Catamaran
Re: Catamaran
Postby tuna1957 » Thu Nov 17, 2022 5:53 am
Looking good so far :thumb: :thumb:
tuna1957
Premium Member
Premium Member
Re: Catamaran
Postby Bryan K » Thu Nov 17, 2022 6:55 am
Thanks tuna!
Premium Member
Premium Member
Re: Catamaran
Postby Bryan K » Sat Nov 19, 2022 1:04 am
Aft fixed. It looks a little off because of the visible lines, but it is correct. (later edit: it was not ) I have not ungrouped the Curviloft sections yet, but when they are ungrouped and merged, it will look better. I will wait until I am absolutely sure it is correct. I'm only 98% sure at the moment.
On to the main cabin in the meantime.
Premium Member
Premium Member
Re: Catamaran
Postby ntxdave » Sat Nov 19, 2022 1:49 am
Coming along nicely. :thumb:
ntxdave
Re: Catamaran
Postby Bryan K » Sat Nov 19, 2022 5:26 am
ntxdave wrote:Coming along nicely. :thumb:
Thanks!
Premium Member
Premium Member
Re: Catamaran
Postby Bryan K » Sat Nov 19, 2022 5:43 am
Resetting my workflow.
3
Premium Member
Premium Member
Re: Catamaran
Postby Mike Amos » Sat Nov 19, 2022 2:12 pm
Definitely proceeding nicely mate. :thumb:
Premium Member
Premium Member
Re: Catamaran
Postby Bryan K » Sat Nov 19, 2022 8:19 pm
Mike Amos wrote:Definitely proceeding nicely mate. :thumb:
Thanks!
Premium Member
Premium Member
Re: Catamaran
Postby Bryan K » Thu Nov 24, 2022 5:50 am
OK, going to check all lines before I got further.
The stern of the hull is definitely not right.
Premium Member
Premium Member
Re: Catamaran
Postby Bryan K » Sat Nov 26, 2022 5:58 am
Stern fixed! (again it was not ) Took some fiddling and finessing even with Curviloft.
Premium Member
Premium Member
Re: Catamaran
Postby Bryan K » Sat Nov 26, 2022 6:12 am
And dang it, it's still off by just a hair.
But I see how to fix it.
Premium Member
Premium Member
Re: Catamaran
Postby Bryan K » Sat Nov 26, 2022 8:43 am
Fixed. The curve and slope are now correct.
See the shadow line? Yeah, this is fixed. Getting that top arc just right was... challenging. :lol:
Premium Member
Premium Member
Re: Catamaran
Postby marked001 » Tue Nov 29, 2022 6:19 pm
Nice..this is coming along!
http://www.revision21vis.com
instagram: revi21on
marked001
Premium Member
Premium Member
Re: Catamaran
Postby Bryan K » Tue Nov 29, 2022 7:46 pm
Thanks marked001.
I've been a little under the weather, so I've just been doing easy renders. Can't focus on the hard stuff right now.
The weather swings in my region are making me... groggy? We are seeing 40F swings in very short periods.
Premium Member
Premium Member
Re: Catamaran
Postby ntxdave » Tue Nov 29, 2022 7:50 pm
Bryan K wrote:The weather swings in my region are making me... groggy? We are seeing 40F swings in very short periods.
Yep, one day you need a parka and the next you need a t-shirt :D
ntxdave
Re: Catamaran
Postby tuna1957 » Wed Nov 30, 2022 9:56 pm
Excellent progress :thumb: :thumb:
Side note…. I get the feel bads from the weather swings also. It’s been jumping around pretty bad lately here in north Texas
tuna1957
Premium Member
Premium Member
Re: Catamaran
Postby Bryan K » Fri Dec 02, 2022 3:17 am
Thanks tuna. :thumb:
Yeah, it's too much for me.
Anyway, roughing in the lower central deck hull. Next step will be to rough-in the aft deck.
Premium Member
Premium Member
Re: Catamaran
Postby Bryan K » Sat Dec 03, 2022 12:23 am
Roughing in the aft deck. I will be taking some liberties with the aft deck as I do not have very good references of it.
Premium Member
Premium Member
Re: Catamaran
Postby Mike Amos » Sat Dec 03, 2022 1:49 pm
Looking great Bryan, nice progress. :thumb:
Premium Member
Premium Member
Re: Catamaran
Postby Bryan K » Sun Dec 04, 2022 12:22 am
Thanks Mike!
Premium Member
Premium Member
Re: Catamaran
Postby Bryan K » Sun Dec 04, 2022 7:29 am
I had to rebuild all of the middle cabin deck. The end points did not line up with the hull contact points on the first build. Why, I have no idea. But it is all tight and correct now.
I also had the lower deck profile wrong. Now fixed as well.
I have a better handle on the aft deck as well.
The windows on the front were not easy, even with tools on surface. It took me several hours figuring out how to get the curve to line up with the side windows.
This is proving as challenging as the Nadesico. Still going faster, though. Much fiddling and cursing, but going faster. :lol:
Premium Member
Premium Member
Re: Catamaran
Postby Bryan K » Mon Dec 05, 2022 1:30 am
Experimenting with the aft deck cover. It's close but not right.
Premium Member
Premium Member
Re: Catamaran
Postby Bryan K » Wed Dec 07, 2022 5:10 am
Close enough. Lots of Curviloft and Tools On Surface and Joint Push Pull. ...and fiddling and cursing
JPP mangled some of the inside geometry, but I'm going with it as you can't really see it on the underside of the roof except as slightly thick lines and not at all if I turns lines off. I'll do better on the next one.
Premium Member
Premium Member
Re: Catamaran
Postby L i am » Wed Dec 07, 2022 1:40 pm
I was watching a travel documentry the other day and I saw a craft that looked very familiar to me. It was the craft you are building. A beutifull craft indeed :thumb:
Premium Member
Premium Member
Re: Catamaran
Postby Bryan K » Thu Dec 08, 2022 1:51 am
Thanks L I am.
I'm still not quite satisfied with with the aft deck cover and thinking about the geometry tells me it really is not right yet.
Premium Member
Premium Member
Re: Catamaran
Postby Bryan K » Fri Dec 09, 2022 2:47 am
Here we go. Far better and the geometry agrees as well.
OK! On to the aft deck details!
Premium Member
Premium Member
Re: Catamaran
Postby Bryan K » Fri Dec 09, 2022 3:12 am
Checking the form with lines temporarily off and shadows on and background set to context.
Premium Member
Premium Member
Re: Catamaran
Postby ntxdave » Fri Dec 09, 2022 4:01 am
Coming along….looking forward to where you take it. :thumb:
ntxdave
Re: Catamaran
Postby Mike Amos » Fri Dec 09, 2022 12:07 pm
Agreed. Do you still have the face for the profiles in the hulls? I found deleting them can clean up the hull forms considerably. I like, a lot. :thumb: :thumb:
Premium Member
Premium Member
Re: Catamaran
Postby Bryan K » Fri Dec 09, 2022 10:26 pm
Thanks ntxdave!
Thanks Mike!
Yes, the profiles of still there. I have not committed to exploding the Curviloft objects yet. The last post was to confirm to me that the shape was good before I commit. Because once exploded, there is no going back.
It will most likely be the very last thing I do. I still need to add add many other parts. I am still at the rough-in phase.
Premium Member
Premium Member
PreviousNext
Return to Gallery
Users browsing this forum: No registered users and 5 guests
