Help with sketchyphysics moving a crank
I made a simple model in SU . The purpose is to move a block with an bend hing road passing trough its slot , just like a crank mechanism .
I tried everything, but I could not move it the right way.
Can somebody help me please !T.I.A.
Franky
For your problem i suppose you must "trim" the object (who must be moved by another thing) in simple boxes ! (so here 3 vertical 3D boxes)
Then grouped(i have not open your file)
Better now is now use MS Physics ( i believe Sketchy Physics is no more developped)
Here a complete tutorial (26 steps)
Pilou thank you in advance.
As you said , I made three separate blocks ( each one is a single group ), than what ?
Next step is to group them again ?
I do not understand what next .
