Twilight - Invisible but cast shadow?
Postby Shanta » Wed Jun 12, 2019 4:23 pm
Does anyone know of a way to render a material so that it is absolutely clear but still casts a shadow? I am trying to do a light study of a whole house in a dollhouse view (looking down with roof and ceilings removed) so that I can see the light only from windows and doors. But, of course, all the light pours in from the missing roof. I need someway to block the light that the roof would, but not obscure my view of the interior. I'd like to use high quality renderers.
Shanta
Re: Twilight - Invisible but cast shadow?
Postby Box » Wed Jun 12, 2019 4:31 pm
How about using a section plane.
Postby TIG » Wed Jun 12, 2019 4:34 pm
Use this.
TransparentDummy.skm
Global Moderator
Postby Shanta » Wed Jun 12, 2019 4:42 pm
Box wrote:How about using a section plane.
Nope, light enters through the section.
Shanta
Postby Shanta » Wed Jun 12, 2019 5:18 pm
TIG wrote:Use this.
This works great in SU, but Twilight does not render the shadow. Thanks, though.
Shanta
Postby TIG » Wed Jun 12, 2019 5:45 pm
Have you tried adjusting the equivalent Twilight Material ?
Global Moderator
Postby baz » Thu Jun 13, 2019 2:52 am
Possibly render with the 'Sun' off. And use emitters in the doors and windows. (In Twilight anyway).
I am both an early bird and a night owl, I am some form of permanently energized dragon.
baz
Postby TIG » Thu Jun 13, 2019 1:02 pm
The way the material works in SketchUp is that its texture is a 100% transparent PNG texture, but the material is set to be 100% opaque: that way you can see through it but it casts a shadow.
The equivalent Twilight material that gets substituted needs the same setup...
Global Moderator
Postby Shanta » Fri Jun 14, 2019 3:31 pm
I guess I'm still missing something. I've tried with the alpha at 0% and 100%, neither produces a shadow in Twilight. The template is "flat", should I start with something else? Advanced pane has Casts Shadows and Blended Clip turned on. Any help appreciated.
Shanta
Postby tuna1957 » Fri Jun 14, 2019 4:27 pm
Follow the link... it might be of help. Really suggest posting your question on the Twilight Forum. If it's doable Chris or Fletch should know.https://www.twilightrender.com/phpBB3/v ... 107#p24290
tuna1957
Premium Member
Premium Member
Return to Extensions & Applications Discussions
Users browsing this forum: No registered users and 8 guests
