RBZ install not working through ExtensionStore
Good Afternoon all,
I'm getting the 0 size RBZ download error for the extension store plugin on both of my win 10 computers with Sketchup make 17 installed on both.
using v4.2.3
Console output:
SCF::TEMPDIR C:/Users/Steven/AppData/Local/Temp/SCF RBZtool::GOT_OPEN_URI true RBZtool::GOT_RUBYZIP true SCF::TEMPDIR C:/Users/Steven/AppData/Local/Temp/SCF
I see the file come into temp/SCF folder, but with 0K size. Resulting in the UnZip Error message
IE is not installed on these computers
I am able to install RBZ if I download and use Sketchup's built-in Extension Manager.
Note: There are two locations I can install to, If I use the one associated with my user name ../appdata/Roaming/.. folder it uses the ../temp/SCF folder for the initial download. if I try to install to the c:/ProgramData/.. folder, it does not seem to use the /SCF folder... as I never see it there.
thanks,
Steve -
Can you clear your Microsoft Edge browser cache?
All installs fail or certain ones?
Something about your set up is preventing the effective download of the RBZ into its temp-folder.
Do you have a firewall ?
Are any of its settings likely to prevent 'sketchucation' [or plugins?] linked URLs from downloading etc ?Over the months we have had some rare reports of this happening, but are still searching for a cause...
@rich o brien said:
All installs I have tried fail, (including ExtensionStore )
I cleared all browser Caches, no love...
About a year ago, I was having this issue on one of my computers, but was able to get it working again for the C:/Programdata?... folder but not the user local folder making me think permissions issue, but have played with that a little with no luck... (Unfortunately I cannot remember what I did before)
On the second computer it was installed a few weeks ago and worked fine up until a few days ago (I did get a windows update in that time frame though.
Reviewing the firewall... I'm not really seeing any settings that would cause suspicion for me, any thoughts on settings that might block a download? Anyway I turned it off for testing, and no difference seen.
A folder permission issue is possible, BUT we see that the downloaded RBZ is getting created in ../Temp/SCF subfolder but its contents are not written.
Seems to me something is preventing the URL data from arriving...
Please copy/paste this code into your Internet Explorer [Edge] web-browser bar and report what happens...
https://pluginstore.sketchucation.com/pluginserv_4.php?hwid=DESKTOP-FF79A08:21&c=ntxMmAO2R7gcBFz6NbKPAzA7HheR8MKz8ILtSlzyreb7sYBJAZkKXxQnf7HlTfkdy9aSxZRoC6z9f0RotFCECg6rmM&v=5.0&z=PurgeAll.rbz
The file was downloaded into my download folder.
I did see an interesting thing though, when I ran it through Chrome. It reports "https://pluginstore.sketchucation.com/" as insecure but it allowed the download too.
maybe a certificate issue.
Thanks for these reports...
So we know it's downloading from a URL OK.
Can you copy/paste all of this into the Ruby Console.
Report any error messages and if the RBZ in the ../Temp/SCF folder is > 0kb !url = "https://pluginstore.sketchucation.com/pluginserv_4.php?hwid=DESKTOP-FF79A08:21&c=ntxMmAO2R7gcBFz6NbKPAzA7HheR8MKz8ILtSlzyreb7sYBJAZkKXxQnf7HlTfkdy9aSxZRoC6z9f0RotFCECg6rmM&v=5.0&z=PurgeAll.rbz" path = File.join(SCF::TEMPDIR, "PurgeAll_v5.0.rbz") p RBZtool::GOT_OPEN_URI File.open(path, "wb"){|f| URI.open(url, "rb"){|r| f.write(r.read) } }
Open the ../Temp/SCF folder and see if the downloaded RBZ is there - should be ~3kb
Report any error messages and if the RBZ in the ../Temp/SCF folder is > 0kb !> url = "https://pluginstore.sketchucation.com/pluginserv_4.php?hwid=DESKTOP-FF79A08:21&c=ntxMmAO2R7gcBFz6NbKPAzA7HheR8MKz8ILtSlzyreb7sYBJAZkKXxQnf7HlTfkdy9aSxZRoC6z9f0RotFCECg6rmM&v=5.0&z=PurgeAll.rbz" > path = File.join(SCF::TEMPDIR, "PurgeAll_v5.0.rbz") > p RBZtool::GOT_OPEN_URI > File.open(path, "wb"){|f| > URI.open(url, "rb"){|r| f.write(r.read) } > } >
this is what is returned on both machines:
true Error: #<NoMethodError: private method `open' called for URI:Module> <main>:4:in `block in <main>' <main>:3:in `open' <main>:3:in `<main>' SketchUp:1:in `eval'
yes 0K file in folder
V17 uses Ruby 2.2.4. is the 'open' Method part of URI Class then?
YooHoo, this worked:
url = URI.parse("https://pluginstore.sketchucation.com/pluginserv_4.php?hwid=DESKTOP-FF79A08:21&c=ntxMmAO2R7gcBFz6NbKPAzA7HheR8MKz8ILtSlzyreb7sYBJAZkKXxQnf7HlTfkdy9aSxZRoC6z9f0RotFCECg6rmM&v=5.0&z=PurgeAll.rbz") path = File.join(SCF::TEMPDIR, "PurgeAll_v5.0.rbz") p RBZtool::GOT_OPEN_URI File.open(path, "wb"){|f| url.open {|r| f.write(r.read) } } true 2794
Thanks for your testing and ideas...
I'll look at what I can do to make v2017 compatible again...
PS:
Found the issue [also with v2018!] will recompile a new version and publish it asap... -
v4.2.4 is now available through the PluginStore / ExtensionStore³
https://sketchucation.com/pluginstore?pln=SketchUcationTools
It fixes the UNzip error when installing RBZ files in v2017/18... -
@tig said:
v4.2.4 is now available through the PluginStore ...
It fixes the UNzip error when installing RBZ files in v2017/18...Back in business! (was also able to manage the new Fredo licensing too.)
Thanks so much Tig for your tireless service to the Sketchup community.
(I still use the Octane Loader plugin you created some time ago - best tool to get an OBJ file out. )
Steve
