this is some of my works
Postby cj_sniper » Sun May 22, 2011 7:54 am
here is some of my works :oops:
cj_sniper
Re: this is some of my works
Postby cj_sniper » Sun May 22, 2011 7:57 am
and more...
Manta - high-speed underwater vehicle with minimal noise, which is achieved by a water-powered engines. Equipped with 10 torpedo room with Tomahawk missiles, 4 triggers to engage aerial targets, and 2 torpedo bays for hitting flooded and underwater targets. Also there are 2 large caliber guns, and 20 medium-range missiles. Because of its stealth, speed and mobility, this submarine is designed to swim undetected behind enemy lines to gather information or precise destruction of the enemy.
(logo mine to)
cj_sniper
Postby cj_sniper » Sun May 22, 2011 8:00 am
cj_sniper
Postby orgelf » Sun May 22, 2011 12:26 pm
excellent simple shapes cj_sniper !!
your renders are very coloured , but I like them . Good style :)
orgelf
Postby cj_sniper » Sun May 22, 2011 1:06 pm
big big thanks
cj_sniper
Postby cj_sniper » Mon May 23, 2011 3:39 pm
Chairs for hacienda. Purpose - kitsch, show off and do not like at all, but the convenience of sitting (not lying) to read books and support the back. Approved the spiral arms of (this office has in mind), the material of manufacture: steel plates laminated with warm (Matt) textured plastic, chrome side profiles (green and yellow on the meadow at a verandah color) + Covers with pillows under the fifth point))
cj_sniper
Postby Bryan K » Wed May 25, 2011 12:59 am
Fun stuff!
Postby cj_sniper » Mon May 30, 2011 12:00 pm
toys for children from 1 to 4 years PLANETARY RIDER
child are thrown on the car, parents control the movement of the machine, you can switch on the steering wheel driving a car
cj_sniper
Postby cj_sniper » Mon May 30, 2011 3:28 pm
hybrid diesel-electro truck GOLIATH-ED
cj_sniper
Postby StilTeg » Mon May 30, 2011 8:37 pm
Some are really really very nice !! Congratulations
doing technical engineering on SketchUp ... without plugins
StilTeg
Postby cj_sniper » Mon May 30, 2011 10:08 pm
StilTeg - thanks
cj_sniper
Postby cj_sniper » Thu Jun 02, 2011 10:49 pm
chopper concept
cj_sniper
Postby pilou » Fri Jun 03, 2011 12:23 am
Very refreshings models! :fro:
Speedy Galerie
Top SketchUcator
Postby cj_sniper » Fri Jun 03, 2011 12:30 am
thanks
cj_sniper
Postby cj_sniper » Sun Jun 05, 2011 11:29 am
hotroad buggy (alot of small details)
cj_sniper
Postby cj_sniper » Mon Jun 06, 2011 12:48 pm
LED Lamp "Flower Power", the lamp not only change the brightness but also hide behind the petals ... lamp equipped with a clock, alarm and has 3 modes:
1) Manual (adjust themselves what light you need and enable, disable) manipulations performed by touching the touch-mound at the base of the lamp,
2) automatic time (ask what time the lamp is switched on and off in what, as well as the intensity of light) button on the left of the clock
3) Automatic on sensitivity (the base is a light sensor, if the lamp goes dark, the darker the brighter the lamp lights and acc. vice-versa) button on the left of the clock
cj_sniper
Postby cj_sniper » Tue Jun 07, 2011 10:47 pm
BLUESKY chopper
cj_sniper
Postby cj_sniper » Wed Jun 08, 2011 4:00 pm
Here are a couple of robot (complete sets of furniture, "Hills" was made ​​of 10 pieces, after the crisis ceased to be ordered, as expensive in production)
Roulette "WilderWestern"(to make when he was the height of the gambling business in Ukraine for a chain of casinos, only 5 tables were produced
cj_sniper
Postby cj_sniper » Thu Jun 09, 2011 3:25 pm
LED Park Lamp "Lily"
completely autonomous because powered by solar elements, the body is made of fiberglass, painted in green color is not obtrusive than it does not emit light from the composition of the park, ceiling made ​​of reinforced plastic, inside a LED elements
Rod with a metal frame. Lamp height (an element) 3,5 m and 1,1 m. rod removal Destination: lighting fittings, sidewalks, pedestrian zones.
cj_sniper
Postby cj_sniper » Tue Jun 14, 2011 8:57 pm
"Jerboa"
the vehicle for movement on Mars
cj_sniper
Postby orgelf » Tue Jun 14, 2011 10:55 pm
very cool "vehicle for movement on mars" :D
orgelf
Postby numbthumb » Tue Jun 14, 2011 11:10 pm
Jerrycans? What fuel does that Mars vehicle use? :D
Seriously, interesting concept. Looks like you have paid more attention to curved parts - they look quite segmented on your previous models.
Comfortably numb...
numbthumb
Top SketchUcator
Postby cj_sniper » Wed Jun 15, 2011 8:19 am
in cans no fuel (fuel - nuclear generator) in their water! Something without which it simply can not survive on Mars (and elsewhere)
cj_sniper
Postby cj_sniper » Wed Jun 15, 2011 8:33 am
The rover "TUSHKAN"
Fuel: in the back of the rover is electric generator at a nuclear fuel, the rotation of the wheels is a chain mechanism with independent motors.
Type the passengers: the rover descends to a height of 50 cm between the hull and the surface of B, then the door gets up and moves forward allowing access to passengers and the driver to board the transport "A".
Features: transport has 4 legs (each of which can be operated independently, which allows him to overcome even the steepest mountain surface) radius of the variability of foot 80 degrees "C". Wheels with tires of low pressure for maximum grip with the ground, equipped with spiked steel inserts. Changing the wheels is made in 3 steps: prepare a spare tire and lift the injured leg of transport, unhook the damaged wheel (turning off the hydraulic lock in the mechanism near the wheels), insert a spare tire in the grooves and re-enable the hydraulic clamps (mounting), thereby fixing the wheel. The wheels have ball bearings at the bottom of the foot, which adds increased maneuverability.
Transportation is also equipped with two 40 liter jerry cans with water (so to speak NC)
Designed for movement on the surface of Mars during its colonization (or rather for the mountain and crater surfaces), requires the presence of gravity)). Used as a scout the territory.
cj_sniper
Postby numbthumb » Wed Jun 15, 2011 9:12 am
Aaah..water jerrycans. Hope they´re properly insulated :D
Very imaginative work!
Comfortably numb...
numbthumb
Top SketchUcator
Postby cj_sniper » Wed Jun 15, 2011 9:20 am
thanks
cj_sniper
Postby chocolate_fou » Fri Jun 17, 2011 5:14 pm
Nice concepts you got there...keep it up..
chocolate_fou
Postby cj_sniper » Tue Jun 21, 2011 11:42 pm
a couple of my works
toy cars
cj_sniper
Postby cj_sniper » Wed Jun 22, 2011 10:00 am
moonwalker for tourists "crater Turtle"
panoramic roof and sides - for better viewing
cj_sniper
Postby cj_sniper » Wed Jun 22, 2011 3:18 pm
and again retro inspiration
cj_sniper
Next
Return to Gallery
Users browsing this forum: No registered users and 4 guests
