[Plugin] Simple Loft alpha 0.1b -- UPDATED May-15-09
Postby Chris Fullmer » Thu May 14, 2009 6:48 pm
UPDATED! 5-15-09
First! if you are looking for a real loft tool, this is not it - yet! This is a solidly working loft tool, but it is missing a key piece (or two) of lofting that will get introduced later. Also, those missing pieces are what make it super fun to use, so this will only be marginally exciting :) Seriously though, this is not a full release of the script. Read the comments below and watch the video and hopefully that is enough to make the useage of the script clear. I'd like to use this thread for suggestions and comments!
What's new
  • I've now added the bezier curve support. So notice that it is not a straight line that connects spline to spline. They are actually connected on a bezier curve. WooHoo!!!!!!!
Rules of Operation.
  • Activate the loft tool.
  • Select the first spline, then the next, and on and on. The order you select them is the order they will be connected.
  • Each spline MUST have the same amount of segments. I'll fix that later, sorry for now.
  • The spline can't be connected to any faces.
  • The script won't tell you've made a bad selection, it just stops working.
  • After selecting all splines, hit Enter.
  • Set the number of segements that will be filled in between each spline.
What's missing
  • I mentioned before, each spline must have the same amount of segments. I know how to fix that, it just takes time to write it.
  • I'll add more User Interface stuff, making it more clear if a good selection has been made or not.
  • Whatever you folks suggest! (well, and I have to be able to program it...
UPDATED VIDEO!!!
old video. Its still good to watch, but some things have changed.
http://www.chrisfullmer.com/forums/loaf_alpha_1a.swf
3
Last edited by Chris Fullmer on Fri May 15, 2009 11:26 am, edited 6 times in total.
User avatar
SketchUp Team
SketchUp Team
Re: [Plugin] Simple Loft _____ ALPHA 0.1a
Postby CadFather » Thu May 14, 2009 7:03 pm
you're unbelievable Chris! : )
Quarr-IT - SketchUp Training from the Master.. http://quarr-it.com/
User avatar
CadFather
PluginStore Author
PluginStore Author
Postby JClements » Thu May 14, 2009 7:37 pm
Chris, don't believe him. You are NOT unbelievable! ... but nearing extremely unbelievable :).
In Rhino, it has prompts to pick the 1st curve, then another prompt to pick the next curve and press [Enter] if done, etc.
If you implemented something similar, you could then have a error check at that point to see if the curve selected was valid or not; if it was then go to a "pick another" prompt and if not then a different prompt stating the problem and what to do to remedy the issue. Just an idea.
John
John
Illustrator
Beaverton, Oregon
User avatar
JClements
Premium Member
Premium Member
Postby Ben Ritter » Thu May 14, 2009 7:38 pm
For a guy like me, nothing's missing.
Thanks. :D
Ben Ritter
Postby Click Draw » Thu May 14, 2009 8:02 pm
Hi Chris,
I have one complaint! Every time I add another awesome script, I have to re arrange my toolbars :-). You the man! Thank you so much. I really appreciate your hours of coding to you put in that benefits all of us so much. I can't thank you enough!
Jeff
Have I mentioned how much of a laugh I get out of some of the Signatures on here!
Click Draw
Postby alpro » Thu May 14, 2009 8:08 pm
Thanks Chris, much appreciated.
Mike
alpro
Premium Member
Premium Member
Postby Frederik » Thu May 14, 2009 9:21 pm
Dang, Chris... This is awesome...!! :thumb:
Thanks...!! :D
Cheers
Kim Frederik
User avatar
Frederik
Thea Render Support
Thea Render Support
Postby materialdb » Thu May 14, 2009 9:29 pm
It's like the curvsticher .. I'm looking forward for the bezier-functionality!
great work! keep it up!!
free vismat materials: http://www.material-db.com
materialdb
Postby Chris Fullmer » Thu May 14, 2009 11:27 pm
materialdb wrote:It's like the curvsticher .. I'm looking forward for the bezier-functionality!
Yeah, that is precisely right. Currently it is only marginally better than curve stitcher (For example, mine is faster, doesn't twist geometery like shown in the video, and you can subdivide to make it a smother mesh, and it works with more than just 2 curves). But like you say, its the bezier connections that will make this awesome! I'm working on that right now and I should be able to get something up and running today.
User avatar
SketchUp Team
SketchUp Team
Postby Daniel S » Thu May 14, 2009 11:34 pm
Looks great!! Very good first version Chris!! :ecstatic: :ecstatic: :ecstatic:
I'm wondering what will be the the missing key piece.
There is not too much to say because you mention most of the problems in "what´s missing".
Having to Make the Splines with the same amount of segments is perhaps the problem that makes it more difficult to use.
Congratulations and thank you!!!
Daniel S
Daniel S
Postby AcesHigh » Thu May 14, 2009 11:53 pm
can it already connect closed lines to open ones?
AcesHigh
Postby Chris Fullmer » Thu May 14, 2009 11:58 pm
No, not at this point. Only works with open "splines" that do not close, and they have to have the same amount of edge segments.
And unfortunately, getting it to work with closed splines will take a lot of re-programming :( I probably won't get to that very soon. But in time. Its definitely do-able. I just need to re-think some things.
User avatar
SketchUp Team
SketchUp Team
Postby utiler » Fri May 15, 2009 12:21 am
Very nice Chris, you really have a handle on what is needed.....
BTW, I PM'd you about another idea for a script.
:thumb:
purpose/expression/purpose/....
User avatar
utiler
Top SketchUcator
Postby Chris Fullmer » Fri May 15, 2009 12:31 am
Thanks Andrew!
PS: Yes, I got the PM. I will have to get back to you on that, it sounds very interesting. And I might need some pictures to help wrap my head around the entire idea :)
User avatar
SketchUp Team
SketchUp Team
Postby utiler » Fri May 15, 2009 12:46 am
Will send you a few pics and video's.... :thumb:
User avatar
utiler
Top SketchUcator
Re: [Plugin] Simple Loft alpha 0.1b -- UPDATED May-15-09
Postby Chris Fullmer » Fri May 15, 2009 10:30 am
UPDATE! Script and video updated.
I've now got the bezier connections from spline to spling working. What does that mean?
Essentially the lofting actually works now. Its a huge improvement.
You still need to make all splines have the same amount of segments though. That will be the next piece I tackle, I promise!
User avatar
SketchUp Team
SketchUp Team
Postby thomthom » Fri May 15, 2009 11:13 am
video isn't loading.... Just get a white square...
User avatar
PluginStore Author
PluginStore Author
Postby Chris Fullmer » Fri May 15, 2009 11:19 am
Sorry, its a big video. about 30mb and it takes a long time to load sometimes. So open that front page in another tab and let it load while you browse other pages.
EDIT: Or, as it turns out, I forgot to actually upload it to my server. :oops: Try it again, thanks for the heads up!
Last edited by Chris Fullmer on Fri May 15, 2009 11:22 am, edited 1 time in total.
User avatar
SketchUp Team
SketchUp Team
Postby thomthom » Fri May 15, 2009 11:22 am
It doesn't have a loading screen?
User avatar
PluginStore Author
PluginStore Author
Postby Chris Fullmer » Fri May 15, 2009 11:23 am
Oh your fast. Sorry, yeah I didn't upload it. So its uploading and should be ready now to try again.
Thanks for pointing it out!
EDIT: Still having issues....hold on.
EDIT AGAIN: OK, now its working!
User avatar
SketchUp Team
SketchUp Team
Postby thomthom » Fri May 15, 2009 11:27 am
Loading! :D
User avatar
PluginStore Author
PluginStore Author
Postby Dave R » Fri May 15, 2009 11:36 am
Wow Chris, this is amazing. Thank you very much for this and all of your other scripts.
User avatar
Global Moderator
Postby thomthom » Fri May 15, 2009 11:36 am
Chris! That's fantastic!
If you find yourself in Norway I'll buy you a big pint of beer!
User avatar
PluginStore Author
PluginStore Author
Postby pilou » Fri May 15, 2009 11:56 am
No possibility to automate the clicks of curves? ;)
the 10 curves are made with the Grow plug by Tig
Speedy Galerie
User avatar
Top SketchUcator
Postby Click Draw » Fri May 15, 2009 2:33 pm
Again.....Thanks very much. This is just amazing....great update! And if your ever in Vancouver, I'll buy you a jug of beer! :ecstatic:
Click Draw
Postby JClements » Fri May 15, 2009 3:01 pm
Very impressive.
Be neat if you could add in something like Joseph Lieblinger's Soap Skin method to flex the triangulated surface.
Regards, John
John
Illustrator
Beaverton, Oregon
User avatar
JClements
Premium Member
Premium Member
Postby EscapeArtist » Fri May 15, 2009 3:26 pm
Fantastic plugin.
Thank you very much for your hard work!
User avatar
EscapeArtist
Top SketchUcator
Postby AcesHigh » Fri May 15, 2009 4:31 pm
damn Chris, you are a genius...
can you please tackle the problems of cold nuclear fusion and faster than light travel, after you finish this plugin? :)
just a question... what if I WANT straight lines connecting faces? You know... for something that doesnt look organic... dunno... like a ship hull or something... maybe you can add, in the final version, option for connecting with splines or lines?
AcesHigh
Postby mitcorb » Fri May 15, 2009 5:34 pm
@Chris:
Thanks for another excellent effort in this Loft Tool.
This is to confirm proof of concept in the wild. I remodeled my guitar neck/body heel transition, and it worked very well.
User avatar
mitcorb
Top SketchUcator
Postby dtrarch » Fri May 15, 2009 5:45 pm
Hi Chris
Heads up on alpha 0.1b
BugSplat on V6 latest (3 times) :(
OK on V7 free latest :D
Using 3 equal arcs.
dtr
dtrarch
Premium Member
Premium Member
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Next
Return to Plugins
cron
Who is online
Users browsing this forum: Hedghhog, SimonParrilla and 18 guests
Visit our sponsors:
