Animator not rendering the sky with Vray after crash
• Page 1 of 1
Animator not rendering the sky with Vray after crashHi everyone,
Sketchup crashed while I was trying to generate a clip with animator with Vray as renderer. After restarting sketchup, vray and animator, loading my file and launching the video creation process, animator doesn't render the sky anymore while vray is (both with the "Test image" button or the general "Generate Video" button). See screenshots attached. Any idea ? Help greatly appreciated ! Olivier PS I'm speaking french as well. Re: Animator not rendering the sky with Vray after crashWhat version of SketchUp are you using? Your profile indicates a version that doesn't and never has existed. What version of Vray?
% (THERE'S NO PLACE LIKE) G28 X0.0 Y0.0 Z0.0 M30 %
Re: Animator not rendering the sky with Vray after crashHi Dave,
profile updated ! ![]() Sketchup 22 Vray for sketchup 6.00.01 PC, Dell 7820 tower with Intel xeon bronze 3204 cpu @1.9 ghz, 48 GB Ram, 2 Nvidia Quadro P1000 graphic cards (4 GB GDDR5. Memory Interface. each) Let me know if you need other infos. Best regards, Olivier Re: Animator not rendering the sky with Vray after crashAnimator does not interact with the rendering settings of VRay. So, the problem might be in the VRay API. As you had a crash, it might be that some hidden processes are alive.
So, I will suggest that you reboot the computer and try again.
Re: Animator not rendering the sky with Vray after crashDear Fredo,
thanks for your reply. Actually, I did restart my machine, but the issue persist this morning. Any other idea ? All the best, Olivier Re: Animator not rendering the sky with Vray after crashWhat happens if you create a new animation from scratch and render it?
Re: Animator not rendering the sky with Vray after crashHi Fredo,
I still haven't found a fix to the problem... I'm getting ![]() ![]() ![]() Is the setting of the sky in vray correct ? Should I try to re-install vray ? Could I send you the files so that you could do a test on your machine ? Any help greatly appreciated, Thanks in advance, Olivier Re: Animator not rendering the sky with Vray after crashIf you do a Natural render, do you get the sky displayed?
Re: Animator not rendering the sky with Vray after crashThanks again for your help Fredo...
Yes I do... so strange... here is a comparison of natural vs vray render through animator... but within vray alone, everything works... Re: Animator not rendering the sky with Vray after crashHi Fredo,
I'm desperate... Do you think that a reinstall of Vray would change something ? Any other idea ? Best, Olivier Re: Animator not rendering the sky with Vray after crashThis may be an idea. On my side, I am short of clues to understand how Animator could prevent things to happen (or not) in VRay....
Re: Animator not rendering the sky with Vray after crashThanks...
That's why I'm desperate, ![]() I'll keep you posted for the re-install. Re: Animator not rendering the sky with Vray after crashYou might try Twilight Render. I have used it with Animator and never had any problems.
![]() Re: Animator not rendering the sky with Vray after crashHi Dave,
thanks for the tip ! I'll give it a try with the hobby version... Are you aware of any limitation with this one ? All the best, Olivier Re: Animator not rendering the sky with Vray after crashDear Fredo,
I also tried with a prior version to the crash and the problem persits. So it's not due to some file corruption of some sort. I uninstalled Vray and re-installed it, and the problems remains as it is: It is so strange. Should I also try to uninstall/install Animator ? thanks again for your support. Olivier Re: Animator not rendering the sky with Vray after crash
Not really. I have used it many times with Animator. They also have several tutorials and a good support team. Let’em know I recommended them. ![]() Re: Animator not rendering the sky with Vray after crashDave, hi again !
I've installed Twilight 2 in Sketchup. Rendering seems fine with the render engine from the software itself, but I can't see it in the Generation of Video in Animator. Any way to fix this ? Thanks again, Olivier Re: Animator not rendering the sky with Vray after crashI am having problems with my laptop so I cannot currently explore this for you, but Twilight Render should show up in the Generate Video toolbar. It has always been there for me. It has been quite a while so I cannot remember how to add it.
I would suggest you post in the Animator thread. Fredo is always pretty good at responding. You might also post the question in the Twilight Render forum. Sorry I cannot run it to help you. EDIT: I opened a thread on the Twilight Render forum that I hope will result in some help here. Here is the thread https://www.twilightrender.com/phpBB3/v ... hp?t=12617 Re: Animator not rendering the sky with Vray after crash
I don't think you need to uninstall Animator (the video management is in LibFredo6 anyway). Likewise, if this happens with any model, I don't think this is useful to send me the model. There must be a setting left in VRay which is used by the VRay API. So, I would recommend you post to the VRay forum, asking whether the API has a separate configuration versus the direct rendering within VRay.
Re: Animator not rendering the sky with Vray after crashWhy isn’t Twilight Render showing up for him in Animator?
Re: Animator not rendering the sky with Vray after crashDear Dave,
Sorry for my silence, unfortunately no resolution yet. I'll try the vray forum as mentioned by fredo6 and will keep you both posted ! Thanks, Olivier Re: Animator not rendering the sky with Vray after crash
Dear Fredo, the vray forum is locked unfortunately Am I missing something ? Thanks, Olivier Re: Animator not rendering the sky with Vray after crashDid you ever get Twilight Render to show up?
Re: Animator not rendering the sky with Vray after crashSo basic SketchUp animation and some plugins do work with Hobby, like the standard SketchUp animation, but Animator requires something we call "external control". It allows Animator to actually execute Twilight Render calls. And that is limited to Twilight Render Pro.
I just downloaded latest available versions for LibFredo6 and Animator and Twilight Render is appearing for me as an option using Twilight Render V2 Pro. This machine is using Windows 10/(actually 11), SketchUp Pro 2022 I had to restart SU a couple times during install of "LibFredo6_v13.6a.rbz" and Animator_v3.8a.rbz but they eventually worked properly. Step 1 set up the animation with Animator Step 2 Set up frame rate and other settings in Animator>Generate Animation dialog -choose Images Sequence -Twilight Render -set F/s Step 3 Open Twilight Render animation dialog (Extensions>Twilight V2>Animation Editor), set resolution and render settings to use for Twilight to render animation Step 4 Inside Twilight Render animation dialog, open the "Advanced" pulldown menu and set up your animation FPS to match that of your settings for the Generate Animation dialog in Animator. - set folder and name of animation sequence Step 5 In "Generation of Video for Animator click the "Generate Video" button. It should start rendering using Twilight Render and placing the sequence of animated images in the "base image" folder you specified in Step 4. We will see about creating a tutorial for this powerful animation plugin. Last edited by Fletch on Tue Jan 17, 2023 8:42 pm, edited 2 times in total.
The official forum for vray hosted by chaos is open for business for licensed users ![]() https://forums.chaos.com/forum/v-ray-fo ... hup-forums Download the D'oh Book for SketchUp
I found out it requires the Pro version of Twilight Render before it will show up and work with Animator. It does work good though. Re: Animator not rendering the sky with Vray after crashDear Dave R, dear Fredo, dear (ntx)-Dave, dear Fletch and dear Rich,
many many thanks for all your support so far. I realized many things in the course of this discussion: -I should either get a pro version of Vray or twilight as it appears the test versions limit me to post question on forum (vray) or test the renderer with Animator (twilight). Not sure I can afford those for test purpose and artistic use that I practice as a hobby... -As I'm thinking of creating an NFT Art Piece and given my PC and graphic cards capacity, I might need a pro with the right material to do the final rendering anyway (It takes me 1 min/frame for an 800*450 pix and if I wish to go that way, the resolution should be much higher). (@Fredo, if you know anybody willing to help me for that matter, speaking french, with experience in SU, Animator and Vray, let me know in private message.) -I also had some discussion with a cabinetmaker and another woodworking professional that incite me to modify some part of my model (and hence redo the whole animation). I'll then be able to possibly retest the rendering part. In any case, I'll keep you posted. Thanks again for your inputs, All the best, Olivier Re: Animator not rendering the sky with Vray after crashTwilight Render is only $99. At least it currently is not a subscription so the $99 is a one time charge
![]() Not all that expensive if you plan to use it for more projects in the future. Wish you luck in what ever direction you go. ![]() ![]()
• Page 1 of 1
Users browsing this forum: KyriousS and 3 guests
