OMG! fur plugin is AMAZING!
Postby olishea » Thu May 06, 2010 4:54 pm
just download it. we have needed this for a long time.
I will post all my grassy renders here. i got a feeling this plugin is very addictive! Please feel free to share your fur creations here as well! :thumb:
viewtopic.php?f=323&t=28092
rendered with twilights "render all hidden layers". great idea.
sang looks a little ill....quick podium render this time.
each line represents a grass component. twilight can now render the hidden components without slowing down sketchup!! :)
oli
olishea
Premium Member
Premium Member
Re: OMG! fur plugin is AMAZING!
Postby solo » Thu May 06, 2010 4:57 pm
Oli that looks great, how about a grassy hill, something on a large scale. ;)
http://www.solos-art.com
solo
Global Moderator
Postby xrok1 » Thu May 06, 2010 4:58 pm
sang in a gilly. :lol:
“There are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
xrok1
Postby olishea » Thu May 06, 2010 5:03 pm
you read my mind pete. my current scene is 320,000 polygons of grass. lets see how it turns out!
i like how the grass takes on the colour of the surface underneath.
imagine an organic form painted with 'color by z' or 'color by slope' plugin with grass applied oooooooohhhhhh :D
sang in a gilly
guess he'd be shot straight away then!
oli
olishea
Premium Member
Premium Member
Postby xrok1 » Thu May 06, 2010 5:27 pm
have you tried it with ghostcomp? viewtopic.php?f=323&t=21469
xrok1
Postby fymoro » Thu May 06, 2010 5:51 pm
Ho yes, This plugin is really amazing, awesome, thank to tak2hata and Oli.
It is the best Fur displacement that I have done with Vray for SU, and It is not displacement... :D
Oli How can I make it less heavy ? I don't understand the trick Thanks
fymoro
Postby xrok1 » Thu May 06, 2010 6:04 pm
fymoro wrote:I don't understand the trick Thanks
yes, please explain in detail. also i can't get ghostcomp to render the real component, have you been able to. it would be a perfect companion for fur. :D
xrok1
Postby olishea » Thu May 06, 2010 6:22 pm
look at the twilight teapots tutorial....the one with 2000 teapots (i think). it explains it better than me :oops:
1. when the fur plugin gives you the option of "make by" select yes. this will turn each grass blade into a component instead of a large group.
2. edit a grass component. double click or right click>edit component
3. draw a line next to the blade
4. open up the sketchup layers manager (window>layers)
5. create a new layer called 'grass' and make it hidden (just check the hidden box)
6. select the grass blade (by double or triple click)...right click....entity info.....change the layer to 'grass'.
7. the blades of grass should all disappear.....leaving you with the line that you drew in step 3
8. close the component (press escape)
9. right click the component....twilight....render all hidden layers in all components
10. render
you could also just put all the grass on a hidden layer without the little lines. I just replaced the component with lines so i could see where the grass would be.
mate dont credit me! i'm just playing!
oli
olishea
Premium Member
Premium Member
Postby xrok1 » Thu May 06, 2010 6:47 pm
thanks! what about ghostcomp. have you tried that?
xrok1
Postby olishea » Thu May 06, 2010 7:25 pm
yes i have but not on this model. you have to unhide the ghosts before rendering which i didnt want to do. great plugin though!
oli
olishea
Premium Member
Premium Member
Postby xrok1 » Thu May 06, 2010 7:30 pm
makes me wish SU had display states. we could display comps as wireframe. i guess this is what ghostcomp gives us (display states) but isn't quite the same as they are in other progs. :cry:
xrok1
Postby boofredlay » Fri May 07, 2010 3:47 am
I seem to have dropped my bread.
boofredlay
Global Moderator
Postby olishea » Fri May 07, 2010 10:28 am
haha sweet. i think there will be some tasty fur images today!
oli
olishea
Premium Member
Premium Member
Postby pilou » Fri May 07, 2010 11:42 am
A new hit :fro: :thumb:
Speedy Galerie
Top SketchUcator
Postby pilou » Fri May 07, 2010 3:01 pm
Funny indeed! :enlight:
Speedy Galerie
Top SketchUcator
Postby massimo » Fri May 07, 2010 3:24 pm
What about a vintage-looking lamp? ;)
massimo
Postby olishea » Fri May 07, 2010 4:31 pm
wow!!!!!!
so many possibilities for this plugin!
keep posting more furry pictures!! we really needed this for sketchup!
i cant play cos im working but will post more grassy scenes soon!
oli
olishea
Premium Member
Premium Member
Postby fymoro » Fri May 07, 2010 5:56 pm
Wow, Very nice lamp... :thumb: I agree with Oli, "keep posting more furry pictures!!"
Here is a fake ivy...From far in a exterior scene It should work not ? And setup in 2 minutes... :thumb:
fymoro
Postby massimo » Fri May 07, 2010 6:46 pm
Looks good Fred. :)
massimo
Postby Gaieus » Fri May 07, 2010 7:47 pm
Some Furry Grass :)
Postby Frederik » Fri May 07, 2010 8:27 pm
fymoro wrote:Here is a fake ivy...From far in a exterior scene It should work not ? And setup in 2 minutes... :thumb:
:berserk: You just gave me an idea, Fred... :D
(which I find to be an excellent idea, actually...)
Since you can use Components from the scene together with this plug-in, you can take the texture of an Ivy leaf, create a component and "spray" that on the surface...
I have a model, where I need to make a pavilion (or whatever it's called in English) made of metal tubes and where Ivy covers it...
I've been struggling with Ivy Creator, but this can actually do the job... :ecstatic:
Cheers
Kim Frederik
Frederik
Thea Render Support
Thea Render Support
Postby fymoro » Fri May 07, 2010 11:32 pm
Yes Kim, It's great idea. This Plugin is awesome... :thumb:
fymoro
Postby Richard » Sat May 08, 2010 1:55 am
Yep that will do the job and very well!!!
Richard
Postby Frederik » Sat May 08, 2010 9:08 am
With this plug-in, I finally succeeded making my ivy pergola...
I had never dreamed that I would be able to do it inside SU... :sketchstatic:
I used two ivy leaves from the "English Ivy" in Solo's Garden pack 1, made it a component and used the fur plug-in to "distribute" it onto a frame... :)
Cheers
Kim Frederik
Frederik
Thea Render Support
Thea Render Support
Postby fymoro » Sat May 08, 2010 9:59 am
Well done, thanks for the tips Kim... :thumb:
Please can you make a small tuto ? :roll:
fymoro
Postby massimo » Sat May 08, 2010 11:31 am
5 min of work...and raw SU output. Really an amazing plugin :)
massimo
Postby Frederik » Sat May 08, 2010 2:16 pm
fymoro wrote:Please can you make a small tuto ? :roll:
It's really easy, Fred... :)
Like I wrote earlier... In my example, I used the English Ivy from Solo's Garden pack...
1.) I exploded the model and deleted everything except 2 ivy leaves.
2.) Make these two leaves into a component.
3.) Open the Fur setting dialog
4.) You'll need to play around with the settings. My input in the "Density" box was 1000
5.) In the "Make by ComponentInstance" you select the Ivy leaves from the list
6.) Select the surface where you want the leaves to be
7.) Click "Make Fur" button.
Voila...! :D
Cheers
Kim Frederik
Frederik
Thea Render Support
Thea Render Support
Postby fymoro » Sat May 08, 2010 2:20 pm
Wow!! Massimo, very cool !!!
Thanks for the totu Fredy... :thumb:
fymoro
Postby Richard » Sat May 08, 2010 2:27 pm
massimo wrote:5 min of work...and raw SU output. Really an amazing plugin :)
Mate when you look at images like that you wonder why SU cant have a better lighting environment, that would do us! Begone all renders!
Richard
Postby massimo » Sat May 08, 2010 2:37 pm
Glad you like it. :D
Totally agree Richard! :thumb:
massimo
Next
Return to Gallery
