Hello,
Last week, out of nowhere, all of my fredo plugins (round corner, tools on surface, fredoscale, etc) stopped working. The toolbars are visible but nothing works when I click on the icons to start using the plugins. I have been workingn with our IT company to come up with a solution, but we have not had success...We uninstalled and re-installed sketchup 2016 and 2018 several times, as well as, all of the plugins. We rolled back a windows update to a time last week when these were still working and it still did not work. I have been using these plugins for years and never seen this sort of problem. I have been working in 2016 (havent had the chance to update all of my plugins to be able to migrate to 2018), but when I noticed the problem in 2016, I decided to upgrade everything to 2018 and still had the same problem. These tools are essential to my workflow and I am at a loss at this point.
I have all of the proper plugin updates and the toolbars are there, but they just dont seem to want to activate when I click on them. If there is anyone else that has had this problem and that could suggest a potential solution, please let me know...I will be extremely grateful. Thank you in advance for any help.
Best,
Adam
Fredo Plugins Not Working...Please Help!
• Page 1 of 1
Re: Fredo Plugins Not Working...Please Help!Hello,
one year later... I have the same problem. Did you get it fixed? I would appreciate any help. I'm desperate. Re: Fredo Plugins Not Working...Please Help!Please list the Fredo Plugins that don't work as you expect.
Have you also installed the latest LibFredo ? Remember that it is needed for almost all of Fredo's tools to work properly. Have you restarted SketchUp to ensure everything you've installed gets synced properly ? If you try to use any of these Fredo tools with the Ruby Console open do you see any error messages ?? TIG
Re: Fredo Plugins Not Working...Please Help!Hello TIG,I solved! Thanks for your help!
Looking at the Ruby Console I could see the problem and solve it by following these other forum posts: viewtopic.php?f=323&t=20485&start=675 viewtopic.php?f=323&t=61213 This was the error message from Ruby Console on my desktop: Error: #<Errno::EACCES: Permission denied @ rb_sysopen - C:/Users/PcCom/AppData/Local/LIBFREDO6_DATA_Dir/LibFredo6_all_defaults.dat> ... ... I change write and read permissions of the entire %appdata% folder (it was not enough to increase permissions in the SketchUp's Plugins folder) and the problem was "easily" solved. Thanks for your help and kindness. Re: Fredo Plugins Not Working...Please Help!It sounds like you might have installed incorrectly.
You can try a repair to avoid future issues - this can be very subtle and hard to track down ! Whilst logged in as your normal Windows user, ensure SketchUp is closed. Find the SketchUp installer exe file - probably in your Downloads folder ? Select its icon. Right-click > context-menu > "Run as administrator" When prompted choose "Repair". It should not affect any installed plugins etc... If you install any complex app in any other way [e.g. by double-clicking the exe to Run it] your face the risk of incorrect permissions being set for all kinds of odd files and subfolders. A 'Repair' should do no harm. TIG
Re: Fredo Plugins Not Working...Please Help!The same thing happens to me, this is what I get in ruby.
What can I do? Error: #<Errno::EACCES: Permission denied - C:/Users/Adorian/AppData/Local/LIBFREDO6_DATA_Dir/LibFredo6_all_defaults.dat> c:/users/adorian/appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/fredo6_!libfredo6/lib6registry.rbe:144:in `initialize' c:/users/adorian/appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/fredo6_!libfredo6/lib6registry.rbe:144:in `open' c:/users/adorian/appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/fredo6_!libfredo6/lib6registry.rbe:144:in `write_to_file' c:/users/adorian/appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/fredo6_!libfredo6/lib6registry.rbe:127:in `store' c:/users/adorian/appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1282:in `usage_use' c:/users/adorian/appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1270:in `command_invoke' c:/users/adorian/appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1253:in `block (2 levels) in build_config_commands' c:/users/adorian/appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe:1348:in `call' c:/users/adorian/appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe:1348:in `block in add_command' SketchUp:1:in `call' Re: Fredo Plugins Not Working...Please Help!Have you tried doing the 'Repair' to SketchUp's installation, as explained earlier ?
If not, then try it and see if that helps... Note that sometimes correcting SketchUp's installation using the Repair can still leave some extensions' subfolders with faulty permissions. The reported folder... C:/Users/Adorian/AppData/Local/LIBFREDO6_DATA_Dir might be one of them... Try deleting that folder and its contents. It is hidden by default but pasting the path into a Windows Explorer windows address bar should still get you there - or change Folder-Options to shown hidden files/folders... After that, when SketchUp restarts and Fredo's tools run that folder and its contents will be recreated - this time with the permissions set up properly... TIG
• Page 1 of 1
