Help with intersect faces
The ideal place for beginners to get help using SketchUp
Postby DFB » Sat Apr 14, 2018 5:32 pm
I cannot, for the life of me, figure out how to intersect faces. Here is a simple example:
Intersect Faces Example.skp
This example shows four groups. I would like to intersect the faces and delete the unwanted parts - for example, the ends sticking out should be removed.
I feel stupid because this should not be difficult. I can do it if I explode each group, select all, and intersect faces. Is that the only way to do this intersection? I ask, because I have had to do it that way on complex intersections and the cleanup takes a long time.
Thanks for any advice/tips.
DFB
Re: Help with intersect faces
Postby DFB » Sat Apr 14, 2018 5:36 pm
Sorry about the example - I did not see that my AddBlocker was preventing the attachment. Here is an attempt after disabling AddBlocker:
DFB
Postby TIG » Sat Apr 14, 2018 6:25 pm
You haven't explained why you want to Intersect these faces inside the groups...
However, to get intersection lines added into faces which are INSIDE a group, you first need to edit the group [double-click it or select+context-menu > edit], then select-all [Ctrl+A] > context-menu > Intersect with Model.
New edges will be added into the edit-context where selected faces intersect other objects.
Back-out of the edit,and repeat editing and intersecting faces in other groups.
If your aim is to delete parts of a group's geometry to form 'miters' etc, then you might also want to add faces to those 'cut-ends' - by over-drawing edges.
To see what you are doing more easily you can also chose the toggle in View > Component Edit > Hide Rest of Model [ it works on Groups too ! ]
User avatar
Global Moderator
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to Newbie Forum
Who is online
Users browsing this forum: Google Bot, tsvincent and 10 guests
Visit our sponsors:
