Toposhaper icon or toolbar not showing up
I have downloaded Toposhaper and installed it through the extension manager of my trial of Sketchup 2022. The extension manager lists it as installed and enabled, but I don't see any tool icon to use it.
Have you also installed LibFredo6, which is needed to support it...
Also install the SketchUcation toolset to get the latest licensing set up.
Restart SketchUp after the installations to sync everything...Also note that this Extension appears in a Tools submenu...
The toolbar associated with it should also be listed in the toolbars-dropdown... -
The toolbar associated with it should also be listed in the toolbars-dropdown...Thanks so much for taking the time to answer. I guess I missed the popup that said you have to restart to see the tool, something which I should have known. All is good now!
