Download from 3d warehouse
The ideal place for beginners to get help using SketchUp
Postby drafter » Sun Jan 20, 2019 7:14 pm
2017 Make
Under window preferences, I set file location for Components. When downloading Warehouse components, I choose not to install in model. I want to install into my component directory instead. Now, every time I want to do this, I must set up the path so it goes where I want it to go. How do I make the path the default?
drafter
Re: Download from 3d warehouse
Postby Dave R » Sun Jan 20, 2019 9:58 pm
The path set under Preferences>Files is for components that are in the SketchUp model. When you right click on a component and choose Save as... that is the default directory. If you are just downloading components from the Warehouse to save into a directory, you'd probably do better to go to the 3D Warehouse in your browser and download them that way. Then, once you set the desired save to location, they should all automatically go there.
Out of curiosity, what sort of components are you collecting?
User avatar
Global Moderator
Postby drafter » Mon Jan 21, 2019 8:39 pm
Dave R wrote:The path set under Preferences>Files is for components that are in the SketchUp model. When you right click on a component and choose Save as... that is the default directory. If you are just downloading components from the Warehouse to save into a directory, you'd probably do better to go to the 3D Warehouse in your browser and download them that way. Then, once you set the desired save to location, they should all automatically go there.
I've got Make 2016 on my desktop. There, when I choose not to place component in model, a dialog box appears that directs the file to my components folder and to "save as". No such dialog appears with Make 2017. Instead, my Windows file explorer opens and I'm told not only to "save as", but then I'm required to indicate where to put the file.
drafter
Postby Dave R » Mon Jan 21, 2019 8:55 pm
I understand that. If you aren't inserting the files into your model, it'll be more efficient to just work through your browser.
User avatar
Global Moderator
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to Newbie Forum
Who is online
Users browsing this forum: Bing [Bot] and 2 guests
Visit our sponsors:
