How to create this in Profile builder 3
Postby solo » Wed Sep 04, 2019 6:32 pm
I would normally just model this if it was a small section, but I need 2 miles of cartoon fencing which will be on a very organic terrain, Profile builder is the best for this I assume, but I cannot seem to get my head around how to do this.
This is what I want it to look like, I need more variety than just 2 uprights, almost if the uprights can be randomized.
http://www.solos-art.com
solo
Global Moderator
Re: How to create this in Profile builder 3
Postby pilou » Wed Sep 04, 2019 6:55 pm
I will made that with groups (components) of 2 or 3 spans (because you have some "inclined" posts between them )
then at the end when all is done use the genious random component replacement by Sdmitch! ;)
Of course you must draw some few different modules variations but it's not a big deal :)
Speedy Galerie
Top SketchUcator
Postby Whaat » Mon Sep 09, 2019 11:30 pm
You should create a PB3 assembly that uses one part for the posts (component) and another component-type span part for the rails. Then, try using the above-mentioned random component replacer plugin to swap the posts for randomized versions and the rail components as randomized versions.
Whaat
PluginStore Author
PluginStore Author
Return to Extensions & Applications Discussions
