Soap skin not working
Hello
Hope someone can help me.
please have a look....my Soap Skin is not working correctly.
Am I doing something wrong with my shapes?
here some pix.thank you all for the help
I expect you'd find it works much better if you use smoother curves, avoid the sharp points and use a higher number for generating the surface.
I was just playing around and got this. It still needs a bit of fine tuning.
Hello Dave
Thank you for the Help.
I understand what you mean.I use illustrator to draw the shapes and export to Sketchup.
do you know a plugin that generates line shapes to bezier curves?....they work better
or to generate smoother curves?regards
Goran -
@goranmax said:
do you know a plugin that generates line shapes to bezier curves?....they work better or to generate smoother curves?
They do work better. I used the Bezier tool from Fredo's Bezier Spline which is available here in the Sketchucation Extension Store.
