Exporting standard views into JPG-Files
Postby sting2318 » Wed Jul 17, 2019 7:46 am
I want to do this:
I want but to export the six standard views into jpgs-files.
This views are the wellkown ISO, FRONT, BEHIND, TOP, RIGHT, LEFT
Before saving each view it should make a SHOW ALL so that the complete model is visible.
The directory should be the same as SKP-directory.
I need a one-click solution or a ruby file (second best solution) that I can execute in the console.
How can I achieve this?
Any idea or solution?
Thank you in advance.
sting2318
Re: Exporting standard views into JPG-Files
Postby juju » Wed Jul 17, 2019 1:18 pm
juju
Premium Member
Premium Member
Postby sting2318 » Thu Jul 18, 2019 7:51 am
Thank you for the hint; I checked this toll but it first of all requires the manual creation of views!
What I want is a one click solution or ruby script that saves the 6 standard views into 6 jpg-files.
sting2318
Postby juju » Thu Jul 18, 2019 3:12 pm
sting2318 wrote:Thank you for the hint; I checked this toll but it first of all requires the manual creation of views!
AFAIK you will always have to create / define views, how else will SU know where it is supposed to point?
juju
Premium Member
Premium Member
Postby sting2318 » Thu Jul 18, 2019 3:27 pm
You are right of course, views are required.
From my point of view, the script can automatically generate the 6 required views, then export the JPG files.
It should just be done within acouple of seconds with a single command, means without running through the commands manually.
I think this is not a big issue for a ruby-developer knowing the API-calls.
sting2318
Postby sting2318 » Thu Jul 18, 2019 3:29 pm
I therefore offer the first programmer who programmed this script 50 USD, via Paypal or bank transfer!
Who is willing an able to build this?
sting2318
Return to Extensions & Applications Discussions
