Some more of my work.
Postby boofredlay » Fri May 03, 2019 10:54 pm
Here are some images of work I have been doing over the past few years (native SketchUp).
Most of these are built or under construction; a couple still fund raising.
4
boofredlay
Global Moderator
Re: Some more of my work.
Postby ntxdave » Sat May 04, 2019 12:13 am
Some interesting looking areas. What part of Alabama?
ntxdave
Postby majid » Sat May 04, 2019 7:04 am
Nice! wow, couple of nice spaces and fine presentation!
My V-Ray book for architects: https://goo.gl/cz1oRc
majid
Top SketchUcator
Postby HornOxx » Sat May 04, 2019 7:44 am
Prima Eric - it's really a good idea to present a (kind of) "activity overview" which all I enjoy looking at! - Especially also when the shown arc spans over such a wide range of different projects, both in terms of their type and size. And all of us realize that this is just a small excerpt of your doing ! :D
Impressive and thanks for showing these here :thumb: :thumb:
never trust a skinny cook
HornOxx
Postby jenujacob » Sat May 04, 2019 9:59 am
Hi Eric,
Really impressive modeling and designs. Does your firm use sketchup only till the conceptual/ schematic phase? Or do they go all out till construction detailing? Do you utilize layout for the drawings? Do you use revit as well? If yes, how do you transition from SU to Revit? Do you redo everything in Revit?
Thanks!
jenujacob
Postby Mike Amos » Sun May 05, 2019 7:54 am
They definitely do the business. Nicely done.
Premium Member
Premium Member
Postby boofredlay » Mon May 06, 2019 5:37 pm
Thanks guys.
ntxdave wrote:Some interesting looking areas. What part of Alabama?
Huntsville / Madison Alabama.
jenujacob wrote:Hi Eric,
Thanks!
It all depends on the project. For the smaller projects we usually use SU through conceptual - schematic then kick it to CD's in Revit (there are still a few Autocad stragglers in our firm). I won't use the SU model again unless to generate a title sheet image or to answer questions during CD's.
For larger projects we usually use SU in tandem with Revit. Sometimes I run both models, sometimes I am running the Su while someone else does the Revit. It is extra work but seems to work well with our style. I am able to work closely with the Architect on design decisions while the CD's are being generated. However most of the SU model is exterior and a few key interior areas.
The only things I might import into Revit from SU are signs or 3d text that is manipulated in SU. Those can be challenging in Revit while I can bang them out in SU in no time.
I have never used Layout.
boofredlay
Global Moderator
Postby jenujacob » Mon May 06, 2019 7:24 pm
Thanks Eric for the detailed info! Nice to hear about workflows from the other part of the globe! :)
jenujacob
jenujacob
Postby Bryan K » Tue May 07, 2019 7:10 am
Very cool!
Return to Gallery
Users browsing this forum: No registered users and 6 guests
