Plugins/Extensions Slowing down Skp
Postby Kgon » Mon Sep 09, 2019 10:06 pm
Hi There guys !
....As title says, the fact is that i've suddenly experienced considerable delays in getting my Sketchup to open as quickly as it normally did. This is with new files, completely empty files and i'm not sure what can cause it.
I usually work with many plugins / extensions that loads when starting Skp, but now i installed some more at the same time (I don't remember which ones, that's the problem :? ) and my Skp has already slowed down ... so my question is ... Is there any way to detect which plugin / extension is taking longer to load?
Thank you in advance for your help :D
Kgon
Re: Plugins/Extensions Slowing down Skp
Postby TIG » Mon Sep 09, 2019 10:44 pm
Complex Extensions and licensed ones will take longer to load.
So anything doing Rendering is an obvious suspect.
Others which have license-checking - e.g. Estimator - might also impose a delay.
Have you installed the SketchUcation Toolset?
https://sketchucation.com/pluginstore?p ... ationTools
It includes several useful tools...
You can use its "Plugin Manager" to disable sets of loader files and see which are causing the issue.
You can of course just slim-down your loading files so that only those you regularly use are loading at start up !
User avatar
Global Moderator
Postby Kgon » Sun Sep 15, 2019 1:00 am
TIG wrote:Complex Extensions and licensed ones will take longer to load.
Thx for the feedback TIG , :knockout:
I'm gonna give it a try right now !. To wait long for SketchUp to opens is kinda frustrating! :roll:
Kgon
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to Extensions & Applications Discussions
Who is online
Users browsing this forum: Bing [Bot] and 2 guests
Visit our sponsors:
