Follow-me twist problem
The ideal place for beginners to get help using SketchUp
Postby thegoodguy » Sun Oct 25, 2020 3:51 pm
I am usually able to solve most issues that I come across by googling and reading the many helpful post here, but I have been unable to find any solution to a problem I have with the follow-me tool. I have SU 2016.
I am trying to model a shaped wedding band. In the file I've upload (follow-me-problem.skp). There is the path of the wedding band shape and a simple rectangular profile. If I start the follow-me with the profile at the top of the path the extrusion expands on one side due to the follow-me twist, and if I start the profile at the bottom of the path, the extrusion contracts on one side.
After lots of hunting and reading I tried, Upright-Extruder, Follow-me And Keep, and 1001bit Tools (which I cannot get to work properly). None of these correct my problem. Has anyone any thoughts?
Many thanks.
Sud
thegoodguy
Re: Follow-me twist problem
Postby Box » Sun Oct 25, 2020 4:17 pm
Is this the sort of shape you are after?
If so a small investment in vertex tools would stand you in good stead.
I've just re-read your post and I'm not sure I understood what you needed, but it's very late here and I'm off to bed.
Postby thegoodguy » Sun Oct 25, 2020 7:22 pm
Box wrote:Is this the sort of shape you are after?
Thanks for the reply Box.
I have the Joint Push Pull extension wich does what have done, but it's not quite what I'm after. I hope the attached file will illustrate more clearly what I'd like.
At the top you can see a 2D example of the vertex option. Below it is what I'd like. It's more like the offset tool. Below these you can see what happens with follow-me. The extruded profile (x-section) turns/twists as it progresses along the path. So the diameter of the front of the ring (the finger size) is larger than the diameter of the back of the ring.
I hope I have explained it better.
Thanks.
Sud
thegoodguy
Postby pilou » Mon Oct 26, 2020 12:06 am
Just rotate 180° the rectangular surface that is not working ? (by it's gravity center)
But can you post an image of Start / Target volume wanted ?
PS Fill your personal profil, it's more easy for to help you...
Speedy Galerie
Top SketchUcator
Postby nlipovac » Mon Oct 26, 2020 12:22 am
I am sorry, just did not quite understand you there so here is my try on this.
At first, I only can get to offset that curve if the upper surface is planar.
So I first did JointPushPull on that upper surface to get a straight hight surface and then used
that surface to get a straight upper surface.
Then I used that surface and JointPushPull-Follow Push Pull to get high surfaces that are offsetting from the upper one.
Here is a file also because my explanation sounds weird, just a bit :-)
I reupload the file, now it is the SU20016 version.
nlipovac
Premium Member
Premium Member
Postby Box » Mon Oct 26, 2020 12:43 am
Have you tried upright extruder on their backs?
What about Extude edge and Joint push pull?
True bend would be another option.
4
Postby pilou » Mon Oct 26, 2020 2:57 am
Can't reload your last skp ! (save as 2016 as previous) ;)
Speedy Galerie
Top SketchUcator
Postby ntxdave » Mon Oct 26, 2020 3:01 am
A set of very interesting approaches. :thumb: :thumb: :geek:
ntxdave
Postby Box » Mon Oct 26, 2020 3:45 am
Don't forget you can always 'remove the finger' from the ring.
4
Postby pilou » Mon Oct 26, 2020 10:32 am
If you have not the pro version for Boolean operations you have Bool Tools 2
(powerful than native tools)
Speedy Galerie
Top SketchUcator
Postby ntxdave » Mon Oct 26, 2020 2:48 pm
More Good videos Box and Pilou. Thanks for sharing.
ntxdave
Postby thegoodguy » Mon Oct 26, 2020 4:31 pm
pilou wrote:Can't reload your last skp ! (save as 2016 as previous) ;)
Hi pilou,
The last skp I uploaded (follow-me-problem-2.skp) was in 2016 format :?
thegoodguy
Postby thegoodguy » Mon Oct 26, 2020 5:02 pm
Wow!
I kind of owe you all a little apology. The rectangular profile was super-simplified to illustrate the problem. I realise now that the impacts any solutions you guys may post. The actual profile I want to use is this:
Box; As I mentioned in my initial post, I tried Upright Extruder. It produces results much like the vertex option. It's good, but not perfect. The edge-extrusion/joint-push-pull produces similar results too, and also, I don't think that option would work with the profile I need. True-Bend is a great suggestion. After "flattening" the ring rail/path using the Unfold tool, producing a flattened complete ring using follow-me and the profile, and then using True-Bend, I'm getting exactly what I need.
The only issue I'm having now is the final solid isn't the "solid" that's needed for 3D-printing. There are many errors that Solid-Inspector finds. I know this is due to the high resultion I need to get a good final result when the ring is actually cast. I'm experimenting with scaling up before True-Bending. Hopefully that will solve the solid issue.
Thank you all for your input, suggestions and solutions. They've been v helpful and have reduced my headache :D
thegoodguy
Postby pilou » Mon Oct 26, 2020 5:57 pm
And why not use Curviloft for propagate some profils on rails?
Speedy Galerie
Top SketchUcator
Postby thegoodguy » Tue Oct 27, 2020 1:45 am
And the winner is ... Curviloft
Excellent solution pilou. Thank you v much. The perfect shape and a perfect solid with no complex intersections to fix.
Should fit snuggly against this lovely little Edwardian engagement ring.
Thanks again, everyone.
thegoodguy
Postby Box » Tue Oct 27, 2020 9:46 am
If you are doing a lot of jewelry it would be well worth your time to look into using vertex tools and true bend. It makes it easy to create rings from non symmetric geometry. And you can be as detailed as you need as long as you model cleanly. This required no cleanup after the bend except the removal of the double inner faces at the join. I only used 96 segments but you can easily go to the 200 you were using if need be.
Postby thegoodguy » Tue Oct 27, 2020 4:11 pm
Hi again,
Upon closer inspection, although the solidness is good and the profile alignment is good along all of the "straight" section of the rail, using Curviloft, the profile does twist on the shaped part of the rail. Back to TrueBend and solid-fixing. Scaling up x1000 reduced the errors to only 3 ... phew.
Just thought you might like to know.
thegoodguy
Postby pilou » Tue Oct 27, 2020 6:37 pm
Maybe we can try something...
Post the file of Profils and Rails in dxf format and let see that Moi3D (nurbs) will made as result in SKP format export...
...not sure...of the result :) (it's not your file just a test)
Here the structure of export SKP
Reloaded in SU
I must ask more polygons in export! :ugeek: (rendered as SKP file)
This time edges are perfect! (for an SKP file) :)
Speedy Galerie
Top SketchUcator
Postby thegoodguy » Tue Oct 27, 2020 8:47 pm
Hi pilou,
Rail and profile DXF file uploaded.
thegoodguy
Postby pilou » Tue Oct 27, 2020 9:08 pm
OK: reloadable! :)
Just a question : does the section is on the good place or must be placed like that ?
Or by it's gravity's center ?
Speedy Galerie
Top SketchUcator
Postby pilou » Tue Oct 27, 2020 9:12 pm
Next version of Moi (V4) will be more adapted for erase problems of the DXF!
Another thing : i must reduce the number of Control Points of the curves!
Or even redraw over it...
(Whithout change the form of course! )
Speedy Galerie
Top SketchUcator
Postby pilou » Tue Oct 27, 2020 9:45 pm
With section on the middle side ... path with 20 points against 200 points! ;)
Speedy Galerie
Top SketchUcator
Postby thegoodguy » Tue Oct 27, 2020 9:53 pm
Looks good pilou.
I finally got it done using TrueBend.
Thanks.
thegoodguy
Postby pilou » Tue Oct 27, 2020 10:05 pm
Many regulates can be done... ;)
This structure will be the SKP structure! :ugeek:
Here one...(skp file rendered)
ps SKP linked
Speedy Galerie
Top SketchUcator
Postby pilou » Tue Oct 27, 2020 11:26 pm
Just for be sure : your dxf was made directly from SketchUP or from another program ?
Speedy Galerie
Top SketchUcator
Postby thegoodguy » Thu Oct 29, 2020 10:51 am
pilou wrote:Just for be sure : your dxf was made directly from SketchUP or from another program ?
Hi pilou,
Yes, it was exported from SU.
thegoodguy
Postby pilou » Thu Oct 29, 2020 12:47 pm
Thx for the info!
Dxf from SketchUp are specific because curves are polylines so numerous "control points" !
Maybe Circles and Arcs can be exported as real curves...
With this one by Joergberg :ugeek: (for SU Make)
So circles and arcs are not "segmented" ! :fro:
As we can see for the circle...that is a true curve!
Speedy Galerie
Top SketchUcator
Return to Newbie Forum
Users browsing this forum: Google Bot and 6 guests
