Thea Render - Interactive Rendering
• Page 1 of 5 • 1, 2, 3, 4, 5
Thea Render - Interactive RenderingSome of you might already seen Thea Render with interactive studio at the 3D BaseCamp. Thea Render is now available at the Thea Render downloads. Don't forget to get a SU2Thea plugin.
[Updated to refer release version] Last edited by notareal on Wed Mar 30, 2011 7:20 pm, edited 6 times in total.
Re: Thea Render - Interactive RenderingLets not forget to mention the new 'shadow catcher'.
5 minute render test.
Re: Thea Render - Interactive Rendering4 minutes unbiased (TR2) with glare.
NO post processing (raw Thea)
Re: Thea Render - Interactive RenderingThanks.
5 minutes, 5 cars. ![]()
Re: Thea Render - Interactive RenderingWhat hardware specs you got Pere?
Re: Thea Render - Interactive Renderingi7 940, 12GB ram, Win 64, Thea 64
Re: Thea Render - Interactive RenderingAnd the GPU?
Re: Thea Render - Interactive RenderingGeforce 280
Just for a record - GPU is not being utilized in Thea yet. Author of Thea Render for SketchUp
Re: Thea Render - Interactive Rendering6 minutes, DOF, IR unbiased, glare in Thea studio
Re: Thea Render - Interactive RenderingA tutorial describing interactive render functionality is now available:
http://www.thearender.com/resources/The ... index.html Created by: Patrick Nieborg Our technology announcement contains also some key info about interactive render: http://www.thearender.com/forum/viewtop ... =17&t=3435 Welcome to try Thea Render, Thea support | kerkythea.net -team member
Re: Thea Render - Interactive RenderingThe license that came with my copy of Thea is not being recognized.
notareal, I sent you a PM on the Thea forum.
Re: Thea Render - Interactive Rendering@Boofredlay looking on it.
Re: Thea Render - Interactive RenderingJust a note, Thea Render (IR) beta download is available from public web site, so there is no registration process anymore. Feedback is much appreciated, so if possible register on forum for detailed discussion.
Re: Thea Render - Interactive RenderingThea Render academic license is introduced (for plugins too)
http://www.thearender.com/forum/viewtop ... =16&t=3730 Welcome to try Thea Render, Thea support | kerkythea.net -team member
Hi Solo ![]() Just a little stupid question ![]() Is it possible to manage the real scene which is around the cars into Thea itself or do you do a sticking work into Photoshop or some else ? - - simon Ps: very nice scene! Re: Thea Render - Interactive RenderingSimon, I'm not sure I understand the question.
Re: Thea Render - Interactive RenderingPete, I think he's asking if you can control the position and look of the HDRI image within Thea, or did you do it externally. Probably because of the seamless way that the tonal qualities match between the IBL and the Geometry. Also the CFR in there is helping sell the illusion that it's all one photograph. Hard to achieve that in other engines.
Stunning render...I must say!! ![]() ![]() 3D Artist at Clearstory 3D Imaging
Guide Tool at Winning With Sketchup Content Creator at Skapeup
Re: Thea Render - Interactive RenderingAh, yes and yes.
You can move the HDRi around as well as camera and objects, then as mentioned using CRF's you can pretty much blend them like I did above.
Re: Thea Render - Interactive Rendering@Earthmover,
![]() thanks! , You have perfectly translated my interrogations ![]() @Solo
How do you import this HDRI into a Thea scene? I have searched this option without find it. And also: Is it possible to include a HDRI into a SketchUp model and export the model into Thea? Very simple questions, sorry for disturbing.. ++simon Re: Thea Render - Interactive Rendering
At the top right, go to Environment > IBL (Image Based Lighting I presume). Enable the feature you want (there are options to open different resolution images of the same file for performance reasons) and import your hdr image. If you are not planning to do any fancy stuff, Background mapping is enough (that should be a full resolution image however). For simple reflections in windows for instance, you may also wish to enable the reflection channel at least if I am not mistaken.
Re: Thea Render - Interactive RenderingThea Render RV425 Beta1.6.3 is available. Interactive render is now much faster when tweaking image-based lighting settings (IBL panel), also some network rendering & packing related bugs are fixed.
Re: Thea Render - Interactive RenderingThea Render RV446 Beta1.7.1 is available (dev forums, registration required. Available in few days from public download).
There been some hard developing work for this release. With recent technical advances Thea Render will give you; region rendering, improved efficiency of unbiased TR1 engine, ambient occlusion support (with dirt mapping) for BSD and the terminator artifact treatment. Terminator artifact treatment is quite important for users that do relay on low polygon models. RV446 also contains numerous bug fixes (Changes Log). Welcome to try Thea Render, Thea support | kerkythea.net -team member
Re: Thea Render - Interactive RenderingAnother killer upgrade. I can't believe what you folks have done to Thea during beta.
Cudo's, and thanks so much. Just monkeying around....like Monsanto
