Import error with gltf importer
I wanted to import a terrain from sketchfab and tried with two different models:
https://sketchfab.com/3d-models/american-road-9558c1673bff4ec7b1c7154e4826699e
and
https://sketchfab.com/3d-models/sea-cliffs-4-add5edc7a72940bcbd898d74e8402665Both fail with "Import Error"
Has anyone seen this error?
Here is the stack trace:
Import has failed. Details as follows:
#<TypeError: reference to deleted Group> Backtrace: /users/foo/library/application support/sketchup 2017/sketchup/plugins/centaur_gltf_import/gltf_importer.rbe:365:in `entities' /users/foo/library/application support/sketchup 2017/sketchup/plugins/centaur_gltf_import/gltf_importer.rbe:365:in `create_mesh' /users/foo/library/application support/sketchup 2017/sketchup/plugins/centaur_gltf_import/gltf_importer.rbe:209:in `import_node' /users/foo/library/application support/sketchup 2017/sketchup/plugins/centaur_gltf_import/gltf_importer.rbe:232:in `block in import_node' /users/foo/library/application support/sketchup 2017/sketchup/plugins/centaur_gltf_import/gltf_importer.rbe:230:in `each' /users/foo/library/application support/sketchup 2017/sketchup/plugins/centaur_gltf_import/gltf_importer.rbe:230:in `import_node' /users/foo/library/application support/sketchup 2017/sketchup/plugins/centaur_gltf_import/gltf_importer.rbe:232:in `block in import_node' /users/foo/library/application support/sketchup 2017/sketchup/plugins/centaur_gltf_import/gltf_importer.rbe:230:in `each' /users/foo/library/application support/sketchup 2017/sketchup/plugins/centaur_gltf_import/gltf_importer.rbe:230:in `import_node' /users/foo/library/application support/sketchup 2017/sketchup/plugins/centaur_gltf_import/gltf_importer.rbe:99:in `block in import' /users/foo/library/application support/sketchup 2017/sketchup/plugins/centaur_gltf_import/gltf_importer.rbe:97:in `each' /users/foo/library/application support/sketchup 2017/sketchup/plugins/centaur_gltf_import/gltf_importer.rbe:97:in `import' /users/foo/library/application support/sketchup 2017/sketchup/plugins/centaur_gltf_import/gltf_import.rbe:30:in `load_file'
Thanks for any advice
-J_Jonesedit: Just happened upon this one: https://github.com/YulioTech/SketchUp-glTF-Importer-Ruby
not sure how to install it for OSX or if it will make any difference.
Thanks for thoughts or advice -
Are you using the importer you linked to?
The path to the linked importer is
AppData\Roaming\SketchUp\SketchUp 2021\SketchUp\Plugins\yulio_gltf_import
Your error output lists
which to me seems to be a different extension
To Rich O Brien
I mentioned the github link as a P.S. afterthought. I didn't mean to confuse anyone.
The error came from the Centaur plugin.
To J Jones
I can't say why it outputs that many errors. Maybe incompatibility with SU2017? Did you try it in a trial 2021 version?
From the stack trace as well as your profile, you are on a Mac. But the capitalization of the items in the path is not standard. Are you perhaps running macOS on a case-sensitive filesystem (not the default)? There have been numerous strange issues reported in the past when SketchUp is installed on a case-sensitive filesystem.
Thanks for the info, I'm not sure, but I haven't done anything special to this mac. I think it's just the default. As far as I can tell, it is case insensitive.
File System Personality: APFS
Type (Bundle): apfs
Name (User Visible): APFSAnyway, maybe it just ran out of memory or maybe I'll try that other plugin I found.
-J Jones
