Extrude a hollow solid using Curviloft
Postby Arbix » Mon Apr 08, 2019 10:20 pm
Does anyone know a trick/plugin to extrude a hollow irregular surface? Looking at the attached photo, you can see i'm trying to create a lattice from a circle to an irregular square'ish solid but leave the center hollow (as you can see by the frame). The best way I've found is using Curviloft but as you can see from the image on the left, it doesn't respect my frame and just fills the whole thing.
Any help is appreciated.
Thanks,
Arbix
Arbix
Re: Extrude a hollow solid using Curviloft
Postby pbacot » Tue Apr 09, 2019 12:29 am
A separate path for each outline?
MacOSX Mojave High Sierra SketchUp Pro v19 Twilight v2 Thea v2 PowerCADD
User avatar
Top SketchUcator
Postby kaas » Tue Apr 09, 2019 6:40 am
I always try to make it easy on the plugin and make it into separate lofts. One for the inside, one for the outside and seperate caps. Finally, add them all to a new group and explode the lofts. Doing so is also more easy tracking down bugs.
kaas
Postby Arbix » Tue Apr 09, 2019 3:50 pm
I think I follow what your saying... skin the inner frame, skin the outer frame, then add caps to both sides. I'll play with that some more. Should adding the caps make it a solid?
Thanks again,
Arbix
Arbix
Postby pbacot » Tue Apr 09, 2019 5:41 pm
Worked for me. I just had to trace an edge or two over the original outlines for the faces to form. Made a group and it was solid. You might have to add lines to get a face-- maybe Curviloft tweaks the original outlines just enough to make non-planar.
User avatar
Top SketchUcator
Postby Arbix » Tue Apr 09, 2019 5:52 pm
Thank you so much. I'll play with it more tonight.
Arbix
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to Extensions & Applications Discussions
Who is online
Users browsing this forum: No registered users and 2 guests
Visit our sponsors:
