Hello out there does anyone know the plug in when you want to raise or elevate the interior walls of a building ???
Plug in for CAD drawings to elevate the interior walls
• Page 1 of 1
Re: Plug in for CAD drawings to elevate the interior wallsBy elevate do you mean raise them up off the ground or raise them up from a zero Z plane?
Either way, push/pull them to the required height. Remove plinth if you need to raise them off the ground, else you'll have them raised up from a zero Z plane. Save the Earth, it's the only planet with chocolate.
Re: Plug in for CAD drawings to elevate the interior wallsmaybe you can use this plug in....its very cool but it just make one part of the process .
it convert all the lines on faces, so then you have to push and pull the walls with out make the face http://www.iscarnet.com/sketchup/plugin ... _caras.php
• Page 1 of 1
Users browsing this forum: rv1974 and 3 guests
