[Plugin] Recall last tool v1.2
Hey Matt - You are eternally my friend! Thanks for listening to my request. I'm sure it will be useful to many!
Astucieux!
Merci Pilou
matt,
here we go again. unless i do not know how to use your new script, it is not working on mac! sorry...
Hi Edson... I hope you do not know!! I'm cursed...
So : Draw a . Draw a . Press space bar for .
Go to Plugins/Recall last tool. Rectangle tool is now recalled.If it does not work, can you open your ruby console, and try again, please?
And, at last, can you call rectangle tool, and try to copy this code in the ruby console ?Sketchup.send_action(21022)
This code calls selection tool.
Thank you Edson. And sorry for the inconvenience. -
matt,
it did not work. i had done it that way before. below is the ruby console reading.
glad to help you. keep your requests coming.
I read a lot /users/mahfuz...
On differenct OS's, even the same OS with different menus, that magic number will have changed.
What's wrong with Sketchup.send_action(selectSelectionTool:);
When the menu structure is updated, then the call will still work even tho the menu id has changed.
Bravo Matt !!
at the very beginning of my learning SketchUp, I was surprised not to have this feature at disposal. And then I was accustomed to always recall my tools. And Here comes your ruby. It is as if suddenly we had won a great lightness. (F2 is great)it already belongs to my toolbox. simon
Merci Simon !
@pecan said:
On different OS's, even the same OS with different menus, that magic number will have changed.
Hi pecan! Are you sure of that? I use only two different numbers in my code. The rest is a recall of the last number used.
But there's a biiig problem with Mac... On Mac, function "send_action" does not accept integers. Only strings!@edson said:
It did not work. i had done it that way before. below is the ruby console reading.
Thank you Edson!
Ouch. I will try to find a solution. Can you test this code below, please?Sketchup.send_action("21022")
it looks good!
Ok. But if you have rectangle tool called, when you copy and validate the code, is the selection tool activated?
i drew a rectangle, then pressed the space bar, then used the script from the menu. the result is in the picture.
Sorry Edson, and all mac users. But I can't do anything with this bug. Function 'send_action' doesn't accept integers (so tool IDs) on Mac.
Result from SU ruby console
(eval)
result = Sketchup.send_action "selectSelectionTool:"
trueI was in error suggesting it was a num.
Using the tool name should work:
def onActiveToolChanged (tools_object, toolname, toolid) print tools_object, toolname, toolid @@Matt_Model_Toolid = @@Matt_Model_Toolid2 if @@Matt_Model_Toolid2 #@@Matt_Model_Toolid2 = toolid if not([21022,10508].index toolid) @@Matt_Model_Toolid2 = "select#{toolname}:"; puts "1: #{@@Matt_Model_Toolid} 2: #{@@Matt_Model_Toolid2}" end
> def onActiveToolChanged (tools_object, toolname, toolid) > print tools_object, toolname, toolid > @@Matt_Model_Toolid = @@Matt_Model_Toolid2 if @@Matt_Model_Toolid2 > #@@Matt_Model_Toolid2 = toolid if not([21022,10508].index toolid) > @@Matt_Model_Toolid2 = "select#{toolname}:"; > puts "1: #{@@Matt_Model_Toolid} 2: #{@@Matt_Model_Toolid2}" > end >
Well... almost.
"selectCameraOrbitTool:" doesnt work.
It's action name is simply OrbitTool.
So maybe a hash of returned tool names and the send_action name.sendActionToolName = {"CameraOrbitTool", "OrbitTool", } etc.
Or maybe a hash of just the exceptions.Its a shame SU has to be so inconsistent.
Here's a list of the send_actions and the actual tool name returned by the observer.
howRubyPanel: viewBack: viewBottom: viewFront: viewIso: viewLeft: viewRight: viewTop: viewPerspective: viewShowAxes: viewShowHidden: viewZoomExtents: viewZoomToSelection: viewUndo: selectOrbitTool: (CameraOrbitTool) ok selectPositionCameraTool: selectDollyTool: (CameraDollyTool selectTurnTool: selectWalkTool: (CameraWalkTool) selectZoomTool: (CameraZoomTool) selectFieldOfViewTool: (CameraFOVTool) <=== inconsistency selectZoomWindowTool: (CameraZoomWindowTool) pageAdd: pageDelete: pageUpdate: pageNext: pagePrevious: renderWireframe: renderHiddenLine: renderMonochrome: renderShaded: renderTextures: ok selectArcTool: selectAxisTool: (SketchCSTool) ok selectCircleTool: ok selectEraseTool: ok selectFreehandTool: selectLineTool: (SketchTool) ok selectMeasureTool: ok selectMoveTool: ok selectOffsetTool: ok selectPaintTool: selectPolygonTool: (PolyTool) ok selectProtractorTool: ok selectPushPullTool: ok selectRectangleTool: ok selectRotateTool: ok selectScaleTool: ok selectSectionPlaneTool: ok selectTextTool: ok selectDimensionTool: ok selectExtrudeTool: ok selectSelectionTool: editUndo: editRedo: editHide: editUnhide: fixNonPlanarFaces: axes is returning SketchCSTool 3d text is returning 3DTextTool plugins return RubyTool orbit return CameraOrbitTool pan returns CameraDollyTool zoom returns CameraZoomTool field of view returns CameraFDVTool zoom window returns CameraFOVTool zoom extends return CameraZoomWindowTool walk return CamerWalkTool look returns CameraPanTool line returns selectSketchTool
Except for "selectFieldOfViewTool: (CameraFOVTool)" you can remove "Camera" from the observer reported name and prefix "select".
Special cases are PolyTool, Line tool, and axis tool.On second thought, a hash like {reportedObserverName, sendSelectName} might be the best bet.
The following seems to work, and you can add to the exceptions hash when you find 'em.
Hope this helps some...
# Supports Organizer.rb =begin Copyright 2009, Matt All Rights Reserved THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE. License: Free Author: Matthieu NOBLET Organization: Matt Name: Recall_lst_tool Version: 1.0 SU Version: 6 and 7 Date: 17/02/2009 Description: Recall last tool used Usage: If you want to have a shortcut, please try with native Sketchup shortcuts... History: 1.000 17/02/2009 First version 1.100 17/02/2009 Global variables replaced by Class variables =end require 'sketchup.rb' class Matt_Observer < Sketchup::ToolsObserver def initialize @ToolExceptionsHash = { # observerName send_actionName "FOVTool", "FieldOfViewTool", "SketchCSTool", "AxisTool", "SketchTool", "LineTool", "PolyTool", "PolygonTool" } end @@Matt_Model_Toolid = nil @@Matt_Model_Toolid2 = nil def onActiveToolChanged (tools_object, toolname, toolid) print tools_object, " ", toolname, " ", toolid, "\n" tname = toolname; @@Matt_Model_Toolid = @@Matt_Model_Toolid2 if @@Matt_Model_Toolid2 # remove "Camera" prefix reported by ToolObserver" @@Matt_Model_Toolid2 = (tname[0,6]="" if (tname[0,6] == "Camera")); tname = @ToolExceptionsHash.fetch(tname, tname); @@Matt_Model_Toolid2 = "select#{tname}:"; puts "1: #{@@Matt_Model_Toolid} 2: #{@@Matt_Model_Toolid2}" end def self.recall_last puts "sending action #{@@Matt_Model_Toolid}" if @@Matt_Model_Toolid return Sketchup.send_action(@@Matt_Model_Toolid) if @@Matt_Model_Toolid return Sketchup.send_action("selectSelectionTool:") end end unless file_loaded?(__FILE__) file_loaded(__FILE__) Sketchup.active_model.tools.add_observer(Matt_Observer.new) $submenu ? (organizer = $submenu) : (organizer = UI.menu("Plugins")) organizer.add_item("Recall last tool"){ Matt_Observer.recall_last } end
