Replacing same groups by component
The ideal place for beginners to get help using SketchUp
Postby jobamann » Fri Feb 22, 2019 5:05 pm
Hi sketchucatheads :geek:
I messed up, starting with my first model I made groups not components, and now I have to change all this groups the same way......
Is there a possibility to replace this groups by a component (with same dimensions as groups) in order to change all structures by one action??? Or can I select all the same groups by one action and turn it into a component???
Thanks for helping!!!!!!
Jo
jobamann
Re: Replacing same groups by component
Postby pbacot » Fri Feb 22, 2019 5:37 pm
I believe you want ThomThom's plugin "Groups to Components" Select one of the groups and in the Contextual menu you can choose the command "Group Copies / Select All"(or another selection choice). Once they are selected choose "Group Copies / Convert to Components". Each group has to be un-edited from the others. Perhaps someone has a one-time script for this, IDK.
MacOSX Mojave ShetchUp Pro v19L Twilight Pro v2 M2 Kerkythea PowerCADD
User avatar
Top SketchUcator
Postby JQL » Sun Feb 24, 2019 10:17 pm
After converting all groups to components, you can replace them all by a single one using component replacer plugin, also from thomthom
User avatar
JQL
Premium Member
Premium Member
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to Newbie Forum
Who is online
Users browsing this forum: Pete_Bach and 12 guests
Visit our sponsors:
