GML texturizer 2.0
Re: GML texturizer 2.0
Postby danielito » Thu Jun 10, 2010 7:07 am
You are the best! It works!!!yeaaaaaaaa
dtrarch wrote:Hi ALL
Attached zip file has the info above, the edited GML Texturizer.rb and png files (in GML Texurizer folder.)
Works for me OK in SU 7.1 but not tested in other versions.
A really useful plugin and a small (very) payback.
Just install the original exe file and copy the edited folder and rb over the installed version.
FYI: version 2.0 was available as a shareware on the GML website but in Russian only.
This update is for GML Texturizer v1.0
dtr
danielito
Postby alhlhli » Fri May 29, 2020 1:59 am
Is it possible to modify the rb file
  To run on 2020
Attachment is wrong
Code: Select all
Error Loading File GMLTexturizer.rb
Error: #<LoadError: Exec format error>
C:/Program Files/SketchUp/SketchUp 2020/Tools/RubyStdLib/fiddle.rb:47:in `initialize'
C:/Program Files/SketchUp/SketchUp 2020/Tools/RubyStdLib/fiddle.rb:47:in `new'
C:/Program Files/SketchUp/SketchUp 2020/Tools/RubyStdLib/fiddle.rb:47:in `dlopen'
C:/Program Files/SketchUp/SketchUp 2020/Tools/RubyStdLib/Win32API.rb:25:in `initialize'
C:/ProgramData/SketchUp/SketchUp 2020/SketchUp/Plugins/GMLTexturizer.rb:8:in `new'
C:/ProgramData/SketchUp/SketchUp 2020/SketchUp/Plugins/GMLTexturizer.rb:8:in `<top (required)>'
alhlhli
Postby Dave R » Fri May 29, 2020 3:15 am
You should contact the author and see if they can help you with this ancient old plugin.
From your error message it does look like you installed it into the wrong directory. Maybe it would help if you put it in the right one which should be User/App Data/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins. You shouldn't be installing extensions into the Program Data directory.
User avatar
Global Moderator
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Previous
Return to Extensions & Applications Discussions
Who is online
Users browsing this forum: virtualfenix and 2 guests
Visit our sponsors:
