[Plugin] BoolTools just released!
I have just released my boolean plugin at http://www.smustard.com/script/BoolTools
Features:
- union, difference, and intersection operations for groups or components
- can handle coplanar faces
- fast and user-friendly
This is such a nice tool. One of them essential which you'd wish came with SU.
Thanks, Whaat. Should come in handy.
Seems there are now 2 boolean tools
Hi Whaat! Great plugin!
Just one thing : All your plugins are scrambled. That's ok.
But we can't move your menus or insert your icons in a personal toolbar... Is it possible (and do you agree ( ) to allow users have access to menu and toobar commands, please?Thank you Whaat!
Awesome plugin, I have been playing with it this week and amazed at speed.
[flash=600,344:1s6y20if]http://www.youtube.com/v/LaSx-xV8Dik[/flash:1s6y20if]
Hehe...I can see a lot of rendered sections coming.
Sepo, the free 'zorro' plugin is also good for cut away renders.
I know ....it is a bit fiddly to control though. This looks like much easier way.
Thank you Whaat!i also second that, Whaat. that way one could integrate it with other toolbars decreasing their numbers - it would be great even for the subsmooth plugins
hmmmm...I'll be considering this in the future. I'm not sure right now how to do this. Thanks!
What a great interim gift in lieu of Profile Builder.....which we all eagerly await.
Will BoolTools work with 3D text?
Works with 3d text.
Very nice plugin btw whaat. Typical of the well thought out and powerful tools you seem to have a knack for producing.
- A request. When performing a Cut - it is sometimes desirable to KEEP the geometry that is acting as the edge for the cut. eg Trimming Steel Beams 1 and 2 with Wall 1.
Sometimes I'd like to keep Wall 1 after the operation.
Could this be built in - eg with an option dialog ??? Would be very handy.
I anticipated this request and tried hard to get this to work for this version but it was too buggy. My idea was that you could hold down the CNTL modifier key while selecting if you want to keep the cutting geometry. Hopefully, I can get it to work for the next version. There is a fairly easy workaround though:
- Select the 'cutting' group and press CNTL+C to copy. You can actually select the group by hovering your mouse over the cutting group while you have the 'Difference' tool active.
- Perform the cut with BoolTools
- Choose 'paste-in-place' to get the cutting group back. (a shortcut-key would come in handy here...)
Hope this helps!
Another great ruby Dale. Scooped it up the second I saw this post last night.
Since I've been putzing around with drill bits I thought this would be handy amongst other objects. This is an eyeballed version I just did without needing any clean up.
The cut into the cylinder had to be copied twice (180 degrees). Basically this involved: 1) helix13; 2) curves to tubes; and 3) Bool Tools.
This will surely cut down on intersecting and erasing.
WOW!! Even I can't believe that was created with SketchUp!!
Dale,
Fantastic Script - SO USEFUL.
I can see this is something that'll I'll be using a lot.
Please see attached - an observation and a request.
OCCASIONALLY, a co-planar edge is left behind. Seems to occur when unioning 2 "Solids" that are right up against each other before the operation is initiated. See Face 1 and Face 2 for example. Possible fix by incorporating delete-coplanar edges script - although I'm pretty sure you've got something similar in there anyway, as this only occurs occasionally.
Other than this the cut feature works brilliantly - very fast.
Thanks once again for producing this script.
This is going to make SU so much more useful and powerful.
Regards
Howard L'
Not knowing much about rubys, or any kind of scripts for that matter, and not having purchased BoolTools, what are the advantages of purchasing this over getting the free Oscar tools?
I havent really had a proper go with oscar's version, but i think whaats version is currently more refined and generally works better.
That's exactly what came to my mind while reading Howard's "wish". Actually, I have used this a lot already with "simple" intersection methods as well.
As for a shortcut; Since Ctrl V is already for pasting things, I have assigned Shift Ctrl V to paste in place
