(TRICK) To re-enable skp file preview
Share or learn with the Pros
Postby pibuz » Sat Jan 24, 2009 2:21 pm
Hi guys!
It may sound repetitive, but I've searched a lot in the forum and I hardly found it at last! So I decided to put it here for a more rapid serach (moderators are free to remove this topic if useless).
This micro-tutorial to explain how to enable the thumbnail preview if it doesn't show up automatically.
It typically happens when you have two sketchup version installed and you uninstall one of them: once uninstalled, your skp files' thumbnails are gone, and you can only see the standard sketchup.exe icon.
A solution is obviously to re-install sketchup (repairing the existing installed version), but most of the times it is more practical to re-enable the thumbnails this way:
Start -> run...
type "cmd" and then press "return"
navigate into your sketchup root directory by typing for example:
"cd C:\program files\google\sketchup 6\" and press "return"
now you're in your sketchup6 root folder. Type:
"regsvr32 thumbsup.dll" and press "return".
Done :D
Hope this can help someone
pibuz
Re: (TRICK) To re-enable skp file preview
Postby kwistenbiebel » Sat Jan 24, 2009 2:31 pm
Cool Pibuz!
Does it work with Vista as well?
kwistenbiebel
Postby pibuz » Sat Jan 24, 2009 2:43 pm
..uhm...don't know at all, since I use WindowsXP pro...
Perhaps someone experiencing this problem on Vista could test it...
Sorry!
pibuz
Postby kevsterman » Tue Feb 10, 2009 9:38 pm
Start -> run...
I'm having the same problem in that I don't have previews for any SU models which is a pain as I want to tidy up some folders but can't when all I have is the description.
I'm running Vista 64bit so if I follow pibuz's advice would I have to type "regsvr64 thumbsup.dll" and press "return".
"Avoid keeping more than 3 items on your desk that you can't fit into your mouth."
kevsterman
Postby free agent » Wed Feb 11, 2009 10:15 pm
very handy thanx, my pc at work just started doing that the other day
User avatar
free agent
Postby Marklas » Fri Feb 13, 2009 10:55 am
Hi guys, do you know how you enable this on a Mac?
Thanks,
Mark.
Marklas
Postby Karlfucious » Mon Feb 23, 2009 7:26 pm
Thanks a lot. Ive been wondering how to do this for a while.
Karlfucious
Postby thomthom » Mon Feb 23, 2009 10:50 pm
This would be nice as a sticky thread.
User avatar
PluginStore Author
PluginStore Author
Postby kwistenbiebel » Mon Feb 23, 2009 11:15 pm
thomthom wrote:This would be nice as a sticky thread.
+1
kwistenbiebel
Postby kwistenbiebel » Tue Feb 24, 2009 2:25 am
kevsterman wrote: I'm running Vista 64bit so if I follow pibuz's advice would I have to type "regsvr64 thumbsup.dll" and press "return".
That doesn't work on my box.
Anyone else has an idea to get this working for Vista 64 bit?
kwistenbiebel
Postby BorgMan » Fri Feb 27, 2009 2:49 pm
I had the same problem as well not so long ago. I fixed it by hitting the SU installer and clicking the "repair" option instead of the "install" or "remove" option. It will then check to see if there's anything out of the ordinary (like faulty preview information) and fix it. I think this is the most universal way of fixing this kind of problem, no matter which operating system :)
More varied than the Borg, more powerful than the living dead, and better shots than Imperial Stormtroopers.
You've gotta love Slivers.
BorgMan
Postby kevsterman » Fri Feb 27, 2009 5:00 pm
Where would I find the SU installer?
kevsterman
Postby BorgMan » Sat Mar 07, 2009 2:50 pm
Well... You used a file to install the program, right? That is the file you need. I don't know where you put your files, I usually throw them in a folder called Downloads...
BorgMan
Postby jeff hammond » Sun Mar 08, 2009 2:43 am
Marklas wrote:Hi guys, do you know how you enable this on a Mac?
Thanks,
Mark.
it's not so simple but it's doable... one way is to select custom icon in the 'save as' dialog..
the weird thing about this is that the icons have to be bigger than 48x48 in order for you to see them correctly.. [finder / ⌘J / icon size] .. if you don't want the bigger icons on your system, make a folder for skp files and have only that folder display larger icons (and that works out ok since you're actually trying to look at the icon)..
another problem is that your system isn't showing a preview in the same way it does a .jpg.. you can put a generic icon jpg on your computer and be able to see its icon as a preview.. with the skps, you're only seeing the preview because you custom made an icon for it... so, only the files that are saved with a custom icon will be able to be seen as you wish.. all the other ones will still have the generic sketchup icon..
this is how it will look vs. the standard view.. (the icon doesn't have to be this big btw)
there's an app called GraphicConverter which used to ship with os x... it stopped shipping with macs around the same time they added .skp support to the app :)..
there's a trial available here: (the difference between the trial and full version is that the trial has a 10sec. waiting period before launching)
http://www.versiontracker.com/dyn/morei ... x/10057380
once installed, you only have to browse a folder containing skps in order for it to make preview icons for the files.. super easy -- file/browse folder/navigate to folder... the icons it builds are much nicer than the sketchup customs and it changes the icons very quickly.. these icons are also visible at any size.. if you really want, you can turn on the GraphicConverter automator actions and search your whole system for skps instead of via folders..
sketchup made icon on left -- GraphicConverter on right
and this is what happens if you want to view the icons at 48x48 or smaller
so those are the two workarounds i know of.. maybe with snow leopard we'll see system support for this.. 10.6 is supposedly going to be a more fine tuned 10.5 instead of a bunch of new features.. focus will be on stability, memory use, etc and i can imagine support for a wider range of files which not only will have preview icons but will be viewable with cover flow & quick look..
User avatar
Global Moderator
Postby kevsterman » Wed Mar 11, 2009 12:25 am
I found where the installer was, ran it, hit repair but it didn't make any difference :(
Is there anything else I can try? Is it because I've got SU 6 & 7 installed?
kevsterman
Postby sepo » Sat Mar 14, 2009 12:54 pm
It could be because the path is not correct. The path is cd C:\program files\google\google sketchup 6\ instead of cd C:\program files\google\sketchup 6\
sepo
Postby kevsterman » Sun Mar 15, 2009 10:54 pm
Do I have to have all my components in the original SU folder, ie, in the programme files? At the moment all my components are in a folder in My Documents for ease of access.
kevsterman
Postby sepo » Tue Mar 17, 2009 12:50 pm
No..you don't have to. However I am finding on my Vista comp it is reporting error when calling regsvr32 thumbsup.dll. As consequence I have preview of .skb instead of .skp. Quite bizzare.
sepo
Postby ideas_arte » Mon Apr 20, 2009 5:48 pm
Thanks,
Mark.
 THANK YOU VERY MUCH...! :thumb:
ideas_arte
Postby kevsterman » Wed Jun 03, 2009 7:35 pm
Grr.. I'm still no nearer to solving this problem. Anyone have any other ideas?
kevsterman
Postby eullicious » Fri Jun 05, 2009 8:33 am
pibuz wrote:Hi guys!
Start -> run...
Done :D
sorry.may i know where to press 'return' on the keyboard?which key? :knockout:
eullicious
Postby thomthom » Fri Jun 05, 2009 8:41 am
User avatar
PluginStore Author
PluginStore Author
Postby eullicious » Fri Jun 05, 2009 8:45 am
ok done!thx thomthom :fecstatic:
eullicious
Postby Gaieus » Fri Jun 05, 2009 11:36 am
Yup, "Return" is an "old fashioned" name of the Enter button (does Mac still u7se it BTW?). It comes from mechanic typewriters when that button "returned" the typewriter to the beginning of the next line.
(Ehm... I still used these mechanic typewriters at university. In fact, AFAIK I was the first to write my thesis on a computer in WrdPerfect at the whole faculty) :roll:
User avatar
Postby troyhome » Fri Jun 05, 2009 12:54 pm
[there's an app called GraphicConverter which used to ship with os x... it stopped shipping with macs around the same time they added .skp support to the app :)..
[/quote]
This is EXACTLY what i've been wanting in a .skp viewer/organizer for mac!!! i can move, delete, etc. Brilliant!!! thanks sooo sooo much for showing us this!!!!!
:berserk: :ecstatic: :thumb: :roflmao: :mrgreen: :D
IOviz.com
SU Pro 2017 PC
Thea: latest
vray4SU latest
User avatar
troyhome
Postby kwistenbiebel » Fri Jun 05, 2009 1:12 pm
For Vista 64 bit users (the TRICK is only for XP) Xnview works as well.
Being able to see the icons in the native explorer would have been better though...
kwistenbiebel
Postby kevsterman » Tue Jun 09, 2009 3:09 pm
Thanks for that hint Kwist. I've downloaded Xnview and it does the trick, tho as you say, being able to do it in the native explorer would definitly have been better.
kevsterman
Postby J40 » Tue Jul 28, 2009 5:57 am
kwistenbiebel wrote:For Vista 64 bit users (the TRICK is only for XP) Xnview works as well.
Hey Biebel,
I just installed XP Pro 64bit, and the thumbnails don't work from the beginning. I've tried the command you mentioned, but this is what i got.
J40
Postby J40 » Mon Aug 10, 2009 10:35 am
Is there XP-64 bit users that can see SU's thumbnails? :?
I can't make it work. The only way to view the skp files that possible for me is the SU browser window in thumbnail view :(
J40
Postby thomthom » Mon Aug 10, 2009 3:13 pm
Don't think there is. The SU preview is a shell extension and 64bit OS need 64bit shell extensions.
Though, maybe you can see them in the file dialog of 32bit applications..?
User avatar
PluginStore Author
PluginStore Author
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Next
Return to SketchUp Tutorials
cron
Who is online
Users browsing this forum: No registered users and 2 guests
Visit our sponsors:
