Alpha Channel, Trees, Vray - HELP
General discussion on V-Ray for SketchUp
Postby CurryPork » Mon Jan 19, 2009 5:26 pm
Hi forum, I need some alpha channel help. I don't know if it's a Vray setting or a Sketchup setting.
Basically, I have some 2D and 3D trees sketchup trees, but I cannot get them to render correctly in VRAY for sketchup. How can I fix the alpha channel?
CurryPork
Re: Alpha Channel, Trees, Vray - HELP
Postby thomthom » Tue Jan 20, 2009 8:23 am
You need to extract the alpha channel as a grayscale image. Then add that to the transparency slot in the diffuse channel. V-Ray doesn't read the alpha channel from PNG images, so it need to be separate.
PluginStore Author
PluginStore Author
Postby CurryPork » Tue Jan 20, 2009 3:26 pm
How do you extract the alpha channel? I can't even find the PNG file from these trees. The 2D might be possible with Photoshop, but how would you extract from the 3D tree?
CurryPork
Postby Gaieus » Tue Jan 20, 2009 3:41 pm
How did you get these trees? What the images used in them is needed is a clip map (if you can get the original png files, you can create these clips easily in PS).
Postby CurryPork » Tue Jan 20, 2009 4:00 pm
Here are the trees. I got them either from here, the internet or the warehouse. But my point is how can you extract the PNG or the alpha channel from these sketchup files.
CurryPork
Postby thomthom » Tue Jan 20, 2009 4:09 pm
Right click the material in the SU material editor, choose "Extract Texture Image". Save the file to disk and open in your image editor of choice to extract the alpha channel.
PluginStore Author
PluginStore Author
Postby CurryPork » Tue Jan 20, 2009 4:21 pm
Thanks Thom, I tried right clicking everywhere and cannot find that feature.
CurryPork
Postby thomthom » Tue Jan 20, 2009 4:27 pm
Sorry. Be in the list of materials. Not in edit mode. (The "Select" tab next to "Edit")
PluginStore Author
PluginStore Author
Postby CurryPork » Tue Jan 20, 2009 4:50 pm
Thanks Thom. I learned something new.
I got the alpha channel out of the tree now. Do you know how to make it work in Vray?
I assign a PNG as a bitmap in the COLOR slot in DIFFUSE and the alpha layer as a bitmap in the TRANSPARENCY slot in the DIFFUSE. But when I render in Vray it's not working... any suggestion?
CurryPork
Postby CurryPork » Tue Jan 20, 2009 5:15 pm
OK, I got it to work... thanks.
CurryPork
Postby chango70 » Tue Jan 20, 2009 5:24 pm
So how did you get it to work?
chango70
Postby CurryPork » Tue Jan 20, 2009 5:25 pm
I have it working for the 2D tree and this works for the 3D tree as well. So, just extract the alpha channel from the original texture as Thom described.
In VRAY, apply the original texture in the Color slot and the alpha in the transparent slot. Render and this solves it.
Thanks Thom.
CurryPork
Postby chango70 » Tue Jan 20, 2009 5:48 pm
Thx I just tried it myself and it works.
chango70
Postby devran » Sun Feb 01, 2009 5:26 pm
Hi Fellowcombatants listen!!! First You download the tree from warehouse... click on the component open it then rightclick and save the png. then open in Photoshop and rightclick on the icon in the layers menu and choose choose pixels... change to channels menu and create a alpha channel... this channel is saveable as a new picture... rightclick on the alpha channel and save as a new picture... thats all.... ( sorry for all non Photoshop users)... ciao devran
devran
Postby tvicari » Wed Aug 25, 2010 6:53 pm
You guys rock . . thanks for the tips, works great I have been looking for this solution for a long time. Thanks for making an effort and sharing knowledge.
tvicari
Postby jdcarling » Fri Sep 10, 2010 3:35 pm
Hey all,
I read this post and have figured out how to create the alpha channel in photoshop for a tree, but cannot find the location to insert the png properly in the material editor - diffuse - transparency. I clicked the lower case, then switched the left panel to TEXBITMAP but coudl not insert the alpha channel PNG anywhere... any tips.
jdcarling
Postby jdcarling » Fri Sep 10, 2010 3:36 pm
Hey All,
jdcarling
Postby thomthom » Fri Sep 10, 2010 4:29 pm
In the Transparency slot of the diffuse layer - add a TexBitmp:
PluginStore Author
PluginStore Author
Postby kalu » Wed Jan 12, 2011 10:11 pm
Hi thomthom:
I have this dilema, I read the post all perfect. I try to mimic the results and I want to know what I am doing wrong. I attach the tree and the images for the render. Please let me know what I am doing wrong. I use Sketchup Pro 8 and Vray 1.48.89. Some of the leaves show as a rectangular green. I have no Idea why.
Here is the link to the 3D model of the tree:
https://rcpt.yousendit.com/1023169415/e ... 1248da71be
Thank you!!!!
THE ONLY DIFFERENCE BETWEEN FICTION AND REALITY IS WHEN FICTION HAS TO BE CREDIBLE
kalu
Postby thomthom » Thu Jan 13, 2011 12:22 am
That's because you didn't map the backside of the faces. You can even see that in SketchUp.
I'm guessing you imported this from another 3d format?
Because of that you lost the backside information. Many other 3d apps doesn't display anything on the backside of faces. You have to explicitly enable it.
To quickly transfer UV mapping from one side to another, use this plugin: viewtopic.php?f=323&t=18992&p=155759#p155759
PluginStore Author
PluginStore Author
Postby kalu » Sat Jan 15, 2011 5:33 am
Thank you ThomThom, aweomse your plugin, I have that problem when Import 3DS trees...
This is the result:
kalu
Postby thomthom » Sat Jan 15, 2011 12:06 pm
:thumb: Nice
Where's that top tree from?
PluginStore Author
PluginStore Author
Postby kalu » Sun Jan 16, 2011 7:13 am
Is from ASGVIS, I need to use for a Tutorial that I work right now.
kalu
Postby teris » Fri Jul 22, 2011 12:59 pm
i've tried it... but it didn't work out... i wonder what part i've missed...
teris
Postby teris » Fri Jul 22, 2011 1:36 pm
i've tried it using vray 1.48.xx,,, it works... just use the color texture as transparency option... but when i tried it using vray 6 with the explanation above,,, it still didn't work... i still wonder... help me out guys... thanks...
teris
Postby bac9-flcl » Wed Dec 21, 2011 7:04 pm
Isn't there a way to utilize normal transparency types supported in SketchUp? I'm talking about alpha channels in .png/.tga/etc textures.
I have a vast library of transparent materials, but all of them have transparency data inside, not as a separate file - and it is very inconvenient for me to make separate images with alpha, just to meet weird V-Ray standards. Is it possible (in V-Ray material editor) to assign alpha channel of e.g. RGBA .tga texture to be used as transparency map?
bac9-flcl
Postby andybot » Wed Dec 21, 2011 7:25 pm
There is a check box in the material diffuse layer to "use color texture as transparency" for just such files.
my blog featuring recent projects
andybot
Premium Member
Premium Member
Postby ali64risk » Tue Jan 24, 2012 3:47 pm
devran wrote:rightclick on the alpha channel and save as a new picture... thats all
I tried but I could not...
please someone explain more?
(right clicking on alpha channel in Photoshop gave me 2 options: "duplicate channel" and "save channel"... where I can save alpha channel as png?)
ali64risk
Postby nomeradona » Wed Jan 25, 2012 2:11 pm
ali.. what they were talking was the workflow for the old version. the new vray version, dont worry, just follow what andybot said.
nomeradona
Postby ali64risk » Thu Jan 26, 2012 2:27 am
nomeradona wrote:just follow what andybot said.
thank you
yes it is working
ali64risk
Return to V-Ray
Users browsing this forum: shds27 and 5 guests
