Lumen RT Plugin not working
Postby Syndicate » Thu Feb 02, 2012 9:09 am
I hit the export to Lumen Rt button, I get a dialog box asking me to export the selected model or not. Either answer I choose the box goes away and then nothing.
Syndicate
Re: Lumen RT Plugin not working
Postby Nicholas Phelps » Thu Feb 02, 2012 3:16 pm
IS this happening with all models, or one in particular?
What happens if you try to export the empty SketchUp startup scene? Do you see the LumenRT interface?
Nicholas Phelps
e-on software
Postby Syndicate » Thu Feb 02, 2012 5:11 pm
Thanks Nicholas for the reply. I tested it with an empty scene, only the female standing there. Nothing selected, upon export, nothing happens. If I select her, and then hit Export, I get the dialog box again. When I choose any option, the box again goes away and nothing happens. This is also the trial version of Lumen Rt I downloaded. One more thing. As I was installing Lumen Rt, I opened Sketchup to check it out, it had realized that some parts of the plugin were already installed and gave me an error about certain files missing. I realized why it did that. I closed Sketchup and waited for the Lumen install to complete. Re-opened Sketchup with no errors but now the plugin doesnt work. Should I re-install Sketchup?
Syndicate
Postby Nicholas Phelps » Thu Feb 02, 2012 5:34 pm
Yes, sounds very much like a problem during install. But before you re-install SketchUp, I'd recommend you just try re-installing LumenRT first. Maybe uninstall it first, just in case.
Last edited by Nicholas Phelps on Thu Feb 02, 2012 5:42 pm, edited 1 time in total.
Nicholas Phelps
e-on software
Postby Syndicate » Thu Feb 02, 2012 5:38 pm
I tried that already to no avail :|
Syndicate
Postby Nicholas Phelps » Thu Feb 02, 2012 5:43 pm
Hmm. Well then if that's not too much of a hassle, could you try uninstalling LumenRT, then uninstall SketchUp, and then re-install both products?
Nicholas Phelps
e-on software
Postby Syndicate » Thu Feb 02, 2012 5:51 pm
Will do.
Women have the last word in arguments. Anything said after that is the beginning of a new argument.
Syndicate
Postby Syndicate » Thu Feb 02, 2012 6:05 pm
One thing I forgot to mention. Sketchup is 32-Bit, the plugin is 64. Does this make a difference?
Syndicate
Postby Syndicate » Thu Feb 02, 2012 6:23 pm
Thats a no go Nicholas. Still nothing :?
Syndicate
Postby Nicholas Phelps » Thu Feb 02, 2012 7:08 pm
Re 32 vs 64 bit: That's not a problem, since LumenRT is launched as a separate application.
I don't understand the cause of your problem.
To clarify, does the LumenRT interface appear inside of SketchUp, when you select it from the plug-in menu or click the LumenRT icon?
Nicholas Phelps
e-on software
Postby Syndicate » Thu Feb 02, 2012 7:38 pm
The interface does not show up. Ive attached an image of what I get. Also, I have ran setup with admin rights on both the 32 and 64 bit. Maybe Ive got a bad trial installer?
Syndicate
Postby Nicholas Phelps » Thu Feb 02, 2012 8:15 pm
Maybe a bad download. What happens if you have nothing selected in the scene when you invoke LumenRT?
Nicholas Phelps
e-on software
Postby Syndicate » Thu Feb 02, 2012 8:28 pm
If nothing is selected when I invoke Lumen Rt 2, then I dont even get the popup like in the pic. Nothing at all happens.
Syndicate
Postby Nicholas Phelps » Thu Feb 02, 2012 8:35 pm
Do you have other plug-ins inside of SketchUp? Is JAvascript disabled by any chance? I've heard of possible interactions with JS...
Nicholas Phelps
e-on software
Postby Syndicate » Thu Feb 02, 2012 8:40 pm
Its a barebones Sketchup install. The only plugin is LumenRT. I forgot how to check for Javascript enabled?
Syndicate
Postby Nicholas Phelps » Thu Feb 02, 2012 8:47 pm
I think it has to do with your browser settings. Not sure, though, sorry.
Nicholas Phelps
e-on software
Postby dburdick » Thu Feb 02, 2012 9:45 pm
Syndicate wrote:I hit the export to Lumen Rt button, I get a dialog box asking me to export the selected model or not. Either answer I choose the box goes away and then nothing.
Hi Syndicate,
Lets do a test.
Try loading in a bigger model to test LumenRT - like a house from 3D Warehouse or something. Then , lets open up the ruby console by going to Window --> Ruby Console.
Now, don't select anything in the scene, just go the menu Plugins --> LumenRT --> Export Full Model.
You should then see the export user interface:
If you don't see this interface, check to see what the Ruby Console is showing.
Dave
dburdick
e-on software
Postby Syndicate » Fri Feb 03, 2012 6:50 am
This is ridiculous. Sorry, Dave, didnt see your reply. Ill try this.
Syndicate
Postby Syndicate » Fri Feb 03, 2012 7:26 am
The interface didnt popup but heres what the console says:
Error: #<Errno::EACCES: Permission denied - D:/Program Files/e-on software/LumenRT 2/LumenRT/Ruby/Settings.ini>
(eval):1844:in `initialize'
(eval):1844:in `open'
(eval):1844:in `save_Settings'
(eval):1862:in `get_SavedSettings'
(eval):1636:in `initialize'
(eval):192:in `new'
(eval):192:in `lumenRT_exportModel'
(eval):278:in `load'
(eval):1844:in `call'
(eval):1844
Syndicate
Postby Syndicate » Fri Feb 03, 2012 8:01 am
FIXED!!! I realized that the console told me the settings.ini file was denied permission. I used a handy little tool called "Take Own" and took ownership of the LumenRT 2 folder and Voila! :sketchstatic:
Syndicate
Postby dburdick » Fri Feb 03, 2012 8:53 pm
Syndicate wrote:FIXED!!! I realized that the console told me the settings.ini file was denied permission. I used a handy little tool called "Take Own" and took ownership of the LumenRT 2 folder and Voila! :sketchstatic:
Glad you got it working - let us know what you think after your test runs.
Regards,
Dave
dburdick
e-on software
Postby whiterabbit » Wed Apr 17, 2013 4:07 am
I have same issue. no export function suddenly, tried a reinstall too.
below is the ruby info. Only material editor appears. No export from dropdown menu or from lumenrt buttons. If I have a selection I do get the window that asks if I want to export the whole model or just the selection, but either way...nothing happens.
Setting Default Settings
Error: #<NoMethodError: undefined method `strip' for nil:NilClass>
(eval):2295:in `get_SavedSettings'
(eval):2292:in `each'
(eval):2292:in `get_SavedSettings'
(eval):1926:in `initialize'
(eval):241:in `new'
(eval):241:in `lumenRT_exportModel'
(eval):552:in `load'
(eval):2296:in `call'
(eval):2296
whiterabbit
Premium Member
Premium Member
Postby dburdick » Fri Apr 19, 2013 6:56 am
Hi WhiteRabbit,
Look like the Setting.ini may be corrupted. Go to ProgramFiles/LumenRT 4 Studio/LumenRT/Skp/Ruby and delete the Settings.ini file. Then, restart Sketchup and try firing up LRT again. It will create a new Settings.ini file.
dburdick
e-on software
Postby reno94 » Mon Jan 06, 2014 1:43 pm
HI. I can help you regarding your problem why nothing model scene during exporting 3d. Well, you need to GROUP or make COMPONENTS of all your materials (like Walls, Tables, Door, etc.) in sketchup before Exporting to 3d. as a result, all which GROUPED materials (like Walls, Tables, Door, etc.) are only be exported to 3D, which is ".dae" files. IF you DON'T GROUP OF MAKE COMPONENTS, there will be nothing to do with exporting.
sorry for my bad english..
Greetings from PH.
reno94
Postby skizzopatrick » Mon Nov 05, 2018 9:39 am
Hi Guys,
After reading the suggestions and tried different ways I still cannot figure out how to solve this thedious problem.
Here you can find the "Ruby console" output.
Closing UI
Starting Export
Error: #<NameError: uninitialized constant LumenRT2015::VueExportGUI::Main>
e:/program files/e-on software/lumenrt 2015/lumenrt/export/skp/ruby/lumenrt_ui.rbs:477:in `showUI'
e:/program files/e-on software/lumenrt 2015/lumenrt/export/skp/ruby/lumenrt_menu.rbs:139:in `lumenRT_exportModel'
e:/program files/e-on software/lumenrt 2015/lumenrt/export/skp/ruby/lumenrt_menu.rbs:535:in `block in <module:LumenRT2015>'
SketchUp:1:in `call'
All the best.
Patrick
skizzopatrick
Return to Extensions & Applications Discussions
Users browsing this forum: No registered users and 4 guests
