Tank Museum UPDATE - new renders
Re: Tank Museum
Postby Paul Russam » Wed Mar 11, 2009 11:01 am
Its one I made by combining 2 that were in the Style Builder Competition Winners set and tweaking the settings a little. All credit to the original authors.
Both Image 3 and 4 are the same style but with different face styles (Hiddenline, Shaded, Monochrome etc) and 'Use sun for shading' switched on or off.
To be honest I cant remember the exact combination :oops: but you get the idea. :)
I've attached the mashed style.
Paul Russam
English doesn't borrow from other languages. It follows them down dark allies, knocks them over, and goes through their pockets for loose grammar.
Paul Russam
Premium Member
Premium Member
Re: Tank Museum
Postby Huggkruka » Wed Mar 11, 2009 5:53 pm
The threads are so perfect it's making me nervous! Amazingly well done.
Huggkruka
Re: Tank Museum
Postby shareck » Thu Mar 12, 2009 12:07 am
Hi All. The King Tiger is nearly finished. I'm posting a quick render from kerkythea. i'll be trying to put some textures on it later.
the render came out too bright and the reflection shouldn't really be there but i've no patience to run it again.
shareck
Re: Tank Museum
Postby david_h » Thu Mar 12, 2009 12:26 am
:thumb: :thumb: :thumb: :thumb: :sketchstatic:
If I make it look easy. . .then it probably is.
david_h
Top SketchUcator
Re: Tank Museum
Postby paul j » Thu Mar 12, 2009 11:46 am
Thanks Paul for posting your style - just downloaded it and will give it a go shortly.
A bit of experimenting and hopefully get the same effect
Thanks again
paul j
Re: Tank Museum
Postby tomislavm » Thu Mar 12, 2009 1:55 pm
Only one word Respect!
This is the best collection I have ever seen, beautiful!
tomislavm
Re: Tank Museum
Postby shareck » Thu Mar 12, 2009 3:12 pm
The texturing of King Tiger has started. Here's a sneak preview of what its going to be.
shareck
Re: Tank Museum
Postby Phil Rader, AIA » Thu Mar 12, 2009 5:56 pm
Speechless...these tanks are awesome. Sketchup and the talents of it's users never ceases to amaze me.
Phil Rader, AIA
Premium Member
Premium Member
Re: Tank Museum
Postby remus » Thu Mar 12, 2009 7:03 pm
A quick clay render of the ford 3 ton:
Im a sucker for clay renders of good models.
remus
Re: Tank Museum
Postby Bryan K » Fri Mar 13, 2009 5:09 am
Uh...uh.... :o
Re: Tank Museum
Postby shareck » Fri Mar 13, 2009 3:15 pm
The King Tiger is now textured completely. I will post some renders later. For the moment have a look at partially finished model rendered in kerkythea. The bump map needs a lot of tweaking cos it looks crappy.
shareck
Re: Tank Museum
Postby tomislavm » Sun Mar 15, 2009 11:24 am
How did You made this texture!
tomislavm
Re: Tank Museum
Postby shareck » Sun Mar 15, 2009 3:35 pm
Hello again. Thanks for the kind words. The texture for king tiger i painted in photoshop. I used the right RAL colours that has been used on these panzers from 1944. Paintbrushed green and red/brown patches over the dark yellow base. Then added some darkening where needed and lots of dirt using some dirt brushes found on deviantart. i made texture for left side, right side, top of the hull, top of the turret, rear of the tank, front of it, bottom hull sides, bottom of the tank and the gun barrel. These textures were projected on to apropriate parts of the tank. the most dificult part was to match the top texture to the side texture. I'm gonna make these proper renders soon but for now you can see some SU renders :)
shareck
Re: Tank Museum
Postby oalexis » Sun Mar 15, 2009 8:56 pm
really nice texturing
oalexis
Re: Tank Museum
Postby Teezer » Sun Mar 15, 2009 9:22 pm
You're a man with a lot of patience and an eye for detail, sir. I salute you!
Real life is just another website, albeit a rather boring one.
Teezer
Re: Tank Museum
Postby silver_shadow » Mon Mar 16, 2009 5:53 am
looks like i'm back in the production line of comments again (been a bit busy). First things first, great job on the models (10 stars), you really got a sharp eye for detail. Seems like you are starting your own virtual war hee hee. I always wanted to build a tank, even if it was only a plastic model.Now one can be inspired by these models if they want to build a tank one day and use these as reference images. This is truly inspiring to those who think Sketchup is still a light weight box building tool only to be used for Google earth. I see more and more heavy duty artists creep out of their shell and show off the capabilities of Sketchup. IDEA: You should build a scene, where a tank stands in the debris, ruined buildings and lots of loose and blown up stuff lying around. Could be really fun. But again, well done, it is truly something beautiful to look at.
silver_shadow
Re: Tank Museum
Postby tomislavm » Mon Mar 16, 2009 8:56 am
Me again!
How big texture You use?
How big tank model is?
Thanks!
tomislavm
Re: Tank Museum
Postby shareck » Mon Mar 16, 2009 7:18 pm
texture size ranged from 1200 pixels wide to 2400 pixels wide. the model without textures with copied components weights 7mb. with the textures and many of the components exploded its 26 mb.
shareck
Re: Tank Museum
Postby edmund » Mon Mar 16, 2009 8:33 pm
Opened and just hit the render button using Podium.
edmund
Re: Tank Museum
Postby free agent » Mon Mar 16, 2009 9:54 pm
amazing amazing amazing, dont know why i didnt click on this thread sooner, i want to see a hardcore scene with that Panzer that Silvershadow was talking about... brilliant :thumb:
free agent
Re: Tank Museum
Postby rombout » Wed Mar 18, 2009 3:52 am
shareck wrote:Thanks for all the comments.
The lowest poly model here would be the T-34 with 290175 edges and 113783 faces. I was aiming at small file size which is only 2,8mb. The king tiger so far has 850214 edges and 338435 faces.
It's not difficult to make these track links. Each link is quite simple in shape and than you just need to copy it along a path.
I only use standard SU tools. Only plugins i have installed are Sketchyphysics and Kerkythea exporter. The only plugin i'd wish to use is subdivide&smooth by smustard.
All these models are done by me just as a hobby. I'm not a military enthusiast, i was just learning sketchup and i couldn't find an interesting topic. I came across some tank model in the 3d warehouse and wanted to do a tank myself. Before i finished my first one i already knew that i'll be doing another one. I find some strange joy in these machines.
If anyone wants to use these models for rendering, animations, texturing or anything they're in the 3d warehouse (all except KV1 and King Tiger). Just search for the tag "shareck".
There is only one pic of Abrams in the first post so i'm posting some more below:
how in gods name did you made those surfaces without any plugin... thats hardly undo able
rombout
Re: Tank Museum
Postby tomislavm » Wed Mar 18, 2009 9:06 am
What computer did You have for that big model?
tomislavm
Re: Tank Museum
Postby shareck » Wed Mar 18, 2009 9:23 am
Well. The only surfaces that are hard to make without any plugin would be the shapes of the cast turrets (t-34, t-62, sherman). Those are kinda organic shapes that cannot be done with the follow me tool and this is why they're either low poly or non accurate. Everything else is quite easy to achieve. It's mostly straight lines and "follow me".
I'm not working in design studio or anything like that so my computer at work is a simple, dated office pc - P4, integrated video card, 480mb RAM :). So you can see that i must have some patience. At home it's not much better. Still pentium4, 2gb ram and a proper graphic card. But i'm ok with that as long as i hide the layers i'm not working on.
shareck
Re: Tank Museum
Postby kilgo » Sun Mar 22, 2009 4:04 am
I did these renders a while back, I got the SKP model from the warehouse, did you make this or was it someone else?
kilgo
Re: Tank Museum
Postby kilgo » Sun Mar 22, 2009 4:05 am
Heres the other one.
kilgo
Re: Tank Museum
Postby tgb57781 » Sun Mar 22, 2009 7:00 am
Great job!
Amazing
It must be perfect after been rendered. :thumb:
I am Chinese. I am Richen. ;)
tgb57781
Re: Tank Museum
Postby shareck » Sun Mar 22, 2009 12:33 pm
It's a Jagdpanther and it's not mine.
shareck
Re: Tank Museum
Postby shareck » Sun Mar 22, 2009 12:45 pm
I've been trying to render some of these tanks. I'm using Kerkythea and still have a lot to learn. Have a look at some renders of KV-1 in a warehouse i've made. I'm still not happy about the light and shadows. Also the warehouse needs some dirtied textures, the current ones are from sketchup.
Any tips on kerkythea settings?
shareck
Re: Tank Museum
Postby Marian » Sun Mar 22, 2009 1:25 pm
AWESOME tanks dude, AWESOME
Marian
Re: Tank Museum
Postby shareck » Thu Jul 16, 2009 11:41 pm
Some renders from last months. Still learning Kerkythea and texturing.
Challenger II late sunset render.
King Tiger.
King tiger textured (metropolis light transport, not more than 6 passes)
King Tiger - photon map
KV-1
T-34 scene WIP. this is a scene with 2 t34 tanks. the tanks are low poly SKETCHYPHYSICS tanks i've done some time ago. I got them to ride over some bricks and then i started modeling the destroyed buildings.
Panther tank
Panzer 4
shareck
PreviousNext
Return to Gallery
