Twinmotion mapping issue
Postby L i am » Mon Jan 11, 2021 10:25 am
I imported an SU model into Twinmotion and the mapping is screwed. I have attched images showing the problem. Does anybody have any ideas why this happened or suggest a fix?
Premium Member
Premium Member
Re: Twinmotion mapping issue
Postby jenujacob » Mon Jan 11, 2021 2:20 pm
I had a similar issue once and I belive I exploded the group and the problem got fixed. It might solve the issue for you as well.
jenujacob
Postby L i am » Tue Jan 12, 2021 10:06 am
jenujacob wrote:I had a similar issue once and I belive I exploded the group and the problem got fixed. It might solve the issue for you as well.
Thanks but the model was exploded. But I have the answer.......when you import the SU model you need to tick the "FixUV/Texture" box and all problems will dissapear. I was concerned as another fix was to project image as texture also works but would have taken a few hours on this model. I have attached where the "FixUV/Texture" is located and it needs to be set before importing.
Premium Member
Premium Member
Return to Hardware, Software & Gadgets
