I Can not get Fredo Joint push pull to work. I have uninstalled the extensions, the LibFredo tools, reinstalled the the extensions and then when that didn't work, I uninstalled SU 2019 and installed SU 2020 and reinstalled all new extensions.. It still wont work. When I click any of the options to use any of the push pull tools, nothing happens.
I have the following Fredo tools extensions installted.
fredoTools_v4.2e.rbz
Libfredo6_v12.4a.rbz
Jointpushpull_v4,4e.rbz
Curviloft_v1.8a.rbz
RoundCorner_v3.3a.rbz
TopoShaper_v2.6a.rbz
None of the Fredo Extensions are working on this computer. Anyone know what the problem could be? TIA.
Joint Push Pull will not work. Uninstalled and reinstalled.
• Page 1 of 1
Re: Joint Push Pull will not work. Uninstalled and reinstalYou might have a permissions issue...
First close SketchUp and [re]run its installer's exe file [usually in your Downloads]. Right-click on that exe and choose 'Run as administrator'... When prompted choose 'Repair'. Now SketchUp's permissions will be set right. If permissions were wrong the first time you ran one of Fredo's tools then its preferences right be corrupted or otherwise unobtainable. To fix this find the following folder and delete it [along with all of its files and subfolders]. C:\Users\YOURUSERNAME\AppData\Local\LIBFREDO6_DATA_Dir It's hidden by default, but it can be found... When SketchUp next runs and you use one of Fredo's tools everything should now be recreated with good permissions. TIG
Re: Joint Push Pull will not work. Uninstalled and reinstalI followed TIG's suggestions but unfortunately Joinnt PP still doesn't work. So too Fredo Scale.
Can you share more details? Error messages, Ruby Console output, SketchUp version if different than your profile....
Re: Joint Push Pull will not work. Uninstalled and reinstalIgnoring the original post and Tigs reply, it is a few months since the OP posted and at some point after that Fredo's JPP became a commercial plugin, so have you bought a license?
• Page 1 of 1
Users browsing this forum: nasaw and 2 guests
