by ct200224 » Wed Jul 13, 2016 4:28 am
Hey, I'm having a lot of trouble locating Visualizer plugins on my SketchUp.... It doesn't seem to be showing up at all. Here's a picture of my plugins folder in SketchUp 2015 with Visualizer installed:
at path /Users/[yourname]/Library/Application Support/SketchUp 2015/SketchUp SketchUp 2016 folder (w/o visualizer, duh):
at path /Users/[yourname]/Library/Application Support/SketchUp 2016/SketchUpCan someone help me at least locate the file? Maybe someone could just upload the files so that I can manually download them? Please?
ct200224
- Name: Caleb Mayhew
- Operating system: Mac
- SketchUp version: 2016
- License type: Free/Make
- SketchUp use: architecture
by driven » Thu Jul 14, 2016 11:34 am
ct200224 wrote:Hey, I'm having a lot of trouble locating Visualizer plugins on my SketchUp.... It doesn't seem to be showing up at all.
if you run this in 'Ruby Console' it will move a copy for you into the v16 User/Library... If you read through the thread, you should have seen that the v15 path is for the HD/Library... - Code: Select all
v15_folder = "/Library/Application Support/SketchUp 2015/SketchUp/Plugins/ImaginationVisualizer" v15_extension = v15_folder + '.rb'
v16_folder = File.expand_path("~") + v15_folder.sub('5', '6') v16_extension = v16_folder + '.rb'
command = 'ditto ' + v15_folder.inspect + ' ' + v16_folder.inspect + ' && ' + \ 'ditto ' + v15_extension.inspect + ' ' + v16_extension.inspect
system(command)
john
driven
- PluginStore Author
- Name: driven
- SketchUp version: 2015
- License type: Pro
- SketchUp use: engineering and mechanical design
by Fred* » Mon Jul 18, 2016 10:14 am
Hello
I'm still trying to install Visualizer 1.3 on a Mac running El Capitan 10.11.5 with SketchUp v. 16.1.1451
Can anyone give me step-by-step instructions? Or point me to some?
Thanks!
Fred*
- Name: Fred*
- SketchUp version: 2018
- License type: Pro
by driven » Mon Jul 18, 2016 8:52 pm
Visualizer will not install in SketchUp v16 without tricking it to do so...
temporarily renaming SketchUp 2016 folder in Finder to SketchUp 2015 will allow the download to make the the v15 files...
once downloaded, change the name back and run the ruby code posted in the post above...
john
driven
- Name: driven
- License type: Pro
by Fred* » Tue Jul 19, 2016 2:46 pm
Thanks, driven, for this help. I find, though, that I don't have a folder called "SketchUp 2016" on my Mac. Do you mean in the applications?
I had SU 8 until now and recently upgraded to SU 2016, in case that makes a difference.
Fred*
- Name: Fred*
- License type: Pro
by Fred* » Tue Jul 19, 2016 2:51 pm
Quick clarification: the folder SketchUp is in on my Mac is just called "SketchUp".
Fred*
- Name: Fred*
- License type: Pro
by driven » Wed Jul 20, 2016 8:58 pm
Applications/SketchUp 2016 is the one I refer too...
john
driven
- Name: driven
- License type: Pro
by Fred* » Thu Jul 21, 2016 4:21 pm
Got it. Thanks!
I was able to install it. Thanks for your help!
Fred*
- Name: Fred*
- License type: Pro
by willanie » Thu Jul 21, 2016 4:50 pm
Hi Fred,
Just so its clear, because I didnt think it was possible. You managed(with John's help) to get Visualizer installed on a Mac with only Sketchup2016 installed.
willanie
- Name: Will Anielewicz
- Operating system: Windows
- SketchUp version: 2014
- SketchUp use: other
by Fred* » Fri Jul 22, 2016 6:49 am
Hi willanie
Yes, that's correct, and I was glad to see that Visualizer works fairly quickly on my MacBook Pro Retina 13" 2014, with 2.8 GHz Intel Core i5 and 8 GB 1600 MHz DDR3 RAM.
Fred*
- Name: Fred*
- License type: Pro
by ste7ana » Fri Jul 29, 2016 2:42 pm
Does anyone know if there is a 32bit Visualizer version available? Thanks
ste7ana
- Name: stefan ana
- SketchUp version: 8
- License type: Pro
- SketchUp use: film and stage
by willanie » Tue Aug 02, 2016 12:50 am
There is no 32bit Visualizer version
willanie
by ste7ana » Thu Aug 04, 2016 7:02 am
 thanks willanie
ste7ana
- Name: stefan ana
- License type: Pro
by tmt0009 » Wed Aug 10, 2016 4:05 am
Hello,
I have installed Visualizer 1.3 and it works with 2015 (on MAC OS). However there are two issues.
The first, is that anytime I close out of the program while modeling it generates a crash report.
The second issue is that it doesn't appear in the Library/Application Support/SketchUp2015/SketchUp/Plugins folder which means I can't copy the Visualizer folder or the ruby file over to the SketchUp 2016.
Anyone have any ideas? Anything would help. Thanks in advance.
T.
tmt0009
- Name: Travis Taylor
- SketchUp use: product design
by ct200224 » Fri Aug 12, 2016 12:58 am
@driven: Thank you! Thank you so much! It's now up and running nicely!
ct200224
by AristosOntwerp » Fri Sep 02, 2016 3:22 pm
Hi Pilou, Quoi faire, si je n'ai pas 2015 comme voi de migrer. J'ai une installation frais de 2016 et installer Visualizer c'est impossible (Vous n'avez pas SketchUp 2013, 2014 ou 2015). Est-ce que tu a un trick pour cela aussi? Merci en avance, Aristos
AristosOntwerp
- Name: GalaxaDesign
- License type: Pro
- SketchUp use: interior design
- Level of SketchUp: Advanced
by AristosOntwerp » Fri Sep 02, 2016 3:34 pm
Hi, Does something like that work on Windows 7 as well? I tried with renaming the 64-bit program directory from SketchUp 2016 in SketchUp 2015 - but that was apparently too easy... Still the message: You need 2013, 2014 or 2015.... Aristos ---------------------------------------- driven wrote:Visualizer will not install in SketchUp v16 without tricking it to do so...
john
AristosOntwerp
- License type: Pro
by willanie » Fri Sep 02, 2016 5:19 pm
Im pretty sure you must at least install 2015 with windows OS. Here is a link to sketchup forum posting for getting 2015 Make. http://forums.sketchup.com/t/link-to-do ... make/24281
willanie
by pilou » Fri Sep 02, 2016 6:56 pm
@aristos Visualizer fonctionne aussi sur la 2015 avec au moins les versions de Window 8 et windows 10 que j'avais installées!
- Top SketchUcator
- Name: Pilou
- SketchUp version: 2017
- SketchUp use: hobby
by pilou » Tue Nov 08, 2016 3:34 am
Seems Visualizer don't works on 2017 with the previous tricks of installation 2015 - 2016 !
- Top SketchUcator
- Name: Pilou
by juju » Tue Nov 08, 2016 7:56 am
pilou wrote:Seems Visualizer don't works on 2017 with the previous tricks of installation 2015 - 2016 !
somehow I am not surprised I'm wondering how many other extensions / plugins will be problematic
juju
- Premium Member
- Name: Juju
- SketchUp version: 2021
- License type: Pro
by vico44 » Tue Nov 08, 2016 10:24 am
It was working with The 2016 on OS X
Pour cela il fallait juste copier l'ancienne installation sur /Bibliothèque/Application Support/Sketchup 2016/ (Pas dans User/Biblithéque/Application Support/Sketchup 2016/ mais à la racine du disque)
Cela ne marche pas pour Sketchup 2017
vico44
- Name: vico44
- License type: Pro
by driven » Tue Nov 08, 2016 12:20 pm
the 2016 tricks will not work for this or any plugin that cannot be updated to run on Ruby 2.2...
there is no legal way around this for encrypted extensions...
john
driven
- Name: driven
- License type: Pro
by masterpaul » Tue Nov 08, 2016 12:31 pm
Yep its busted. I wish they released the program as opensource. - Code: Select all
C:/ProgramData/SketchUp/SketchUp 2017/SketchUp/Plugins/ImaginationVisualizer/Extensions/IRExtension2015x64.so> C:/Program Files/SketchUp/SketchUp 2017/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in `require' C:/Program Files/SketchUp/SketchUp 2017/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in `require' c:/programdata/sketchup/sketchup 2017/sketchup/plugins/imaginationvisualizer/iv_initialize.rbs:67:in `<module:ImgTecVis>' c:/programdata/sketchup/sketchup 2017/sketchup/plugins/imaginationvisualizer/iv_initialize.rbs:10:in `<main>' C:/ProgramData/SketchUp/SketchUp 2017/SketchUp/Plugins/ImaginationVisualizer/iv_loader.rb:5:in `eval' C:/ProgramData/SketchUp/SketchUp 2017/SketchUp/Plugins/ImaginationVisualizer/iv_loader.rb:5:in `require' C:/ProgramData/SketchUp/SketchUp 2017/SketchUp/Plugins/ImaginationVisualizer/iv_loader.rb:5:in `<top (required)>' C:/Program Files/SketchUp/SketchUp 2017/Tools/extensions.rb:197:in `require' C:/Program Files/SketchUp/SketchUp 2017/Tools/extensions.rb:197:in `load' C:/ProgramData/SketchUp/SketchUp 2017/SketchUp/Plugins/ImaginationVisualizer.rb:25:in `register_extension' C:/ProgramData/SketchUp/SketchUp 2017/SketchUp/Plugins/ImaginationVisualizer.rb:25:in `<module:ImgTecVis>' C:/ProgramData/SketchUp/SketchUp 2017/SketchUp/Plugins/ImaginationVisualizer.rb:14:in `<top (required)>' Error: #<NoMethodError: undefined method `get_imgtec_rnd_api' for nil:NilClass> c:/programdata/sketchup/sketchup 2017/sketchup/plugins/imaginationvisualizer/iv_initialize.rbs:23:in `irapi' c:/programdata/sketchup/sketchup 2017/sketchup/plugins/imaginationvisualizer/iv_menu_commands.rbs:26:in `<module:ImgTecVis>' c:/programdata/sketchup/sketchup 2017/sketchup/plugins/imaginationvisualizer/iv_menu_commands.rbs:10:in `<main>' c:/programdata/sketchup/sketchup 2017/sketchup/plugins/imaginationvisualizer/iv_menus.rbs:9:in `eval' c:/programdata/sketchup/sketchup 2017/sketchup/plugins/imaginationvisualizer/iv_menus.rbs:9:in `require' c:/programdata/sketchup/sketchup 2017/sketchup/plugins/imaginationvisualizer/iv_menus.rbs:9:in `<main>' C:/ProgramData/SketchUp/SketchUp 2017/SketchUp/Plugins/ImaginationVisualizer/iv_loader.rb:6:in `eval' C:/ProgramData/SketchUp/SketchUp 2017/SketchUp/Plugins/ImaginationVisualizer/iv_loader.rb:6:in `require' C:/ProgramData/SketchUp/SketchUp 2017/SketchUp/Plugins/ImaginationVisualizer/iv_loader.rb:6:in `<top (required)>' C:/Program Files/SketchUp/SketchUp 2017/Tools/extensions.rb:197:in `require' C:/Program Files/SketchUp/SketchUp 2017/Tools/extensions.rb:197:in `load' C:/ProgramData/SketchUp/SketchUp 2017/SketchUp/Plugins/ImaginationVisualizer.rb:25:in `register_extension' C:/ProgramData/SketchUp/SketchUp 2017/SketchUp/Plugins/ImaginationVisualizer.rb:25:in `<module:ImgTecVis>' C:/ProgramData/SketchUp/SketchUp 2017/SketchUp/Plugins/ImaginationVisualizer.rb:14:in `<top (required)>' Error: #<NoMethodError: undefined method `enable_statistics' for nil:NilClass> c:/programdata/sketchup/sketchup 2017/sketchup/plugins/imaginationvisualizer/iv_menus.rbs:93:in `<module:ImgTecVis>' c:/programdata/sketchup/sketchup 2017/sketchup/plugins/imaginationvisualizer/iv_menus.rbs:12:in `<main>' C:/ProgramData/SketchUp/SketchUp 2017/SketchUp/Plugins/ImaginationVisualizer/iv_loader.rb:6:in `eval' C:/ProgramData/SketchUp/SketchUp 2017/SketchUp/Plugins/ImaginationVisualizer/iv_loader.rb:6:in `require' C:/ProgramData/SketchUp/SketchUp 2017/SketchUp/Plugins/ImaginationVisualizer/iv_loader.rb:6:in `<top (required)>' C:/Program Files/SketchUp/SketchUp 2017/Tools/extensions.rb:197:in `require' C:/Program Files/SketchUp/SketchUp 2017/Tools/extensions.rb:197:in `load' C:/ProgramData/SketchUp/SketchUp 2017/SketchUp/Plugins/ImaginationVisualizer.rb:25:in `register_extension' C:/ProgramData/SketchUp/SketchUp 2017/SketchUp/Plugins/ImaginationVisualizer.rb:25:in `<module:ImgTecVis>' C:/ProgramData/SketchUp/SketchUp 2017/SketchUp/Plugins/ImaginationVisualizer.rb:14:in `<top (required)>'
masterpaul
by spadestick » Tue Aug 01, 2017 11:06 am
The Visualizer website is down! Does anyone have a list of enhanced material names for the different reflection levels?
I only remember gloss and matte
I recall paint plastic / metal somewhere...
thanks-heaps!
spadestick
by vidy » Tue Aug 01, 2017 12:22 pm
spadestick wrote:The Visualizer website is down! Does anyone have a list of enhanced material names for the different reflection levels?
thanks-heaps!
Hi Spade, it's still there, check out this link: http://getvisualizer.com/blog/enhanced-materials.htmlRegards, VD
still so much to learn..
vidy
- License type: Pro
- Level of SketchUp: Beginner
by pilou » Wed Aug 02, 2017 10:34 am
And for French speaking!
- Top SketchUcator
- Name: Pilou
by Nathans » Fri Jun 15, 2018 6:54 pm
Any luck with visualiser on sketch pro 2018 and windows 10?!
Nathans
- Name: Nathan Stocks
by pilou » Fri Jun 15, 2018 9:39 pm
Works on Windows 10 only till SU 2016 !
- Top SketchUcator
- Name: Pilou
by Nick1 » Tue Aug 20, 2019 11:57 pm
Has anyone been able to render a sand blasted/ frosted glass in Visualizer. I have tested lots of different ways and no proper results. I know the software is somehow limited in some ways, but I thought maybe someone has been successful with a setting for frosted glass or sand blasted glass that would actually render properly in Visualizer.
Nick1
- Name: Nick1
- Robot
Return to Extensions & Applications Discussions
