[Plugin]Make Unique Plus
Postby yorik1984 » Tue Feb 07, 2017 5:37 pm
Hello everybody!
I represent my small plugin for big modeling improvement!
Thanks for honoluludesktop
and his plugin Make Unique Selected Components
ABOUT
Plugin for Sketchup 8 Pro or above for making unique selected components depend of nesting levels.
USING
Right click on component and/or group, or selected components and groups, and "Make Unique Plus". It has two submenus:
  1. Only parent level - This will make unique all selected components without their nested levels. Any report or message are absent.
  2. Choose nested level... - This will make unique all selected components and their nested selected levels components.
You can choose nested level from list. 2 level is parent. Report has three understandable options:
  • Off
  • Short in messagebox
  • Full in console
NOTE. In SketchUp version 2014 or above console will be open automatically if it not opened yet. In other case you must open via "Window > Ruby Console".
INSTALLING
Install from .rbz or source code on GitHub
TODO
- Make unique components in any sublevel and make unique all parent components thru upward to model parent level
3
yorik1984
Re: [Plugin]Make Unique Plus
Postby pbacot » Tue Feb 07, 2017 6:10 pm
Honolulu Desktop's legacy continues.
Thanks for this Yorik. I've been using another plugin, but this is a needed function. Saves a lot of trouble.
Top SketchUcator
Postby Pixero » Tue Feb 07, 2017 6:28 pm
Thanks.
Pixero
Postby yorik1984 » Tue Feb 07, 2017 7:02 pm
I receive message from user for more improvement:
To be continued... :)
yorik1984
Postby setmoveisplanejados » Tue Jan 07, 2020 6:18 pm
Hi yorik1984!
First of all, thank you very much for the plugin! It helps a lot!
The only time I have encountered a problem was with a test of a "worst case scenario" of mine (I'm developing a spreadsheet to use the data from sketchup).
I tried with two times of "component groups", making them as a new component and the other time using Component Groups. Your plugin worker just as expected when I make new components, but it failed when I use groups :(
setmoveisplanejados
Return to Extensions & Applications Discussions
