Sketchup to Lumion - Material Problem
Postby ramonbastos » Sun Mar 24, 2013 11:34 pm
Hi guys, sometimes when i import a model from sketchup to lumion, some faces come "brown'.
Here is an image to show:
The roof is supposed to be white, as it is in the sketchup file:
Anybody knows why is it happening?
ramonbastos
Re: Sketchup to Lumion - Material Problem
Postby solo » Sun Mar 24, 2013 11:53 pm
It's not a material issue, it's a GI issue. What version of Lumion do you have? As the new version is tailored more for interiors and there are tools to get interiors right.
The quick fix (if your roof is a separate material) is to give it a very slight emissive value, or use the AO tools that come with new version (I do not have the new version so I cannot help)
http://www.solos-art.com
solo
Global Moderator
Postby ramonbastos » Sun Mar 24, 2013 11:56 pm
Yeah it´s possible to "fix" by adding emissivity, but it gets kinda weird..
I have lumion 3. What do you mean by AO tools?
ramonbastos
Postby solo » Mon Mar 25, 2013 12:10 am
In your movie effects options there is one called Global Illumination, There you can set sun effects, which will fix the ceiling, again I do not have this version so I cannot really help much, if you go to the Lumion forum they will help you better.
solo
Global Moderator
Postby 1996aditn » Wed Sep 05, 2018 1:59 pm
Even i am facing the same issue in lumion-8. Have you found the solution? please help me out.
1996aditn
Postby 1996aditn » Wed Sep 05, 2018 2:04 pm
Hii guys! please help me out. sketchup to lumion 8 material issue.
1996aditn
Postby juju » Wed Sep 05, 2018 4:24 pm
check in Sketchup what the face orientation may be, i.e. if those are oreinted correctly and not backfaces
juju
Premium Member
Premium Member
Return to Extensions & Applications Discussions
