Multiple animated groups with one click
• Page 1 of 1
Multiple animated groups with one clickIs it possible to run multiple functions with multiple groups?
For example, I want to create one main group containing 3 objects/groups, each subgroup/object should rotate in different position, but they all should run simultaneously on single main group click. Is this possible? Re: Multiple animated groups with one clicktry animator by Fredo6
Re: Multiple animated groups with one clickYou could learn how to do it if it's something you need to do. Or you could hire someone else to do it for you.
% (THERE'S NO PLACE LIKE) G28 X0.0 Y0.0 Z0.0 M30 %
What do you mean? What are these "functions" you refer to? Etaoin Shrdlu
Re: Multiple animated groups with one clickAccording to your profile, you have SketchUp Make. Dynamic Components might work for what you want but you have to have SketchUp Pro to create them.
Re: Multiple animated groups with one clickI didn't update my profile. I use Pro version but from what I know dynamic components are not necessary for functions and animations. They work also only with groups.
Re: Multiple animated groups with one clickThe functions Help page you linked to is for Dynamic Components.
Dynamic Components work with Components. They aren't called Dynamic Groups. For animations like you are referring to, you don't have to use Dynamic Components. You can use an extension like Animator but either way you'll have to learn how to use whatever you choose. Or you can hire someone to do the work for you. Etaoin Shrdlu
Re: Multiple animated groups with one clickI mean that the same functions can be used for components and groups.
Re: Multiple animated groups with one clickYes. When making Dynamic Components those functions can be used.
You should get on with doing it. You'd have had it done before now if you'd gotten down to it. Etaoin Shrdlu
Re: Multiple animated groups with one clickYou could upload a model with some commentary on how it should work
Re: Multiple animated groups with one clickI mean that those functions can be used also for pure groups (without components). Anyway, I want for example: 1. one click on the object (left) causes rotation of each subgroup (right) 2. first click on the object causes rotation of the object on one axis, second click causes rotation on the second axis, third click causes scaling Is this possible to do in SU without plugins? Re: Multiple animated groups with one clickSurely in Dynamic components (with Pro Version of SU)
But you must make a light coding!
Re: Multiple animated groups with one clickPerhaps you should take a look at SimLab Composer.
They have a free version and you can click on objects to animate them. Re: Multiple animated groups with one clickusing onclick formula with groups
1. rotation with cumulative angle 2. multi movement with a timeline called num Re: Multiple animated groups with one clickImpossible to load this above exemple1 (too recent version)
Re: Multiple animated groups with one clickshould have known better......
Re: Multiple animated groups with one clickBetter loading for a more large audiance!!
![]() So Dynamic Components I presume? ![]()
Re: Multiple animated groups with one clickThanks for these models, I've tried to figure it out and implement it to my idea, but still I don't get it. Can you just make that for me?:
1. 3 subgroups with different sizes, same axis - first click: red, blue rotates by 45, 90, green no change - second click: going back to start positions (0, 0) 2. 2 subgroups with different sizes, same axis - first click: red changes its size (2) - second click: whole group rotates by 90 (3) - third click: red gets original size (4) - fourth click: back to start/rotation -90 (1) 3. 2 subgroups with different sizes, same axis - first click: red changes its size (2) - second click: red changes its size (3) - third click: back to start/red changes its size (1) Re: Multiple animated groups with one clickThank you, I still can't recreate the same objects having same values.
ad 1: error in
ad 2: error in
Also, one more animation: 4. 2 subgroups - first click [right]: bigger subgroup rotates holding to smaller one, whole group moves to stick with wall object (independent object) - second click [left]: goes back to 90 rotation and sticks to the wall Re: Multiple animated groups with one clickWithout the file, I can't be sure, but is the child label "group" as well as the parent? if so then there is a reference to the same. Double click one of the labels and change the name
the next Re: Multiple animated groups with one clickOk, I fixed it and did what I wanted to do (more or less), thanks again.
• Page 1 of 1
Users browsing this forum: ARCHSG, Google Bot and 6 guests
