Render This - Marble
Postby boofredlay » Thu Aug 19, 2010 2:44 pm
Ok, I was sifting through old models and found a marble I tried rendering last year without success. So I put it up for a render challenge. Use this marble or make your own.
The image above is not a rendering, just an example. My poor attempt is below.
boofredlay
Global Moderator
Re: Render This - Marble
Postby olishea » Thu Aug 19, 2010 3:45 pm
ooh nice challenge
oli
olishea
Premium Member
Premium Member
Postby sepo » Thu Aug 19, 2010 7:03 pm
I wish the model was smoother.
sepo
Postby massimo » Thu Aug 19, 2010 10:32 pm
Here is my shot... :D
massimo
Postby Rich O Brien » Fri Aug 20, 2010 12:23 am
Something a little different [sic. shite]
Rich O Brien
Administrator
Postby EarthMover » Fri Aug 20, 2010 12:25 am
Render engine? Render Time? Technique & Approach? These should be mandatory with every render submitted in any "Render This" challenge. If not, then you might as well take "Ucation" out of SketchUcation. :geek:
Content Creator at Skapeup
EarthMover
Premium Member
Premium Member
Postby Rich O Brien » Fri Aug 20, 2010 12:42 am
Good point Adam :thumb:
Render Engine - Simlab Composer
Render Time - 1hr
Technique/Approach - Basic Studio with Titanium texture. Studio HDR and a directional light. Glass was water ior value with plastic applied to interior feathers. Tried to create a more NPR feel to it. Not to everyones taste I'd imagine but I liked the result all the same.
Rich O Brien
Administrator
Postby andre51 » Fri Aug 20, 2010 7:48 am
This is a welcome break from the normal architectural stuff!
Used Maxwell - render time about 3hrs but image was OK after about 1hr.
Bump to surface a bit overdone.
andre51
Postby fymoro » Fri Aug 20, 2010 7:51 am
Here is my render,
Twilight 1.4, easy Hight+ preset, Hdri lighting, 8 minutes at 800/800.
PP with ACDsee pro for contrast and border...
fymoro
Postby fymoro » Fri Aug 20, 2010 10:05 am
Another image, preset easy 10, 40 minutes...
Twilight caustics... ;)
fymoro
Postby olishea » Fri Aug 20, 2010 10:10 am
bravo guys!! :o
oli
olishea
Premium Member
Premium Member
Postby martin-art » Fri Aug 20, 2010 10:54 am
Rendered in Shaderlight, taking 33 minutes at 800 x 600. Setup using a simple room environment with GI and bump.
martin-art
Shaderlight
Postby boofredlay » Fri Aug 20, 2010 4:54 pm
Oh man, these are looking great. I must try again soon.
boofredlay
Global Moderator
Postby Burkhard » Fri Aug 20, 2010 5:16 pm
..another raw octane with hdri lighting.
Burkhard
Premium Member
Premium Member
Postby massimo » Fri Aug 20, 2010 6:03 pm
Another one. Kerkythea again, unbiased 100 passes, procedural clipmap for the sack. No post pro with the exception of the vignette in Photoshop. :D
massimo
Postby stefanq » Fri Aug 20, 2010 6:40 pm
V-Ray for SU, studio setup, 21 minutes, HDRI in background, and for illumination.
stefanq
Postby EarthMover » Sat Aug 21, 2010 3:00 am
A quick stab at it. Vray/Max - 40 minutes at 1600x1200. Rendered with a studio setup and HDRI. Post process to color adjust, add the DOF and vignette. Also smoothed the geometry.
EarthMover
Premium Member
Premium Member
Postby urgen » Sat Aug 21, 2010 1:21 pm
...Hypershot 20 min+some photoshop...hot weather now ...
--pupil forever...------
urgen
Postby puck » Sat Aug 21, 2010 1:54 pm
First crack at this one.
Arion Render - 60 mins
Set up time after sketchup was about 15 mins
I've got another one cooking at the moment with a slightly different material for the outside of the marble. I'll upload it when it's done.
Puck
puck
Postby puck » Sat Aug 21, 2010 3:13 pm
Second one using Arion Render. This took about 1h 20m. I'm quite pleased with the results, would like to have put some DOF on it but I'm not sure how to do that with Arion yet.
Puck
puck
Postby dale » Sat Aug 21, 2010 4:31 pm
As usual some great work.
My first contribution:
Thea /TR1(unbiased)/48 min/combination of IBL reflection mapping and physical sky at dusk/thin film
dale
Top SketchUcator
Postby solo » Tue Aug 24, 2010 10:41 pm
A quick try with Thea, not much time to play unfortunately.
http://www.solos-art.com
solo
Global Moderator
Postby EscapeArtist » Sun Aug 29, 2010 1:28 pm
Would've liked to do more with this, but we have a new kid so it took 5 days to cobble together enough free time to do this much. Modeled in SU, exported to Blender for duplication of the marbles and using physics to pour them in the jar and tray. Rendered in Luxrender.
EscapeArtist
Top SketchUcator
Postby dale » Sun Aug 29, 2010 2:21 pm
EscapeArtist wrote:Would've liked to do more with this, but we have a new kid so it took 5 days to cobble together enough free time to do this much. Modeled in SU, exported to Blender for duplication of the marbles and using physics to pour them in the jar and tray. Rendered in Luxrender.
Hey congratulations on the new one!
dale
Top SketchUcator
Postby charly2008 » Sun Aug 29, 2010 2:44 pm
Testing of different materials I realize again how much our vision in the real world is influenced by the environment.
The result is that you keep aware of things in the hand and studies the different lighting effects and reflections.
Charly
Kerkythea with Basic Glasses and different global enviroments
charly2008
Postby EscapeArtist » Sun Aug 29, 2010 6:15 pm
dale wrote:Hey congratulations on the new one!
Thanks! Took 9 months to render, but turned out pretty good! Just forgot to deselect "fussy" and lower the "gassy" slider before I pushed Start. :roll: :lol:
EscapeArtist
Top SketchUcator
Postby FlapsyD » Mon Aug 30, 2010 8:13 pm
Don't worry: you have about 18 year to do some postpro ... :knockout:
Congrats !
Flapsy
FlapsyD
Postby EscapeArtist » Mon Aug 30, 2010 10:33 pm
LOL, too funny.
EscapeArtist
Top SketchUcator
Postby olishea » Wed Sep 01, 2010 2:50 pm
massimo: is this the wireframe procedural again??! nice....your other render looks like a photo! :shock:
oli
olishea
Premium Member
Premium Member
Postby massimo » Wed Sep 01, 2010 2:52 pm
Yes, again... :lol:
Nice new avatar btw Oli! :D
massimo
Next
Return to Gallery
Users browsing this forum: No registered users and 6 guests
