MULTITAG EXTENSION FOR SKETCHUP
The extension allow assign several tags/layers to group/component. And get flexible control to object visibility on complex models, such as houses, apartments with large engineering networks (water supply, electricity, etc.)
By default all selected tags use AND condition: so object will displayed only if all tags are enabled;
Extension also allow use OR condition between layers, grouping and combination AND and OR conditions
For sample: Each wall in house can be assigned at least to two layers "room1" and "room2" and be visible when one of "room" tags enabled or Furniture can belong to both tags "room" and "type", for example "Chair" or "Table" and are displayed only when both layers are active
Download from Plugin Store
[Plugin] MultiTags for Sketchup
• Page 1 of 1
[Plugin] MultiTags for SketchupLast edited by ezyuzin on Thu Sep 08, 2022 4:13 pm, edited 2 times in total.
Re: [Plugin] MultiTags for SketchupWould you like to list it on our repo?
https://sketchucation.com/pluginstore It will also get added to our Sketchucation Tools so users can access it in SketchUp too. Let me know ![]()
Re: [Plugin] MultiTags for SketchupI was trying this plugin with SketchUp 2022 on macOS 12.5.1 with Apple M1 max chipset.
When I click the toolbar button of MultiTags, a window pops up. However, the pop up window is tiny, very tiny that doesn't show even a word. And I can not adjust the size of the window. Re: [Plugin] MultiTags for Sketchup
fixed
Re: [Plugin] MultiTags for Sketchup[Update]
1.1.221216 - added support negative expression using exclamation mark symbol “!” in forumulas Download from Plugin Store
Re: [Plugin] MultiTags for SketchupIn what cases can it be useful to use negation in formulas:
1. Hide obviously hidden elements, for example, electrical boxes hidden behind plaster. And the reverse operation: show these objects when the “Plaster” layer is turned off. This gives a significant increase in model rendering and increases your productivity, since these objects are not drawn when they are not needed without necessary additional clicks to layers to hide this objects. In addition, eliminates rendering defects in Sketchup with appearing edges, which is non aesthetically pleasing when editing, and irritated these strange edges that appearing when the model is moved away. 2. Switch with one button/tag between the degree of used mesh details of the model. Often high details mesh is required only when we start photo rendering and in normal model editing, high details mesh is not needed, and reduce 3d mesh details gives a significant increase in rendering speed in Sketchup (FPS). Now we can switch using one click
Re: [Plugin] MultiTags for SketchupHi,
I've been trying to purchase a license, but the pay company for your cart has failed on two different accounts. Is there a way to Venmo, or transfer you payment for a license other than through the cart, or worst case scenario, send another trial license until the cart is fixed and I can properly support your endeavors? Re: [Plugin] MultiTags for Sketchup
Hi joshtays, I'm answered to your question into PM
• Page 1 of 1
Users browsing this forum: SHAZAM538 and 5 guests
