FREDOSCALE NOT WORKING
Hi I am having problems with FREDOSCALE.
Once I have box scaled the following to 0, I can't edit the groups. If you select them, they are randomly positioned in the space or I just can't select them in the first place.
I am on the latest version.
Normally, you should not use a scale of 0 with FredoScale. It would likely create undesirable side effects as this seems to be your case.
Thanks Fredo.
It was a technique that was on the Sketchup Essentials Fredo Scale video. I will drop him a comment.
I use box stretching to target often. It suddenly stopped working. green arrow appears but none of the other indicators appear and nothing is clickable in the selected group. Any advice to resolve this?
We'll need more detail to understand what happens, may be the model, screenshots, ....
