How to determine in which font a text was written
The ideal place for beginners to get help using SketchUp
Postby Alohaa » Mon Nov 20, 2023 1:01 pm
Hello,
I have a text that I need to correct, but I no longer know which font it was written in. Is this information available in SU? I don't find it anywhere.
I have tried all the fonts available in SU, but it is none of those and I don't understand how I could have written it in a non present font!
Kind regards
Alohaa
Alohaa
Re: How to determine in which font a text was written
Postby TIG » Mon Nov 20, 2023 2:19 pm
SketchUp Pro lists all of the ttf fonts installed on your computer.
So you should be able to find it... :o
Global Moderator
Postby Rich O Brien » Mon Nov 20, 2023 4:03 pm
Alohaa wrote:I have a text that I need to correct
3D or 2D text?
Rich O Brien
Administrator
Postby Alohaa » Mon Nov 20, 2023 8:07 pm
3D Text
Alohaa
Postby Rich O Brien » Mon Nov 20, 2023 8:24 pm
Since 3D text is actual geometry it is not editable without an extension.
But if you screenshot your text and upload it to https://www.myfonts.com/pages/whatthefont it might identify what the font is.
Rich O Brien
Administrator
Postby Alohaa » Mon Nov 20, 2023 8:54 pm
Ok, thanks.
Which extension enables editing?
Alohaa
Postby Rich O Brien » Mon Nov 20, 2023 9:22 pm
Alohaa wrote:Which extension enables editing?
https://sketchucation.com/pluginstore?pln=tt_texteditor
Rich O Brien
Administrator
Postby Alohaa » Fri Nov 24, 2023 11:35 pm
Thank you!
Alohaa
Postby Dave R » Sat Nov 25, 2023 12:59 am
Note that the 3D text needs to have been created with that extension in order to be editable. If it was created with the native 3D Text tool, the extension won't work on it.
Share the text with us in a screenshot or as a .skp file. We might be able to help you identify it.
Global Moderator
Postby Alohaa » Sun Nov 26, 2023 10:55 pm
Thank you for the offer!
I have since realised that I did not create the text in question in SU, but in Estlcam, the program in which I load the dxf and define the milling paths, and which is just as inflexible as far as this question is concerned, and have been able to identify the font in the long list: Monotype.
But, since I sometimes create it directly in SU, the question still arises. I will install this extension. If I don't get along, I will post the skp.
With kind regards
Alohaa
Alohaa
Return to Newbie Forum
Users browsing this forum: No registered users and 26 guests
