FluidImporter free .obj importer Beta 1.0.5 Updated
Postby fluid » Thu Mar 17, 2011 3:54 pm
Hi Everybody,
We just released the first beta of FluidImporter, a free, fast .obj importer entirely written in C++.
For now it supports only the .obj format, other formats will be added in future releases.
You can grab it from http://www.fluidimporter.com/downloads
Nicola
fluid
Re: FluidImporter free .obj importer Beta 1.0.0 released
Postby Khai » Thu Mar 17, 2011 3:57 pm
you mean a free Demo of....
Khai
Postby fluid » Thu Mar 17, 2011 4:02 pm
No, FluidImporter is completely free.
fluid
Postby Khai » Thu Mar 17, 2011 4:12 pm
fluid wrote:No, FluidImporter is completely free.
it says
"Here you can download FluidRay for SketchUp demo. The demo version has all the features of the full version except for a limited resolution. "
the word DEMO is quite clear.
Khai
Postby numbthumb » Thu Mar 17, 2011 4:18 pm
Fluidimporter is completely free, FluidRay renderer can be downloaded as a demo.
Although it is a bit confusing:
Anyway, thanks for the heads-up.
Comfortably numb...
numbthumb
Top SketchUcator
Postby Khai » Thu Mar 17, 2011 4:20 pm
my bad. the filenames also confused 2 others I showed it to as well. to alike on the same page.
Khai
Postby fluid » Thu Mar 17, 2011 4:21 pm
There is a distinction between "FluidImporter" and "FluidRay".
FluidImporter is a plugin to import .obj files in SketchUp and is FREE.
FluidRay is the physically based renderer, and is in fact available in DEMO version.
If you want a FREE .obj importer, just scroll down the download page... http://www.fluidray.com/downloads
fluid
Postby TIG » Thu Mar 17, 2011 4:33 pm
Thanks for this free compiled OBJ importer; it is potentially a welcome advance on my own free OBJimporter Ruby script, that can be slow and not always successful...
I have tested yours against mine and I can now comment as follows...
It is very fast. [there's no 'progress-report' - but that's probably because it was so fast?]
It makes no attempt to make the object the correct size - i.e. there's no 'units' option. It therefore needs manual scaling after the import.
It has no option to flip the object's YZ axes - many OBJ are made with these flipped. It therefore needs manual rotation after import.
It does not follow the associated MTL file's settings, and although it makes all of the required materials by name it does not assign RGBA values or textures to them - instead it makes all materials look the same with a 'checker' texture... which is confusing.
I appreciate that this is the first version but if it is to be taken seriously I recommend that you address these issues with some urgency...
Global Moderator
Postby fluid » Thu Mar 17, 2011 5:09 pm
Hi TIG,
Thanks for the suggestions. I'll put them on the top of the list.
Nicola
fluid
Postby Rich O Brien » Fri Mar 18, 2011 2:20 am
This is causing alot of bugsplats for me? On quite simple .obj files.
Rich O Brien
Administrator
Postby TIG » Fri Mar 18, 2011 10:20 am
Rich O'Brien wrote:This is causing a lot of bugsplats for me? On quite simple .obj files.
And no 'Error 666' ;) [private joke :roll: ]
Global Moderator
Postby fluid » Sat Mar 19, 2011 6:12 pm
Richard, can you provide the file that causes the crashes?
fluid
Postby fluid » Sat Mar 19, 2011 6:54 pm
Just released v.1.0.1 featuring:
- Units options
- Flip YZ option
- Read color and texture from material library
- Triangulate polygons option
- Should handle negative indices (not tested)
Thanks to TIG for the suggestions.
Check at the end of the page: http://www.fluidimporter.com/downloads
fluid
Postby TIG » Sat Mar 19, 2011 7:09 pm
fluid wrote:Just released v.1.0.1 featuring:
- Units options
- Flip YZ option
Check at the end of the page: http://www.fluidray.com/downloads
Thanks, couple of issues...
Flip YZ Yes 'mirrors' the result too, and it's not placed the same as in the original :?
The Material Groups Yes/No Option is confusing as it did exactly the opposite what I expected... :roll:
Global Moderator
Postby fluid » Sat Mar 19, 2011 7:45 pm
Released 1.0.2, should fix the issues...
fluid
Postby TIG » Sat Mar 19, 2011 7:54 pm
fluid wrote:Released 1.0.2, should fix the issues...
Good, it seems fixed - I haven't managed to break it yet...
-1
Global Moderator
Postby pibuz » Sat Apr 02, 2011 2:17 pm
Hi fluid!
Wonderful tool, your obj importer!
..still, I seldom find some troubles in importing some obj files: most od the times SU reads the textures and UV mapping very well, but sometimes it happens that only ONE material is read from the source obj file, and it is applied to the whole geometry (note: all the faces are correctly UV mapped with the texture of the only material imported).
How come this? Can I fix it?
Thank you a lot!
pibuz
Postby TIG » Sat Apr 02, 2011 2:26 pm
The OBJ importer tool is in need of at least one last tweak... it isn't reading the materials 'alpha' from the MTL file. For example...
newmtl Translucent_Glass_Gray
Ka 0.000000 0.000000 0.000000
Kd 0.500000 0.500000 0.500000
Ks 0.000000 0.000000 0.000000
d 0.600000
The d value is used as this material's transparency 'alpha' thus - material.alpha=d
Global Moderator
Postby Krisidious » Sat Apr 02, 2011 8:37 pm
I use Tig's .OBJ importer... is there something different about this one? does it allow me to import a glass of beer? cuz I could use one.
By: Kristoff Rand
Home Designer
Unique House Plans
Krisidious
Postby TIG » Sat Apr 02, 2011 9:00 pm
Krisidious wrote:I use Tig's .OBJ importer... is there something different about this one? does it allow me to import a glass of beer? cuz I could use one.
This new 'compiled' OBJimporter WILL be better than mine - IF he fixes the transparent material issue...
It's faster...
Global Moderator
Postby fluid » Mon Apr 04, 2011 12:17 pm
Hi pibuz, can you provide the file that causes problems?
fluid
Postby fluid » Mon Apr 04, 2011 12:43 pm
Just released 1.0.3, should have transparency working properly.
fluid
Postby TIG » Mon Apr 04, 2011 12:47 pm
Super !
Global Moderator
Postby dedmin » Mon Apr 04, 2011 1:50 pm
:sketchstatic: :sketchstatic: :sketchstatic: :sketchstatic:
Thanks!!!
dedmin
Postby pibuz » Mon Apr 04, 2011 3:22 pm
fluid wrote:Hi pibuz, can you provide the file that causes problems?
Hi Fluid! Thanks for your reply! I'm really looking forward to slve this issue, so I can start building a good set of outdoor vegetation :thumb:
You can pick a random tree from this link:
http://www.xfrog.com/2011/01/130-free-x ... available/
They all show the problem when I try to import the obj file. Note that all textures are in the same folder as the obj model, so I guess there is no path conflict or anything..
pibuz
Postby TIG » Mon Apr 04, 2011 3:30 pm
The texture image files need to be in the same relationship to the OBJ file, as set in the MTL file.
Open the MTL file in Notepad[++] and read it...
You will find that Xfrog OBJ texture image files usually stay in the same folder with the OBJ, as there is not a subfolder specified by the MTL file.
If an MTL file needs a subfolder for the texture image files' paths then if it doesn't exist you simply make a new folder to match, next to the OBJ file, and move the texture image files into it...
Global Moderator
Postby pibuz » Mon Apr 04, 2011 3:46 pm
Oh thank you TIG, I'll check that!
EDIT: just checked and in fact no subfolder seems to be required.
BTW, after the import, the material given to the branches is applied to the leaves too...
I'm attaching the mlt file to make sure I'm not reading it wrong..
pibuz
Postby TIG » Mon Apr 04, 2011 3:50 pm
These are relatively large objects with complex texturing and take a while to load...
Over 53 million lines of code in the largest OBJ in that zip !!!
They are so 'heavy' that one or two can kill you model - avoid shadows etc !!
I see what you mean as typically only 1 texture comes in - the first one !
When the OBJ and MTL says there are perhaps 7 in the original !!
The MTL file correctly specifies the materials, the image files are there and the OBJ correctly assigns materials to faces half of the face son my import are wrongly oriented - so you need to run one of my tools to add the material to both faces, smooth edges etc so it looks right!!!! ....
My old clunky Ruby based importer does work... but takes [almost] forever to process the OBJ file !
and then it's 40Mb and half the faces are wrong so I have to fix those with another tool and then add matching back materials and hide edges etc... :roll:
Fluid... back to work ! The material importing is broken!
The usemtl lef etc before each set of face definitions f 1/2/3/... needs to be read in used AND the materials made from the MTL specs...
Global Moderator
Postby thomthom » Wed Apr 06, 2011 1:49 pm
I'm getting crashes when I try to import an .obj file I got. (120MB)
I've tried different options - triangulate on/off, material on/off - but it bugsplats every time. Memory usage of Sketchup.exe doesn't exceed 300MB.
Any ideas?
PluginStore Author
PluginStore Author
Postby jason_maranto » Wed Apr 06, 2011 3:14 pm
Wow, that is extremely fast! Thank-you :ecstatic:
Best,
Jason.
jason_maranto
Next
Return to Extensions & Applications Discussions
Users browsing this forum: amkdm and 1 guest
