Wrap-R for SketchUp
Re: Wrap-R for SketchUp
Postby juju » Thu Feb 14, 2019 8:42 am
tengel07 wrote:Payed nd got nothing! Cheater!
This won't help resolve any problems you may be experiencing.
More details would help though, like when the transaction happened, etc.
Be sure to check you spam filters / folders as well, sometimes there are false positives.
User avatar
juju
Premium Member
Premium Member
Postby tengel07 » Thu Feb 14, 2019 8:45 am
i did check my spam folder and my folder with mails from unkown too.
Its now 24h after i did the payment and i got nothing - only the payment response mail.
They do not respond on mails to support too.
CHEATER!
tengel07
Postby Gábor » Thu Feb 14, 2019 10:59 am
Hi tengel07,
Thank you for your interest in Wrap-R.
I'm now investigating what happened. Will answer your support ticket soon.
Gábor
Gábor
Postby Gábor » Thu Feb 14, 2019 11:27 am
Hi tengel07,
I checked and our system sent out the licence by email at the time of the purchase. Sometimes it happens that some over sensitive spam filter puts it into the spam folder or erases it.
Anyhow now I've re-sent the licence both from the system and from my gmail mailbox. Hope you've received it this time.
Best regards,
Gábor
Gábor
Postby pilou » Thu Feb 14, 2019 8:10 pm
+ QFT + SubD
What is QFT ? :oops:
Speedy Galerie
User avatar
Top SketchUcator
Postby juju » Thu Feb 14, 2019 9:17 pm
pilou wrote:
+ QFT + SubD
Quad Face Tools :thumb:
User avatar
juju
Premium Member
Premium Member
Postby pilou » Thu Feb 14, 2019 10:56 pm
Aaaah! Thx! :enlight:
I believe that Optimaforever is an old famous member of PPB*! ;)
And Master of Su of course! :fro:
* PushPullBar
A very cool SketchUp forum who has alas hacked! :(
Speedy Galerie
User avatar
Top SketchUcator
Postby suSteve » Sun Mar 10, 2019 9:38 am
Could you please confirm that it is compatible with make 2017 and pro 2019?
thank you (the wrap-r website says pro 2018).
Also the website has a cyber monday 2018 code is that still valid?
thank you
suSteve
Premium Member
Premium Member
Postby TIG » Sun Mar 10, 2019 6:34 pm
Get the latest version to ensure v2019 compatibility...
You can but try the code ;)
User avatar
Global Moderator
Postby Gábor » Mon Mar 11, 2019 11:45 am
suSteve wrote:Could you please confirm that it is compatible with make 2017 and pro 2019?
Yes, it is compatible with these versions. But to be sure it fits your needs I suggest to obtain and try the 7 days free trial at https://wrap-r.com/trial-access.html .
If you already have purchased a license you can download the latest version of the program from here: https://s3.amazonaws.com/wrapr-download/WrapR-installer_2018_4.exe
Gábor
Postby optimaforever » Mon Mar 11, 2019 12:19 pm
pilou wrote:Aaaah! Thx! :enlight:
* PushPullBar
Ah! salut Pilou! yes, I'm ryo from PPB ;)
optimaforever
Premium Member
Premium Member
Postby suSteve » Fri Mar 15, 2019 12:09 pm
Thanks for the replies - just purchased. No need to do the free trial as the reviews are good enough for me.
suSteve
Premium Member
Premium Member
Postby Gábor » Sat Mar 16, 2019 8:58 pm
Thank you for purchasing Wrap-R. I wish you loads of happy unwrapping! :)
Gábor
Postby suSteve » Tue Mar 19, 2019 4:10 pm
One of the bug bears and hopefully I have this wrong is:
I choose ctrl to create the start of my cut and I can't see the end of my cut so I hold down the middle mouse and shift key to pan and by doing that I switch over to loop mode and lose my start cut.
Is there a way around this?
thank you
Also, is there a way to pan the 3D object in wrap-r. I tried right click (which I think I saw somewhere) but that just gives me a context menu. Hand tool, middle mouse + shift does not work
thanks again
suSteve
Premium Member
Premium Member
Postby Gábor » Wed Mar 20, 2019 8:40 pm
suSteve wrote:I choose ctrl to create the start of my cut and I can't see the end of my cut so I hold down the middle mouse and shift key to pan and by doing that I switch over to loop mode and lose my start cut.
Do I understand well that you are trying to select an edge loop in the 2D window? In edge select mode pressing holding down T and left clicking an edge should mark the beginning of the edge loop. Then you can release T and pan with middle mouse button (Shift is not necessary) and then by again holding T and left clicking the end of the loop should create the loop. Is it not working so for you? Would it help if in loop select mode the middle mouse button would still do the panning?
suSteve wrote:Also, is there a way to pan the 3D object in wrap-r. I tried right click (which I think I saw somewhere) but that just gives me a context menu. Hand tool, middle mouse + shift does not work
Panning in the 3D window should work with Shift + Right mouse button
Gábor
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Previous
Return to Extensions & Applications Discussions
Who is online
Users browsing this forum: No registered users and 4 guests
Visit our sponsors:
