Joint Push Pull Classic (Old version) - v2.2a - 26 Apr 17
Re: [Plugin] Joint Push Pull - Visual Edition
Postby Rodentpete » Fri May 16, 2008 2:00 pm
Excellent! Between this and OOS I am going to save so much time modelling, thanks for all the hard work you've put in.
Rodentpete
Postby neoshed » Sat May 17, 2008 1:28 pm
Many thanks for your effort on these scripts, to quote Push Pull Bar "CRACQUER"
neoshed
Postby marcociacci » Sun Jun 01, 2008 9:35 pm
This Plugin is FANTASTIC!!! thank you
marcociacci
Postby digby dart » Tue Jun 03, 2008 2:49 pm
Thank you for your generosity in sharing this excellent script Fredo6. It works beautifully. I now consider your icons an essential part of the Sketchup screen.
digby dart
Postby topmanblue » Fri Jun 20, 2008 7:42 pm
:roflmao: :roflmao: :roflmao: :roflmao: :roflmao: :roflmao:
Oh~~~~~~~~~~~~~~~~my God!!!!!!!!!!!!!!!!!!!!!!!!!!!thank u
topmanblue
Postby wq418 » Sun Jun 22, 2008 9:47 am
it's cool!!!
thank you
wq418
Postby pix_zaaaaa » Wed Jun 25, 2008 8:44 am
Good :D :D :D
pix_zaaaaa
Postby mpowell1234567890 » Sun Jul 06, 2008 6:44 am
I'm trying to use joint push pull on a model but everytime I use it - Sketchup freezes. is there a way to fix it?
mpowell1234567890
Postby Gaieus » Sun Jul 06, 2008 7:51 am
Michael,
The progress (push/pull operation) is displayed in the status bar. Does it seem to work (and maybe the progress is just too slow) or is that frozen as well?
User avatar
Postby mpowell1234567890 » Sun Jul 06, 2008 10:05 am
Gaieus wrote:Michael,
Both. It happens with a large model. "For example, I made a large maze type shape using a "cubic benzier" or "the freehand" tool. then I clicked on the shape to select it. Then I used the joint push pull to push pull it. 1st click I chosen the height, but when I click it the 2nd time - after a minute, it freezes up.
mpowell1234567890
Postby fredo6 » Sun Jul 06, 2008 1:30 pm
mpowell1234567890 wrote:Both. It happens with a large model. "For example, I made a large maze type shape using a "cubic benzier" or "the freehand" tool. then I clicked on the shape to select it. Then I used the joint push pull to push pull it. 1st click I chosen the height, but when I click it the 2nd time - after a minute, it freezes up.
So, Can you confirm this works fine with small model?
Then, how large is the 'large model'?
Although there are surely limits to how many faces and segments you can handle (due to limits in Ruby memory allocation), JPP usually takes very long when there are many elements. Because Ruby is not multi-threaded within Sketchup, it may 'freeze' Sketchup and even the progress bar, while computing. This may take minutes or longer, but may well end up at some point in time. If you can, try this before doing something else than computing to see if it finally finishes.
User avatar
PluginStore Author
PluginStore Author
Postby plot-paris » Mon Jul 07, 2008 8:44 am
if I do large jpp operations, SketchUp sometimes freezes (certainly, if I click somewhere else).
therefore I wait the first 30 seconds, look in the status bar how many faces are done and how many are still left. thus I can calculate a rough remaining time (which normally precisely matches the real time needed).
then I go to the SCF forum and enjoy live until suddenly (sometimes after 10 minutes or so) SketchUp draws my attention to it by becoming active again...
so Joint Push Pull and SCF-forum work hand in hand :D
User avatar
plot-paris
Postby boofredlay » Mon Jul 07, 2008 4:14 pm
Great idea Jakob!
Fredo, maybe you should ad a progress bar that has a link to the SCF...
"While you wait for your mesh to be created, please enjoy the SCF". :D
You could even add some elevator music to go along with it.
:roflmao:
Ok, I am done amusing myself today.
User avatar
boofredlay
Global Moderator
Postby plot-paris » Mon Jul 07, 2008 5:04 pm
Boofredlay wrote:You could even add some elevator music to go along with it.
:roflmao:
oh yes. that would be wonderful! I love this beautyfully boring pseudo-classical elevator music :roflmao:
User avatar
plot-paris
Postby fredo6 » Tue Jul 08, 2008 8:15 pm
plot-paris wrote:if I do large jpp operations, SketchUp sometimes freezes (certainly, if I click somewhere else).
By the way, in case you exhaust all posts in SCF, I would recommend that you perform JPP by pieces. Normally, making sure the option "extend to neighbors" is on, then the result should be the same.
For the time being, there seems to be no way to interrupt the script or prevent it to grasp all Sketchup CPU, giving the impression that Sketchup freezes. May beGoogle will do something for version 7!
User avatar
PluginStore Author
PluginStore Author
Postby plot-paris » Tue Jul 08, 2008 9:35 pm
a very good tip to do it in pieces. didn't know that gives the same result (wasn't aware of the "extend to neighbors" function either of course).
yeah, lets wait for SU7. I still haven't given up hope that Google will do something truely amazing...
User avatar
plot-paris
Postby mpowell1234567890 » Mon Jul 14, 2008 6:50 am
Almost an Acre in size.
mpowell1234567890
Postby mpowell1234567890 » Mon Jul 14, 2008 6:52 am
Cool, I'll be waiting everyday for it.
plot-paris wrote:a very good tip to do it in pieces. didn't know that gives the same result (wasn't aware of the "extend to neighbors" function either of course).
mpowell1234567890
Postby BorgMan » Fri Jul 25, 2008 3:45 pm
While I'm late, I still want to show my appreciation for the fact that you gave out this script for free, Fredo. It's really a nice piece of programming, and the way it's integrated within the SU toolribbon makes it feel very natural. If Google's watching this, they'd do good to just add the plugin to SU7; why waste time on something that's already there while you can make the next version even better?
More varied than the Borg, more powerful than the living dead, and better shots than Imperial Stormtroopers.
You've gotta love Slivers.
BorgMan
Postby plot-paris » Fri Oct 10, 2008 9:41 am
Coen, you are putting Fredo under pressure, aren't you? :D
User avatar
plot-paris
Postby flyashy » Thu Oct 23, 2008 9:53 am
I'm sure you are tired of all the people thanking you, but I have to thank you for putting this script up.
It's quite simply brilliant and now an essential part of sketchup for me.
Thank you again.
Ashy
flyashy
Postby bellwells » Fri Oct 24, 2008 3:00 am
Coen Naninck wrote:Fredo,
Can you please include inference locking to the Vector Push/Pull mode? Holding Shift to lock inference doesn't seem to work for me.
Also, why is the toolbar labeled NUL Transformation? Perhaps Joint Push Pull is better. After all, that is the name of the plug-in and its current name may be a bit confusing when new users look for it in their toolbars menu.
As always thanks!
This never occurred to me, Coen. Thanks, I've changed my toolbar label.
Ron
bellwells
Premium Member
Premium Member
Joint Push Pull Question
Postby Jim57 » Thu Nov 27, 2008 5:57 pm
by Jim57 on Wed Nov 26, 2008 10:50 pm
I'm offsetting a curved shape on the wall of a cylinder, then insetting the inner panel with Joint Push Pull. It spans 8 facets of the cylinder, and the outer curve has 20 line segments. I made sure all the vertexes of the curve lined up with the edges of the facets, to simplify the work.
When I type in an amount for JPP (.125") the VBS shifts to: "Elts **** / **% **.**sec" (where the asterisks are numbers rapidly ascending until they hit somewhere around Elts 1200 / 100% 55 sec, when the processing is over. If I can manage to offset the surface accurately to 1/8" on my trackpad, it hardly takes any time.
My question is, why the difference? What does "Elts" mean?
Thanks,
Jim
Jim57
Postby fredo6 » Thu Nov 27, 2008 8:52 pm
"Elts" means essentially faces to be processed.
I am not clear about what is exactly the problem you highlight.
User avatar
PluginStore Author
PluginStore Author
Postby Jim57 » Tue Dec 02, 2008 9:04 pm
The tool does the job, it's not a problem like that.
If I type in a number the processing takes about a minute, but if I can move the cursor the exact amount it's almost instantaneous. I'm curious about why the difference.
Thanks,
Jim
Jim57
Postby thomthom » Tue Dec 09, 2008 11:15 am
In regards to the context menu; it'd be nice if it only displayed the menu entries when you have face entities selected. No need for it to appear when you've only got lines, groups and/or components etc selected. When a user, like me, have a few plugins installed the context menu quickly fill up.
User avatar
PluginStore Author
PluginStore Author
Postby skiprender » Mon Feb 02, 2009 3:52 pm
I downloaded the plugin and used it to extrude a concrete base and 2 walkways, but when I used the joint push pull and then tried to stamp a small box on it, it crashed. Every time. Is there a fix for this? I enclosed the file
skiprender
Postby fredo6 » Mon Feb 02, 2009 11:02 pm
Skiprender
Yes it bugsplats, even when you remove the vertical border to the offset surface. Difficult to tell whether this comes from JPP or from the Sandbox Stamp tool, which may not like the generated surface (in particular the triangles in the angles). This is the first time such a bug is signaled, so I don't know too much what can be done. I'll think about it however.
PS: If you just want to draw the rectangle (or any shape) on the curved surface, you may want to try with ToolsOnSurface.
User avatar
PluginStore Author
PluginStore Author
Postby fredo6 » Mon Feb 02, 2009 11:40 pm
I have no explanation, because whether you drag the mouse or enter a number in the VCB, you end up in a stage where you still need to double-click or to press enter to start the JPP process. So there should be no difference actually!
I am interested to have a model where the difference can be perceived.
User avatar
PluginStore Author
PluginStore Author
Postby haynesc » Sun Apr 12, 2009 10:39 pm
hi fredo ... would itbe possible for you to rewrite JPP so that it loads into your fredo collection folder? so that its a bit tidier ?
thanks
haynesc
by Ad Machine » 5 minutes ago
Ad Machine
Robot
PreviousNext
Return to Plugins
Who is online
Users browsing this forum: cadrata, Jardas15, kesarwani2403, RebelWarden, silviosketch2, subjoc, wp_contacto and 10 guests
Visit our sponsors:
