skethUcation privacy https
Re: skethUcation privacy https
Postby Pherim » Mon Nov 26, 2018 11:57 am
Gábor wrote:
Pherim wrote:I still have this problem with Firefox and Chrome.
Could you please send me a screenshot about what you see? Also could you please click on the lock icon in your browser's URL line and see the certificate details there?
The problem is, it's in German, I don't know if it would be of any use to you. I installed a portable English Firefox version to give you an English error screen, but the page works with that one for some reason. Then I tried creating a new profile, and once again it didn't work.
But now I switched back to my main profile and it appears to be working. Let's hope it stays like this. :thumb:
It still doesn't work in Chrome, but I only used this to check if Firefox was the problem. There i get the following error:
Code: Select all
NET::ERR_CERT_REVOKED
Subject: *.sketchucation.com
Issuer: COMODO RSA Domain Validation Secure Server CA
Expires on: 23.11.2019
Current date: 26.11.2018
And then a huge amount of apparently random characters and numbers.
Edit: Now the problem is back. The forums work without "https://" in front of "sketchucation.com", but when I click the icon in the address bar (there is only a shield, not a lock on this page), it says that the connection isn't secure.
Pherim
Postby TIG » Mon Nov 26, 2018 12:52 pm
I'll cleared all caches and restarted - with limited success.
Both Firefox [which says Verified by Comodo CA Limited] and Chrome [similar Comodo RSA msg - valid for one year to 22 Nov 2019] do not have this certificate error.
But Edge and IE11 still balk at 'server certificate revoked/expired'...
Is this perhaps a virus-checker db out of date ?
Global Moderator
Postby Gábor » Mon Nov 26, 2018 1:02 pm
Thank you. I've contacted our certificate issuer and it seems they made a mistake revoking the certificate. They sent me an other certificate what I've installed now. Could you please check now again with cache erase reload? If the problem seems to be fixed, please also check the expiry date of the cert.
FYI: The online SSL checker shows that everything is ok with the cert now: https://www.sslshopper.com/ssl-checker.html#hostname=sketchucation.com
Gábor
SketchUcation IT
Postby Pherim » Mon Nov 26, 2018 1:12 pm
No change so far...
Pherim
Postby Gábor » Mon Nov 26, 2018 1:15 pm
Pherim wrote:No change so far...
Thank you. If you click the https://www.sslshopper.com/ssl-checker.html#hostname=sketchucation.com link, does it show for you as well that the cert is OK?
Gábor
SketchUcation IT
Postby TIG » Mon Nov 26, 2018 1:39 pm
The SSL shopper link shows it's valid.
BUT, even with a cleared cache etc, both Edge and IE11 [AND Avast WebShield] report that SCF is using a revoked certificate, and block it !
As before, Firefox and Chrome are both OK, and report the SCF certificate as valid !
Global Moderator
Postby Gábor » Mon Nov 26, 2018 1:46 pm
Thank you for the information. FYI: I've contacted again our certificate issuer and now they are looking deeper into it. Will let you know when I get any information from them.
Gábor
SketchUcation IT
Postby Pherim » Mon Nov 26, 2018 2:20 pm
Now it works properly with https:// and I get the green lock icon!
Pherim
Postby solo » Mon Nov 26, 2018 2:38 pm
still not working for me on Chrome or edge
http://www.solos-art.com
solo
Global Moderator
Postby Pherim » Mon Nov 26, 2018 2:45 pm
solo wrote:still not working for me on Chrome or edge
Yes, Chrome also still doesn't work for me.
Pherim
Postby juju » Mon Nov 26, 2018 2:53 pm
https still fine here
juju
Premium Member
Premium Member
Postby Gábor » Mon Nov 26, 2018 2:56 pm
Thank you everybody for the feedback.
Now it should be ok for everybody as our cert issuer solved the problem. It was a problem on their side, they accidentally revoked the cert. The solution was that they gave us a new one.
I just hope it won't happen again with the new one.
Gábor
SketchUcation IT
Postby Pherim » Mon Nov 26, 2018 2:57 pm
Chrome works now.
Pherim
Postby pilou » Mon Nov 26, 2018 3:03 pm
Re works fine now! :thumb: (Opera)
Till the next time! ;)
Speedy Galerie
Top SketchUcator
Postby TIG » Mon Nov 26, 2018 3:05 pm
I confirm that the latest SCF certificate now works OK for me in the following browsers:
  • Firefox
  • Chrome
  • Edge
  • IE11
:D
Global Moderator
Postby solo » Mon Nov 26, 2018 3:08 pm
Fixed now
solo
Global Moderator
Postby Gábor » Mon Nov 26, 2018 4:07 pm
Thank you very much everybody for checking it.
Gábor
SketchUcation IT
Postby kaas » Mon Nov 26, 2018 5:15 pm
bitdefender is happy again as well
kaas
Previous
Return to Ideas Box & Board Issues
