[Plugin] Blackout
[Plugin] Blackout
Postby thomthom » Fri Jan 16, 2009 12:04 pm
This plugin was made on request from Free Agent which wanted a script that turned all materials black so he could then make one material white and render out a material mask for post processing. Hence the name.
I later added another function that picked the material of a selected and turned that white and the rest black, just to make it a little bit more quicker to set it up.
NOTE! Run this script on a backup file!!!
This script removes all textures, and opacity and modifies the colour. While the operation is undoable it's all to easy to accidentally save the file. (I press Ctrl+S regularly as a habit.)
Plugin is operated from the Plugin menu. "Blackout" and "Mask Material"
Tested against SU6 & 7
Update 1.2.0:
Free Agent had a got idea: use the current material instead of the selected object's material. Added this new function.
Download
User avatar
PluginStore Author
PluginStore Author
Re: [Plugin] Blackout (1.1.1)
Postby Stinkie » Fri Jan 16, 2009 12:17 pm
Thanks alot!
User avatar
Stinkie
Postby CadFather » Fri Jan 16, 2009 12:48 pm
ThomThom you're rolling now!
Thanks! :D
User avatar
CadFather
PluginStore Author
PluginStore Author
Postby free agent » Fri Jan 16, 2009 1:19 pm
:thumb: :geek:
User avatar
free agent
Postby plot-paris » Fri Jan 16, 2009 1:36 pm
sounds cool and useful :thumb:
immediately the 'Greyscale' by Jim Foltz springs to my mind.
the script turns all colours to greyscale. then you can one or several textures to be changed back to colour to make them stand out more clearly. somehow Jim managed to preserve all the colour information, the script lets you toggle between 'Greyscale-' and 'Colour-mode'.
that would be the perfect thing to take your script to the next step - make the changes undoable...
User avatar
plot-paris
Re: [Plugin] Blackout (1.2.0)
Postby thomthom » Fri Jan 16, 2009 1:45 pm
The original colour could be stored in an attribute dictionary. But I'm not sure about textures. I didn't find a way to turn them off. Only remove them. Will have a look at Jim's script and see if he handles textures. I've not spent much time on this. Just quickly whipped it together while working on some other stuff.
User avatar
PluginStore Author
PluginStore Author
Postby kwistenbiebel » Fri Jan 16, 2009 1:55 pm
Cool script thomthom! :thumb:
Very useful. Thank you.
kwistenbiebel
Postby bianhai » Fri Jan 16, 2009 6:12 pm
:thumb:
Thank you thomthom.
bianhai
Banned
Postby Gaieus » Fri Jan 16, 2009 7:44 pm
Tom,
In SU you can undo an operation after saving, too. Does it not work in this case?
User avatar
Postby thomthom » Fri Jan 16, 2009 7:48 pm
I suppose so. But I make the warning just in case as there isn't any built in restore in the function. Also, with V-Ray for SketchUp I've experienced that it can some times interfere with the undo operations of scripts. Especially if it manipulates materials.
It's a better safe than sorry warning. ;)
User avatar
PluginStore Author
PluginStore Author
Postby sepo » Sat Jan 17, 2009 2:05 pm
This is useful. Thanks.
sepo
Postby JClements » Sun Jan 18, 2009 11:13 pm
ThomThom:
I think this might have been discussed a year or two ago.
I make masks for postprocessing by turning all my layer colors to black and turn on Color By Layer in the Layer Manager. This eliminates messing with the material colors directly. I hardly ever organize my layers via a color scheme so this method is relatively fast to do and doesn't screw up the model. Also, SU shadows are exported with their greyscale value which can be interpreted in post processing as semi-transparent.
I often create a style for Color by Layer in my model and assign it Scene named "MASK" which only remembers style parameters. I can then use this scene to on toggle Color by Layer for any of the other scenes.
My workflow would be to click on any Camera view or Scene and select the "MASK" Scene, and export the current view as your mask for post processing.
Now IF Ruby can remember and store a model's existing Layer Colors and later restore them, then a script to temporarily change the model's layer colors to black, turn on Color by Layer, queue the File > Export > 2D Graphic dialog and then restore the layer colors after printing, might be pretty quick and handy.
JClements
Premium Member
Premium Member
Postby thomthom » Mon Jan 19, 2009 12:22 pm
Interesting.
I made this script very very quickly. I might revise it and implement some more stuff suggested. Appears that there was more use for this than I thought. And there's some good ideas here.
User avatar
PluginStore Author
PluginStore Author
Postby MALAISE » Sat Jan 24, 2009 8:58 am
THanks Thomthom
Back to the forum after a while and discovering new rubies :D :D
MALAISE
User avatar
MALAISE
Postby me3mar » Sun Feb 01, 2009 1:58 pm
can you please show some pics on how to use, and what for ?
that would be great
thanks in advance
me3mar
Postby sepo » Fri Jun 26, 2009 4:57 pm
Would it be possible to include transparency of .png . Give you an example. If you for instance have a .png tree in front of the material than tree should go black instead of rectangle. It would make life much easieer if possible.
sepo
Postby thomthom » Fri Jun 26, 2009 5:34 pm
Nope. Can't read transparency info. If I had access to the V-Ray maps I could have replaced the texture with the alpha texture - but I don't have access to that either.
User avatar
PluginStore Author
PluginStore Author
Postby sepo » Fri Jun 26, 2009 11:02 pm
Thanks for the reply.
sepo
Postby xiombarg » Wed Mar 19, 2014 5:36 am
This is actually another really good plugin for character and product design and a standard feature of high end modelling programs. Animation modelling programs implement this feature to help the designer get a better idea of a characters posture and demeanor which subtly reflects their personality. Product designers also use it for similar purposes.
Probably is a good idea to do a quick save before using it though, just in case.
User avatar
xiombarg
Postby onzki » Fri Aug 04, 2023 7:08 am
Hi I know it's an old thread. Is there a way to customize the color, instead of black maybe something else, like red or any RBG code? Thanks!
[/hr]Dell Alienware Area-51. Skp Pro version 23.1.340 AutoCAD 2023. Landscape design firm
onzki
Postby Didier Bur » Fri Aug 04, 2023 10:23 am
Hi onzki,
Go to your 'Plugins' folder and open 'blackout.rb' in a pure text editor (Notepad++ for instance).
Search for lines like this one:
Code: Select all
material.color = 'Black'
Replace 'Black' with the color you want, like 'red', 'green', 'blue' and so on.
Lines to be modified are: 42, 69,91, if i'm not mistaken.
The names of available colors can be found on this page:
https://ruby.sketchup.com/Sketchup/Color.html
To customize the color with RGB values will be a little longer to explain ;)
Save the file blackout.rb, quit SketchUp and restart.
Regards,
Didier Bur
User avatar
Didier Bur
Postby Didier Bur » Sat Aug 05, 2023 1:34 pm
Hi, me again,
Here is an enhanced version with which you can select your color in a list.
Menu can still be found in the 'Extensions' menu but I've put the 3 options in a sub-menu to spare your menu space ;-)
Hope Thomthom won't mind if I modified his script.
Regards,
3
Didier Bur
User avatar
Didier Bur
Postby onzki » Fri Aug 25, 2023 8:05 am
Didier Bur wrote:Hi, me again,
Regards,
Amazing! Big Thanks! :D :thumb:
onzki
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to Plugins
Who is online
Users browsing this forum: alsomar, kadcad, SAlesh, Sam968057, sophiaashley02 and 5 guests
