[Plugin] Boolean--OSCoolean (Dec 2013) for SU 8 up free ver
Great! I've always wanted boolean operations in SU.
Thanks Oscar!
..guess it should have been part of the scf powertoolbar!
Well,finally had some time to play with it - but the same as Coen; nothing seems to happen no matter how I combine the things.
Here is the error in the Ruby Console:
Error: #<NameError: uninitialized constant OSCoolean::Oscar> (eval):331:in `Cut' (eval):376 (eval):376:in `call'
Error: #<NameError: uninitialized constant OSCoolean::Oscar> > (eval):331:in `Cut' > (eval):376 > (eval):376:in `call'
not only cut-command
Error: #<NameError: uninitialized constant OSCoolean::Oscar> (eval):1068:in `Intersect' (eval):1204 (eval):1204:in `call' (eval):3878 Error: #<NameError: uninitialized constant OSCoolean::Oscar> (eval):1161:in `Cut' (eval):1206 (eval):1206:in `call' (eval):3878 Error: #<NameError: uninitialized constant OSCoolean::Oscar> (eval):1114:in `Union' (eval):1205 (eval):1205:in `call' (eval):3878
Hi, same as Coen and Gaieus.
nothing happen,
no error messages. -
Thank oscarlok
Hi Everybody,
Oh ya! "Error: #<NameError: uninitialized constant OSCoolean::Oscar>" (Thanks for Jim & ilay7k 's error report)
Sorry ! part of my def script is under another ruby script in Class Oscar.
Anywhere, I have repackage OSCoolean script and with OSCoolean.skp for testing.(In the FIRST post)Thanks
Oscar -
Is this an answear to this?
http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=14217 -
Yep, this is a boolean tool, although still under development, as the author says.
Thanks Oscar,
This is a very cool tool, although a bit buggy, it's another work simplifier and enhancer for Sketchup
, can't wait for the improved version.
Good luck. -
Thanks Oscar! Now it works (although indeed there are some little bugs - especially when there are coplanar faces with a union for instance)
Great development Oscar.
Bep van Malde
Tell us when V 1.0 is released!
Wow. I was JUST doing some intersect and delete stuff manually, and was thinking about how useful it would be if there was a ruby to do it for me. I go to see if I got any comments on posts here, and viola.
This only works on SU7...
Nice job oscarlok!
I'll be watching this one. This is a long-needed feature for SketchUp.
Dale
very good script to watch... this will be another milestone. i hope it will also have bollean add. where when you intersect two volumes, the unwanted volume will be erased automatically.
If I understand your words correctly, this is exactlywhat happens with the script (apart from the errors/bugs).
