[Plugin] MultiTags for Sketchup
Would you like to list it on our repo?
https://sketchucation.com/pluginstore
It will also get added to our Sketchucation Tools so users can access it in SketchUp too.
Let me know
wow, been looooong waiting for this feature
I was trying this plugin with SketchUp 2022 on macOS 12.5.1 with Apple M1 max chipset.
When I click the toolbar button of MultiTags, a window pops up.
However, the pop up window is tiny, very tiny that doesn't show even a word.
And I can not adjust the size of the window.
And I can not adjust the size of the window.[attachment=0:10c1m068]<!-- ia0 -->截屏2022-09-10 12.41.42.png<!-- ia0 -->[/attachment:10c1m068]
Thanks for issue, i'm investivating a problem
1.1.221216
- added support negative expression using exclamation mark symbol “!” in forumulas
Download from Plugin Store
In what cases can it be useful to use negation in formulas:
- Hide obviously hidden elements, for example, electrical boxes hidden behind plaster. And the reverse operation: show these objects when the “Plaster” layer is turned off.
This gives a significant increase in model rendering and increases your productivity,
since these objects are not drawn when they are not needed without necessary additional clicks to layers to hide this objects.
- Switch with one button/tag between the degree of used mesh details of the model.
Often high details mesh is required only when we start photo rendering and in normal model editing, high details mesh is not needed, and reduce 3d mesh details gives a significant increase in rendering speed in Sketchup (FPS). Now we can switch using one click
I've been trying to purchase a license, but the pay company for your cart has failed on two different accounts. Is there a way to Venmo, or transfer you payment for a license other than through the cart, or worst case scenario, send another trial license until the cart is fixed and I can properly support your endeavors?
@joshtays said:
Hi joshtays,
I'm answered to your question into PM -
Hallo, I tried your plugin, but I get white empty dialog box.
Windows 10 + Sketchup version 2021.0.339
And in Sketchup 2020 dont get nothing dialog box. After restart I get thisr errors:
Error: #<NoMethodError: undefined method
each_folder' for #<Sketchup::Layers:0x0000021a38918260>> (eval):758:in
GetLayerListEx'
(eval):764:inGetLayerList' (eval):333:in
refresh'
(eval):219:ininitialize' (eval):1341:in
new'
(eval):1341:ininitialize' c:/users/fero/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/zzlab_multitagplugin/plugin.rbe:69:in
new'
c:/users/fero/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/zzlab_multitagplugin/plugin.rbe:69:inmain' c:/users/fero/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/zzlab_multitagplugin/plugin.rbe:85:in
class:Plugin'
c:/users/fero/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/zzlab_multitagplugin/plugin.rbe:6:in<module:MultiTagPlugin>' c:/users/fero/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/zzlab_multitagplugin/plugin.rbe:5:in
module:ZZLab'
c:/users/fero/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/zzlab_multitagplugin/plugin.rbe:4:in<main>' C:/Program Files/SketchUp/SketchUp 2020/Tools/extensions.rb:197:in
eval'
C:/Program Files/SketchUp/SketchUp 2020/Tools/extensions.rb:197:inrequire' C:/Program Files/SketchUp/SketchUp 2020/Tools/extensions.rb:197:in
load'
C:/Users/fero/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/ZZLab_MultiTagPlugin.rb:26:inregister_extension' C:/Users/fero/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/ZZLab_MultiTagPlugin.rb:26:in
module:ZZLab'
C:/Users/fero/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/ZZLab_MultiTagPlugin.rb:5:in `<top (required)>' -
Layers folders were introduced into SketchUp and the API in v2021, so trying to use this extension in v2020 won't work !
The author could include a Sketchup version check as the code loads, to tell you it's not compatible with your older version...
It's quite straightforward to do and a kinder way of coding... -
release 1.1.230903:
added command to menu for reload visibility state,
which can be broken in some cases (for sample: component reloaded from file) -
automatic updating of the visibility on all scenes when their visibility changes
fix updating of the visibility on the Scenes: the status of object hiding changed to set via Hidden.
Also stop use technical tag “Multitag Hidden” which was used to hide objects in earlier releases.
[anchor= goto=https://zzlab-xs.com/downloads/MultiTag-1.1.230903.rbz:3m0vt35m]Download MultiTag-1.1.230903.rbz[/anchor:3m0vt35m]
