Where have all the textures gone?
Postby Roger » Fri Mar 28, 2008 5:36 pm
I have lost the textures in one of my KT renders.
As a check on what was happening I then made another render of just a rectangle with one of the textures applied. It worked fine. Then I opened the xml on both files and looked for glaring errors such as different paths or differences in the texture name. Nothing jumped out at me as being incorrect. I hate to go back and try to rebuild the whole project.
Has anyone experienced the problem or does anyone have ideas on why this would happen?
Roger
Re: Where have all the textures gone?
Postby Frederik » Fri Mar 28, 2008 10:48 pm
Hi Roger,
I suggest that you simply put your XML-file in the same folder as your textures... This will ensure that KT will find them... ;)
Did you re-export your model - or part of it - and then use the "merge" tool..?? :?
It seem as if you've exported this scene with the Export default UVs set to "YES"...
If this is the case I suggst that you re-export again with "No" instead...
Cheers
Kim Frederik
Frederik
Thea Render Support
Thea Render Support
Return to Extensions & Applications Discussions
