help with hyperlinks
Postby VisionM » Fri May 08, 2009 3:33 am
Hi all
I have used SU for some years now and have always been very appreciative of the help I find freely given in the forums. This is the first time I've asked for help so here goes...............
I have a project to model a site of 19 hectares and am trying to plan my approach first, being very aware of the potential size of this model. The site includes commercial and residential buildings plus a lake, native tree stand and various landscaping features. What I'm planning to do is a 'sketchy' outline model of the whole site showing the differing zones - this should be low poly enough to orbit etc. Then I would like to attach hyperlinks to certain components that would open up a more detailed SU file for that particular aspect. I will then render selected images from each detailed SU model.
Is it possible to link from SU file to SU file from hyperlinks? I'm guessing this would require a ruby script but although I use them I can't write them.
I would be very grateful if any of you experts could guide me in the right direction and offer some suggestions?
Thank you very much.
Lesley
VisionM
Re: help with hyperlinks
Postby remus » Fri May 08, 2009 7:55 am
Im not sure if it is possible, but it would certainly be a great plugin if it was.
remus
Postby HPW » Fri May 08, 2009 8:50 am
Link from local file to local file?
Or link to an url with the file?
One hyperlink per component?
Some rough ideas (WIN):
For an local file the idea is to write a ruby script with a 'require Win32API.so' and import the ShellExecute from shell32.dll .
The hyperlink could be stored in a DC-attribut:
sel_def.set_attribute 'dynamic_attributes', 'hyperlink', 'c:\....'
sel_def.set_attribute 'dynamic_attributes', 'hyperlink2', 'c:\....'
A ruby command would read the attribut and fire the ShellExecute.
Of cource a second instance of sketchup will start.
For an external URL no idea yet.
It would need to first download it and then open it in a second instance.
HPW
Postby VisionM » Fri May 08, 2009 8:59 am
Hi HPW
I was thinking of local file to local file so that it could be displayed either by myself in a presentation or put on a CD using the viewer. Thanks for your suggestions - I'm not sure how to implement your suggestion but I do know someone who can write Ruby scripts so may get some help there. Sounds like it could be possible? I don't think starting a second instance would necessarily be a problem if I was controlling it....
VisionM
Postby HPW » Fri May 08, 2009 9:06 am
For interfacing Win32API your ruby-scripter may have a look at Jim's toggleWindows.rb
HPW
Postby AdamB » Fri May 08, 2009 9:31 am
Here you go. Put this in your Plugins folder and restart SU.
Now you can right click over a Group and either Set the file to link to, or Open an already set link.
Enjoy,
Adam
User avatar
AdamB
LightUp Support
LightUp Support
Postby VisionM » Fri May 08, 2009 10:57 am
Hi Adam
Thanks so much - I really appreciate your time doing that - it works well. I can now plan how to tackle the rest of the project in my sleep as its 10pm at night here in New Zealand.
Cheers
Lesley
VisionM
Postby VisionM » Fri May 08, 2009 10:58 am
Hi HPW - where can I find Jim's toggleWindow script? I've searched but no luck?
VisionM
Postby HPW » Fri May 08, 2009 12:00 pm
HPW
Postby HPW » Fri May 08, 2009 12:03 pm
Adam,
Thanks for the script.
I wasn't aware of Sketchup.open_file(url).
Does it open a new instance or does it replace the open file?
HPW
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to Developers' Forum
Who is online
Users browsing this forum: lemonandy and 2 guests
Visit our sponsors:
