Render this: SSS
Re: Render this: SSS
Postby EarthMover » Wed Nov 11, 2009 8:37 pm
Here's a try with the dragon in vray using an SSS sssnake ssskin material applied to the refraction channel.
And another without the skin bitmap.
Content Creator at Skapeup
EarthMover
Premium Member
Premium Member
Postby solo » Wed Nov 11, 2009 8:41 pm
Nice one Adam.
http://www.solos-art.com
solo
Global Moderator
Postby EarthMover » Wed Nov 11, 2009 8:45 pm
Thanks Pete...I actually cheated a little and used the high poly dragon since it was in Max. Looking at yours...I should've jacked up the specularity a little.
Pete, have you tried using different color lights with a white SSS material? That should be interesting.
EarthMover
Premium Member
Premium Member
Postby solo » Wed Nov 11, 2009 8:58 pm
a quick 30 second render.
solo
Global Moderator
Postby solo » Wed Nov 11, 2009 9:22 pm
Four lights, two red, two white.
I used a bump map.
solo
Global Moderator
Postby EarthMover » Wed Nov 11, 2009 9:40 pm
Wow Pete..the last one is amazing. The bump map really made it pop.
EarthMover
Premium Member
Premium Member
Postby avariant » Wed Nov 11, 2009 9:47 pm
Red rubber ball
avariant
PluginStore Author
PluginStore Author
Postby remus » Wed Nov 11, 2009 10:04 pm
Blue rubber material again.
remus
Postby solo » Wed Nov 11, 2009 10:07 pm
Remus, that's a very convincing looking rubber mat.
solo
Global Moderator
Postby solo » Wed Nov 11, 2009 10:11 pm
This one came out great IMO, it's a waxy type material, the extra back lighting really made it pop.
solo
Global Moderator
Postby jeff hammond » Wed Nov 11, 2009 10:19 pm
ha, i was going for a blue rubber dragon too.. :D
was going to let it cook longer but stopped it after seeing remus'..
dotdotdot
jeff hammond
Global Moderator
Postby EarthMover » Wed Nov 11, 2009 10:21 pm
WOW...these are all amazing. Love the blue rubber Remus (and Jeff). Here's "light side" angle of my previous on a Jade material stand.
EarthMover
Premium Member
Premium Member
Postby remus » Wed Nov 11, 2009 10:28 pm
just downloaded the material form the indigo materials database, so cant take any credit for it ;)
remus
Postby Rich O Brien » Wed Nov 11, 2009 11:07 pm
Twilight User
Here's my problem -
Place model in 'Basic Studio' with Omni Light behind model
Apply SSS material to model (Red Gum)
Sunlight Disabled
Sky Type - Background Color (Black)
Render at Medium+ (Still Cooking after 30mins)
Vista64bit - AMD Turion X2 Dual Core - 4GB
When i cooked at lower presets the model was very dark? Do i need to up light size?
Rich O Brien
Administrator
Postby solo » Wed Nov 11, 2009 11:30 pm
Rich
So far I've only been playing with Vue, I am yet to try Twilight for SSS, I know Miguel (Ecuadorian) has done some tests over at Twilight successfully. I would guess that using Twilight in conjunction with Kerkythea for the advanced material editing that you will get great results.
I will give Twilight a try later and hopefully I can figure it and and if I do I will see if I can help further.
However, try adding another point light behind camera also
solo
Global Moderator
Postby Chris_at_Twilight » Wed Nov 11, 2009 11:33 pm
rclub24 wrote:Twilight User
Here's my problem -
Sunlight Disabled
The Low, Med, High presets, being biased, don't do nearly as good a job at SSS as the unbiased methods. They have to make approximations and assumptions which can turn out quite well sometimes, but with complicated organic shapes you aren't going to get as good of results. At at the really low end, with Low or Low+, you may not actually get any results from SSS and translucency because those are designed for higher speed.
Chris_at_Twilight
Twilight Render
Postby avariant » Wed Nov 11, 2009 11:38 pm
Here's my problem - ...
The red rubber dragon I posted above was done in Twilight. I just used the SSS Rubber Ball right out of the box. It's done with Interior +, so that's probably the difference.
This is Twilight also.
avariant
PluginStore Author
PluginStore Author
Postby EarthMover » Thu Nov 12, 2009 12:09 am
Avariant..iridescent one is fantastic. Really good showing from Twilight.
Last one from me. Added some displacement in the mix.
EarthMover
Premium Member
Premium Member
Postby Ecuadorian » Thu Nov 12, 2009 12:19 am
I just want to print and hang in my walls all renders by Remus, Pete and Adam, they're wonderful!
Ecuadorian
Postby olishea » Thu Nov 12, 2009 12:20 am
earthmover these are fantastic! and yeah remus that blue rubber is amazing!
oli
olishea
Premium Member
Premium Member
Postby Ecuadorian » Thu Nov 12, 2009 1:34 am
A couple of lazy attempts with just Twilight library materials:
Milk:
And blue gum. Indigo and Maxwell beat Twilight big time when it comes to blue gum/rubber. :(
Ecuadorian
Postby dale » Thu Nov 12, 2009 1:38 am
A little from Kerkythea
dale
Top SketchUcator
Postby solo » Thu Nov 12, 2009 1:59 am
My first twilight attempt.
solo
Global Moderator
Postby Rich O Brien » Thu Nov 12, 2009 2:08 am
solo wrote:My first twilight attempt.
I'm sick as a parrot after that one.
What the $@#* am I doing wrong?
I've read the manual, I've followed the tuts. All that's left is to remove the mallet from my ass and beat myself with it
Goodnight
Rich O Brien
Administrator
Postby solo » Thu Nov 12, 2009 2:14 am
Rich, here is my setup, see I have 3 lights behind and one in front, I rendered using preset #9
I used the studio setup, painted black, I have no sun and a black background.
solo
Global Moderator
Postby Click Draw » Thu Nov 12, 2009 2:36 am
Here's my attempt....
Have I mentioned how much of a laugh I get out of some of the Signatures on here!
Click Draw
Postby Click Draw » Thu Nov 12, 2009 2:38 am
looks like I'm a bit behind.....oops :oops: Guess I've been Dragon my ass.... :roflmao:
Click Draw
Postby d12dozr » Thu Nov 12, 2009 2:55 am
Fantastic renders, guys! This is so cool :fro:
Using Twilight, I also had the same problem as Rich, I started using the Low and Medium presets and it was taking forever, but I'm getting much better results after switching to #10 - Interior+ (but not good enough to post here yet)
http://goo.gl/f7ooYh
d12dozr
Top SketchUcator
Postby Ecuadorian » Thu Nov 12, 2009 3:08 am
Twilight Render's Easy 09 preset should be enough; Easy 10 enables color dispersion and some other special FX, however.
I made two more tries: One with Easy 09 and another one with Easy 10. I stacked them together:
And then added some airbrush to the eyes and altered the curves a little bit in GIMP:
Hey, Pete, how about "Emitters and LEMs" for the next "Render this"?
Ecuadorian
Postby woodtick » Thu Nov 12, 2009 3:28 am
Very interesting thread........thanks for starting this.I've just started working with Twilight and rendering in general.Keep in mind I'm a carpenter, not a graphic artist so any breach of rendering etiquette is purely unintentional. This is what I came up with....not sure it meets any of the sss criteria but it sure was fun trying.
Rich
woodtick
PreviousNext
Return to Gallery
cron
